Question about InFocus Office Equipment & Supplies
I have a IN2102 with a fresh bulb or the old bulb and it looks like bubbles or snow showing on the screen. Replacing the bulb did not change the output showing, Tried compressed air also, did not change the display.
    Problem Solver:
  • 20 Answers
DMD or DLP chip has died. Can be replaced by user if you have electronics experience equivalent to building or servicing desktop computers. Just replaced mine this week, actually. Good as new now. The part or chip number is on the chip itself. Once you have that number, you can usually find replacements on eBay for roughly $200. Kinda pricey, but way less than a new unit. I looked at some forums but found no listed DMD chip numbers for your projector:(. Hope this helps!!!!
Posted on Mar 31, 2014
  • JR Dutton Mar 31, 2014
    DLP or DMD chip is bad. Part is about $150-$200 on eBay. Have to remove the old one to get part # unless a Google search of your projector model turns it up. User serviceable if you have about the same electronics skills it takes to build/service a desktop computer.
2 Suggested Answers
  • 9 Answers
SOURCE: overheating
Set the lamp to economy mode, make sure it is being used in a cool room with easy air flow thru the projector. If the problem persists, there are two fans inside and a thermistor that takes the temp reading, there is small adjustment POT on the board to increase the operating temp if needed.
Posted on Jan 22, 2008
Snow thrower not starting
Two ways to find out:
1.
2.elctric
start with elctric, take the plug cable out and see if have
https://www.youtube.com/watch?v=mUOmsGiirTU
if you have spark go to fuel :
change the old fuel to a fresh one.
https://www.youtube.com/watch?v=RfzzTilqwo0
Dec 13, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
I am getting small white dots on the screen and they are increasing in number
sounds like pixel failure. The DMD chip needs replacing. Get a quote from the infocus agent to make the repair before you decide if it's worth it.
Aug 19, 2011 | InFocus In2102 Projector
When i put a new bulb in my projector panasonic ptae1000 its shows green how do i fix this
A new bulb may just be showing up a problem that wasn't apparent with the lower brightness coming from an old bulb.
Try putting the old bulb back in and look very carefully and see if the problem is still there.
If the green is uniform over the whole screen then it may be fixed by setting a colour level change in the menu.
If it varies over the screen then it is probably a polarizer affected by age and heating.
Jul 14, 2011 | Panasonic PT-AE1000U LCD Projector
How can i fix static on my maxent lcd tv
26 inch maxent mx-26x3 and 32 inch, l2614xw02 some same parts
When i hear the word static, i think snow,
If while your watching tv and it looks like color snow pixels popping in and out all over the picture i did this to fix it.
look at main board you see a green heat sink,
left of that heat sink you see a 220 uf 16 volt capacitor that half surround by 22 uf capacitors,
change the 220 uf capacitor and snow is gone.
to get it off i just wiggle slowly back in forth until the old capacitor falls off,
then put some fresh solder on and new capacitor on and done.
use a radial electrolytic capacitor not the little metal one they had on
tc
bagabillion
Jul 11, 2011 | Maxent MX-26X3 Television
I just bought a infocus in2102 projector but when i turn it on nothing comes up on the screen
check if any of the lights on the top come on (lamp light) and that the power light is green.
it may be a defective lamp that infocus should replace
Feb 08, 2011 | InFocus In2102 Projector
I have a Husqvarna 455 about 2 years old. At about 1 year point it would no longer start using the primer pump button on the side when cold. If I take off the air cleaner and give it a a shot of gas down...
Your seeing the problem. Air in the fuel lines usually caused by a cracked fuel line or a pin hole in the primer bulb. Until you can stop the air bubbles by either replacing the actual primer bulb or fuel lines your always going to have the hard to start problem. This can also cause the engine to run lean at high RPM settings and eventually burn a hole in the piston. You should repair the fuel problem ASAP. If you do not find any fuel line / primer bulb problems then it is time to start looking at the carb diaphram.
Thanks for choosing FixYa,
Kelly
Oct 08, 2010 | Husqvarna Chain Saw 20" Bar
What does a lamp bulb look like when it is no longer good or working? does it look burnt out? Mine looks like nothing it broken or burnt, but my projector isn't showing a picture on the screen. the fan...
look at the lamp head on. an obviously bad lamp will have cracks in the mirror, the stem can have frosty,veiny looking blisters or bubbles, the mirror can have lots of bubbles. And sometimes there are just no obvious signs.
Jun 14, 2010 | InFocus LS 110 Multimedia Projector
I have a sony projector ceiling mounted, the image is projected
go into the menu and the image settings. there is a selection for front, rear, ceiling front, and ceiling rear. it might be sent to ceiling rear, so change it to ceiling front.
Dec 15, 2009 | InFocus In2102 Projector
A brief history: fixya helped me change my bulb (been receiving a "replace bulb" message for awhile until my picture went black). The picture now is snow, not black which seems to me to indicate the bulb...
Since you do have sound but snow for picture is your TV 54J or 54U chassis the PT50DL54J chassis shows 4 tuners also Have you look for Leaky or Bad capacitors if they are puffed up on top they are Bad 2200uf 25v 1000uf 25v Look for bad capacitors on tuner Boards, and I have seen where they are on Power supply board that will affect Picture.
Dec 04, 2009 | Panasonic PT-50DL54 50" Rear Projection...
How do I change the light in my fresh air purifier
The light bulb is a tube style that clips in - - kind of like replacing a flourescent light bulb T-8, T-10 style. Try rotating it so that the end pins align themselves properly for removal. Simple !!
Oct 08, 2009 | Ecoquest Fresh Air Air Purifier
85 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
