Question about EdgeStar CWR361FD - 36 Bottle Built-In Dual Zone French Door Wine Cooler - Black/Stainless Steel
Thermostat resets to 44
The right side cooler thermostat is set a 55 - after 7 to 14 days, the thermostat changes the setting to 44. This is a constant and repeating issue occurring every 7 to 14 days. The board was replaced last October and the problem continues @ 4 months later, the same period of time the first failure occurred after purchase. The company refuses to repair because warranty period is over, even though the problem is the same that occurred during warranty period - Any help?
  • Peter Demas
    Peter Demas Apr 02, 2014
    The right side temperature set point changes on its own to 44 degree after a period of 7 to 14 days of operation. Upon resetting the set point to the desired 55, the unit will again change the set point after 7 to 14 days to 44 degrees.
How can I disable the programmable function and just use as a conventional thermostat
5. Temperature Adjustment
Extended Hold (Vacation) Mode
1. Press the HOLD button to bypass the program schedule. The current set point temperature will be held either permanently or for 24 hours, depending on the setting selection made in section 4.
2q==
2. Press the
HOLD button again to return the thermostat to the normal program operation.
3. The hold period will last until the hold is released as in step number 2 above, or is limited to 24 ours if the default was changed in the User Options Settings (see section 4).
4.Programming User Settings
Setting the Extended Hold Time (see also section 6)
The default setting is Long (indefinite) Hold. If the HOLD feature is activated, the current set point will be held until HOLD is released.
1. In normal operating mode, press and hold the
RETURN button for 4 seconds. Press RETURN again to skip past differential setting. The display will show "HOLD LG", where LG is indefinite hold.
z
2. Press the or button to change the Extended Hold time from indefinite (LG) to 24 hours (SH).
3. Press the
RETURN button again to set the Filter Check Monitor or wait 30 seconds for the thermostat to return to the normal mode.
6.Additional Operation Features
Resetting the Thermostat
The Reset feature allows the user to completely reset the thermostat to register new manual switch settings.
1. To erase all entered programs, current time of day, day of week and other user settings, gently press the
RESET button using a paper clip or a small pencil tip.
2. This will return all thermostat settings to their default values and register all new manual switch settings for proper operation (incl.
Extended Hold = Indefinite).
Dec 28, 2014 | Proselect PSTS21P52 Programmable 2 Stage...
Need to clear programmable settings
1. To erase all entered programs, current time of day, day of week and other user settings, gently press the RESET button using a paper clip or a small pencil tip.
denbrcvrefwaaaaasuvork5cyii=
Nov 11, 2013 | Proselect PSTS21P52 Programmable 2 Stage...
Beverage-air DW freezes
Try turning thermostat knob all the way to left or counter clockwise. This should shut the compressor off. If the compressor continues to run the thermostat is stuck closed & bad. If the compressor remains off with thermostat turned all the way to the left try turning it slightly to the right (warmest setting). See if it stops freezing. If it continues to freeze set at warmest setting replace the thermostat. Try pricing a thermostat out at Refrigeration Hardware. Link attached. Refrigeration Hardware Supply
Oct 05, 2013 | Beverage Air Refrigeration Deep Well...
Unit will not stay cool. Is it a thermostat, compressor?
Small refrigeration units like this one like to fail to cool by developing a small leak and slowly
leaking refrigerant.
THERMOSTAT FAILURE CHECK:
A technician will check the thermostat using using a DMM (digital multimeter). But you can suspect the thermostat if you set the thermostat high and the compressor motor does not run,
then set thermostat low, and the compressor motor also doesn't run - in other words, the thermostat is failing to start the refrigerator's refrigeration system no matter what its setting - an obvious failure of the thermostat.
COMPRESSOR FAILURE CHECK:
If the compressor is dying, you would hear the compressor running almost constantly, but not
sounding quite right (uneven noise, clunking, tapping).
REFRIGERANT LEAK CHECK:
If you unit is low on refrigerant (due to a leak), the compressor motor will be running
almost constantly, but it will sound Ok.
Mar 24, 2011 | Danby DWC513BLS Wine Cooler
It is not holding temp. its range is 30 to 49 degrees in one hour
As a refrigerator, it should not go below about 34 degrees. If it is going down to 30, it may be freezing up on the coil. If you get a chance, do this: unplug the refrigerator and let it sit for 4 hours with the door open. If the coil is frozen it will defrost. You can feel the coils inside the box at the top back inside the unit. If you feel ice at any time it is an indication that it is getting too cold. Once the inside coils freeze over, the air can't flow through the coils and the unit will get warmer and warmer. When it is defrosted, set the thermostat just above the off setting. Let it run until the compressor shuts off. See what the temperature reads on a thermometer inside the cooler. If it is not cool enough move the thermostat one number colder and let it run an hour. Take your time, let it equalize before you change the thermostat. Also if the cooler is empty it is hard to set the thermostat because when you open the door all the cold air escapes and the temp will change rapidly. If it is full of cold food, opening the door won't change the temperature very quickly. Also check the radiator coils at the bottom of the cooler behind the grill. If it is clogged with dust or grease, the compressor may overheat and shut off prematurely.
Sep 21, 2010 | True T-49 Side by Side Refrigerator...
Temperature setting is wrong. Stove is about 80 deggrees cooler than what the knob is set at. I am a yooper too.
If you think it is too cool, adjust the thermostat to make it hotter.
To Adjust the Thermostat:
1. Put the Oven Set knob in the OFF position.
2. Press and hold the HOUR INCREASE and the HOUR DECREASE pads at the same time for 5 seconds until the display changes.
3. Immediately, before display changes back, press the HOUR INCREASE or DECREASE pads to increase or decrease the temperature in 5 degree increments.The oven temperature can be increased up to 35°F.hotter or decreased 35°F. cooler.
If the oven adjustment is set cooler than the factory setting a minus sign “–” and the new temperature will appear in the display.
4. Wait several seconds for the control to automatically set and return to its previous setting.
NOTE: This adjustment will not affect the broiling or the self-cleaning temperatures. The adjustment will be retained in memory after a power failure.
To Adjust the Temperature on Models with Only an Oven Set Knob
1. Put the knob in the OFF position.
2. Pull the knob off by pulling straight out.
3. Press and hold the HOTTER or COOLER button for 5 seconds to make the oven 20°F. hotter or 20°F. cooler.
When you are adjusting the thermostat, the following lights will flash indicating where the thermostat will be set when you release the
adjustment button:
OVEN ON indicates the thermostat will be set at the factory setting.
PREHEATED indicates the thermostat will be set 20°F. hotter.
CLEAN indicates the thermostat will be set 20°F. cooler.
4. After you have made the adjustment, replace the knob.
If you have any doubt please go through the manual which is given here
http://kitchen.manualsonline.com/manuals/mfg/hotpoint/rgb745.html
Hope this will help you
Thank you
Oct 02, 2009 | Hotpoint RGB745 Gas Kitchen Range
Beer cooler keeps freezing
Could be but sounds like it may be low on gas. What emp do you set it at. Should be about 35 degrees if you have it set to low it will ice up on you. Russ
Jul 21, 2009 | Beverage-Air DW49 Stainless Steel Beverage...
Haier wine cooler freezes the wine.
You may find that the thermostat is not working. Try to turn the thermostat to the warmest setting, the compressor should switch off within two hours, if not change the thermostat.
Mar 09, 2009 | Haier BC112G Wine Cooler
Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Jan 20, 2008 | Haier BC112G Wine Cooler
EdgeStar CWR361FD - 36 Bottle Built-In Dual Zone French Door Wine Cooler - Black/Stainless Steel Logo
37 people viewed this question
Top EdgeStar Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an EdgeStar Furniture Expert? Answer questions, earn points and help others
