Question about Troy bilt Super Bronco Tiller 208cc
Won't start Bought tiller last fall and used it twice, now it wont turn over.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 61 Answers
It might be broken so you should go to the shop with it and complain
Posted on Mar 31, 2014
Gilson roto tiller model 51082
Something in the wheels drive is jammed preventing them from turning. That is why the turning belt starts to smoke when it is turning but cannot unstick the wheels. Need to unstick them for unit to work.
Apr 01, 2016 | WI Gilson Bycast Club Chair
Refurbished ft900 will not start
did u replace gas and see if it is gettin spark it should still be under wanate
Oct 13, 2012 | Husqvarna FT900 Adjustable Width Briggs &...
Just bought the tiller and it wont start
if you bought it brand new bring it back to the store if you bought it used need more info to help like fires on staring fluid has no spark etc
Mar 31, 2012 | Echo Garden
When primming the fuel bulb no fuel will come in the bulb. it great last fall when i last used it
remove bulb inspect for cracks or simply might need to be cleaned, use carburator cleaner
Apr 18, 2011 | Mantis 2-Cycle Tiller
Just bought an older Mantis 2 cycle tiller. The tines engage when the tiller is started. Of course that makes it hard to start with the tines on the ground! I don't believe it was doing this when I...
if the idle is too high the tines wont stop due to the tiller tines are run by a "centrifuigual clutch" which means when you increase the throttle speed the tines will start to turn : there are 2 adjustments you can try,1) adjust the idle screw under the carburetor where the throttle adjustment and a triangle piece of metal touch(your throttle cable wire will be attached to this triangle) ,if the triangle and idle adjustment don't touch and there's a gap between these 2 pieces close the gap by adjusting the 10mm adjusting nut,this will correctly set the idle #2) adjust the idle adjustment screw talked about above till the tines dont turn with throttle set at idle or lowest speed setting
Mar 26, 2011 | Mantis 2-Cycle Tiller
Honda 4 cycle cult wont start. New gas primer primes new spark plug. Won't fire.
Check the start switch and the start switch line. If not broken, check the choke switch and try different settings to start it. Last check the gas line for any cracks. This tiller can be easily be flooded when pushing the prime button..
Jun 25, 2010 | Honda 25cc 4-cycle Mini Tiller
Ariens 8hp Formula rototiller with tecumseh engine- will not start.. have checked spark plug... gas was drained last fall. troubleshooting tips please
well you should really cheek your spark to see if you are getting spark by using a screw driver in the spark plug agents the metal and see if their is an arc from the points
May 04, 2010 | Garden
My troy-built tiller/edger won't start without 500 pulls. it has a newplug and fresh gas-oil. it was sitting for some years without being used,it started last fall and now nothing.
sounds like a fuel issue the carb has a diaphram after sitting for so long it is probably gummed also check fuel filter and fuel line inside tank
Apr 15, 2010 | Garden
Rototiller will not start
paul i assuming you mean the motor stopped running,not the tiller part........? you say the motor turns over easy,suggesting that the motor hung a valve open and you have no compression in the motor.i'm hoping that you checked the oil level before you started and ran the engine. oil level is at the second thead down from the top of oil fill hole. if it was any lower the that you could have ran the motor low of oil causing one of the valves to stick. never had much luck on cleaning the valve stem or valve guide in the head,usualy you need to replace the head assy. they do come as a unit but they are pricey. take the valve cover off and see if both valves will push down into the cylinder. also see if one or the other valves are lower then the other. if you need more help i'll be glad to help you out as much as possible.......
Mar 11, 2009 | Husqvarna 26" Front Tine Tiller
Roto tiller stopped working
i bought three rototillers an every one stopped working after one use an i took it to a dealer an he said it was the coil . why is your coils going bad ?now it wont start needs a new coil agiian i think you should be responsible seeing i bought three it was under warranty but i didnt get it out in time .i like it when it works but if it s gonna do this i wont buy any more of your tools my emalis dugie54 frontiernrt .net i would **** to hear from you ty bob .
Sep 02, 2008 | Garden
Troy bilt Super Bronco Tiller 208cc Logo
165 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
