Door on S163
The bag door came off and I can't get it back on.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Check for lose screw on the door..and reinstall them. contact the local repair shop.
Posted on Mar 31, 2014
Electrolux 2100 vacuum
Electrolux has had this issue across all tank machines for years and it has to do with the orientation of the bag. The bags are model specific and must be installed properly. Consult your manual for the proper filter bags and how to install them. The door on the bag will pop open and shut down the machine if the bags are not the proper ones and don't fit precisely. It is supposed to be a safety feature but it annoys the devil out of people and has for years. Their machines are very powerful and well made, but if the bag does not seal properly around the hose inlet or the gasket around the door and bag chamber leak, then you will have this happen.
Nov 20, 2017 | Vacuums
How to change bag
Open the bag door, slide the bag out of the bag holder, slide the new bag in and close the door.
Sep 11, 2013 | Riccar Moonlight/Sunburst Hepa Vacuum Bags
Shredder keeps stopping and the bag is not full
there are three switches on most shredders that can cause them to stop.
1) a jam
2) door ajar
3) bag full
If you can rule out a jam, and the door ajar light goes on when the door is open and off when its closed, and the shredder has not been undergoing very heavy use (they will overheat and shut off, then be fine in 15 min or so)
then its a safe bet to say that it has to do with the switch that tells the shredder that the bag is full (when you take out the bag you can see a metal flap hanging down at the back of the top opening)
the way that the shreddings fall can often trip the swtich that tells the shredder that the bag is full, shake the bag a bit so the paper resettles that often fixes it.
Nov 08, 2011 | Fellowes Office Equipment & Supplies
How do I remove door interior to access the door lock mecanism ? on both door !
You will need a Torx head screwdriver.
First, disconnect the battery and leave it disconnected for several minutes because you don't want to lose a finger in the window mechanism or have the air bag blow up in your face.
Next, starting from the rear, carefully pry up the trim strip that runs from the door latch back to the back of the door. It is usually wood-grain finish, but may be aluminum or carbon fiber, depending on your interior package. Remove the screws beneath that trim.
Pop out the two oval plugs from the underside of the door handle, and remove the two screws beneath those plugs.
Now with something large and flat and preferably with no sharp edges, start snapping the inner door panel off. If you break some snaps, no worries. They are available on line for $0.35 each or at the dealer for about $1 each. The top of the door panel does not hook in the window sill like most cars, it snaps straight out.
Now disconnect the speaker wires, mirror control, and probably the air bag. You can leave the air bag connected if you are willing to work around it.
I presume that your window regulator is broken. Specifically, the piece of plastic that attaches the window mechanism to the cable. You can replace the whole regulator, but on my wife's '04 330i, I chose to put two good quality zip ties around it. One just above the broken piece and one just below it. There are holes and notches in the metal backing plate that work great to hold the zip ties in place. I did this repair a couple of years ago and the window still works just fine. Much quicker and cheaper than replacing the whole regulator.
If you unplug the air bag, DO NOT connect the battery and turn on the key to check your work while the air bag is unplugged. Doing so will set a critical fault in the SRS system that only a dealer or well-equipped BMW repair shop can clear. DAMHIK
Jan 23, 2011 | 2003 BMW 330
Where are screws located that access main motor compartment in panasonic canister MC-V9647? Something is rattling inside and smells hot. Belt or motor?
If the model is the same as pictured, the screws should be visible.
If the model is older like I think it is, the screws are going to be a tad tough to get to, but not impossible.
First you will need to take the bag door off. Open it like you would to change the bag and then push the bag door back farther so that the hinges "pop" out. Generally how i do it is put it on the counter, with the bag facing you, open as far as you can, grab the top portion of the bag door and push it back quickly.
Now, when the bag door is off, with a flat screw driver, the colored housing above the gray bumper will come off. insert the flat screwdriver in there and pry it open a touch. do that to the other side as well. Once both sides are open, you want to slide the screwdriver towards the back of the unit and gently pry the back off.
under there you will find 2 screws (if you need to go that far at this point) and you can remove the back of the unit easily.
Good luck,
Mark
Nov 08, 2010 | Panasonic Kenmore Canister Vacuum Vacuum
My Electrolux Aerus auto rewind chord mechanism is broken. Is there an easy way to remove the back of the canister to replace or fix the spring there?
Take out the bag and keep the door open.
While the bag door is still open, turn the machine upside down so you are looking at the serial number.
Pull the cord out one foot.
Use a puddy knife and put it between the rubber side rails and the **** end of the machine.
Use a hammer or malett to hit the putty knife from the back of the rubber bumber toward the bag door.
Pull the rubber bumber stright out on both sides.
Once both bumpers are out pull the lower body of the canister from the **** end toward the intake of the machine.
Once the bottom is open you can then service the motor, cord winder, switch, and all other components.
For all the parts to fix the machine visit: http://evacuumstore.com/c-69-electrolux-accessories.aspx?manufacturerfilterid=0
Feb 28, 2010 | Electrolux UltraLux 2000 Bagged Canister...
02 330i drivers door airbag deployed, dealer saying it needs a new door panel,I disagree, looks like the panel is fine & can be used after a new air bag is set in. Any advice here?
the door panel needs to be replaced to correctly fix it. I guess you could go and glue the door panel back together. The dealership is going to put the vehicle back into factory condition. Usually when side air bags blow, the way the door panel is meant to tear it would make sense just to glue it back together as long as the leather doesn't tear
May 05, 2009 | 2002 BMW 3 Series
98 Continental please help me>>>>>>>>
if the car is up too high then i would try to locate where the leveling sensor is,im not sure where to look,i havent had to work on a Lincoln in a while
Apr 25, 2009 | 1998 Lincoln Continental
Windsor sensor says bag is full when its not
Are you vacuuming up fine particals like pet dander or just large amounts of regular dust? Also when was the last time you replaced your filters?
Just some sugestions.
Mar 17, 2009 | Windsor SR12 Sensor Bagged Upright Vacuum
Hi, Fitted new paper bag to this cleaner but have 'No' suction. With bag removed no air movement can be felt at outlet(ie bag entry). Have you any suggestions?. Many thanks, John Pessall.
What kind of model is it?
If you have the bag door open just to feel if there is suction it won't work. The machine would have to have its door put back on before suction can be ascertained. In the meantime check the hose that leads into the bag, or main dust channel - it may well be clogged as well as motor filters usually located under the paper bag.
Mar 02, 2009 | Vacuums
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
