Question about Microsoft Office Word 2007 Home and Student Full Version Non-commercial License for PC (DHMSCD16515WI)
1994 chevy rear license plate light out after new bulb
Replaced light still not working
    Problem Solver:
  • 19 Answers
Just because light was new, does not guarantee it's works, check builb with battery. Just place a live wire from + side and earth out bulb against car body work. If light working, you have a wiring fault. Give it a light pull and see if located correctly. Good luck
Posted on Mar 31, 2014
I have a 09 chevy impala. My license plate light stopped working
if all the other rear tail lights are working
it will be the number plate bulb holder ..earth and power issue
or bulb
Jun 30, 2016 | Cars & Trucks
Plate light does not work, but lights are good and sockets seem good
check bulb the number plate light runs on the same circuit as the side lights so if they are working its got to be a bad earth on the plate light
Jan 24, 2016 | Cars & Trucks
2007 chevy equinox license plate light won't work after bulb and fuse replacement
Do the park lamps work ? license plate lights get power from same fuse ! Check ground wire ! use a volt meter an do voltage drop test ! Voltage Drop Testing The fuse for the license plate lights is in the under hood fuse box -engine compartment ! fuse #12 RT PRK LAMP 10Amp .
May 23, 2015 | 2007 Chevrolet Chevrolet Equinox LT
My 1994 3000gt has no rear license plate light
run a wire from the tail lights to the plate light . if this works the wire to the plate light is broken , if not replace the light socket
Feb 26, 2014 | Mitsubishi 3000GT Cars & Trucks
My 2005 chevy tahoe 5.3 license plate light went out i replaced bulbs problem still there what is the fuse labeled for that circuit?
Check the brake bulb socket for short , clean replace bulbs , check connector to rear licence plate lights . Also trailer harness for short , all on same fuse circuit .
Jan 23, 2013 | 2000 Chevrolet Blazer
Tag light is not working. is there a fuse that will get the light turned back on?
The fuse labeled REAR PARK LP 15A in the right instrument panel fuse box powers the rear park lamps, and the tag lamps. If your rear park lamps are working then you most likely need to replace the tag lamps (bulbs). Use the following procedure to replace the lamps.
To Remove:
  1. Remove the two mounting screws from the license plate lamp.
  2. Remove the license plate lamp from the rear bumper fascia.
  3. Remove the license plate lamp socket by turning it counterclockwise.
To Install:
  1. Install the license plate lamp socket by turning it clockwise.
  2. Position the license plate lamp to the rear bumper fascia.
  3. Install the license plate lamp mounting screws.
Feb 17, 2011 | 2004 Chevrolet Impala
How do you change the rear license plate light bulbs???
First look under when your license plate lights are and you will see 2 phllips headed screws remove those screws and the license plate light assembly will drop out of the bottom of the trunk, simply twist the blub to unlock it from the light housing pull the bulb straight out of the socket replace it with a new bulb and the installation is the reverse of the removal.
Dec 06, 2010 | 2002 Jeep Grand Cherokee
1999 Dodge Neon rear license Plate bulb
LICENSE PLATE LAMP BULB
REMOVAL
  1. Remove screws attaching license plate lamp to rear bumper
  2. Remove lamp from bumper.
  3. Remove bulb socket from lamp.
  4. Pull bulb from socket.
INSTALLATION
  1. Install bulb into socket.
  2. Install bulb socket into lamp.
  3. Place lamp in position.
  4. Install screws attaching license plate lamp to rear bumper.
Oct 08, 2009 | 1999 Dodge Neon
Replacing license plate lights on Chevy Trailblazer
I just had the same problem. I took the cover off, saw the white bulb base, twisted it to take it out, but it popped back inside the door. I got it out, but it wouldn't pull through, so I twisted it back in place and went to Autozone to get new bulb. Once I saw the new bulb, it was obvious, just the bulb itself pulls out. There's so little room to work, I couldn't get it with just my fingers - - maybe rubber gloves would have worked, but I used pliers, lightly, wiggled it a little and it popped right out. I had a similar issue once with the taillight bulb and had to break the bulb and then grip the remaining filament wires with pliers to get it out, so that was my backup plan, just in case.
Hope this helps others.
Apr 14, 2009 | 2002 Chevrolet TrailBlazer
Rear lights don't work nor license plate light
Start with checking or replacing the bulbs, if you had an electrical problem, nothing would be lighting up in the back.
Let me know, Pierre ( Montreal)
Jan 02, 2009 | 1994 Oldsmobile Achieva Special Edition
Microsoft Office Word 2007 Home and Student Full Version Non-commercial License for PC (DHMSCD16515WI) Logo
27 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
