Question about Coby 40 TFTV4028 LCD TV
Wont power on after being turned off
Whe you first plug it in it will come on. if you turn the set off it wont power back on
    Top Expert:
  • Coby Master
  • 74,377 Answers
Main power supply regulator board fault. Contact any service technician. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Electro help Pull up older posts.
Posted on Mar 31, 2014
How do I get the promo display off my screen on a Samsung PDP TV series 4+ 600hz
For this model, you will need to reset the TV and go through the first time set up again. To do this, use the remote when the TV is turned off and push mute, 1, 8, 2, power in that order. The service menu will come up. Select options, then factory reset. The set will then power off. Turn the set back on and go through the first time set up, making sure you pick home and not store. Hope this helps.
Apr 09, 2016 | Samsung Televison & Video
I just installed a new fuel pump whe whole module hooked it all back up and the car wont start check all fuses and relays car turns over but pump does not run but it still register
Did you check to see if the pump is getting power from the relay when you turn the key on ?
It can take several minutes to build up fuel pressure and expell air in the line after replacement.
Oct 10, 2015 | Cars & Trucks
My monitor hp w2207 works, but a few minutes later the screen is turnning off, whe I press the power switch off and on the screen returns, back and forward the monitor does
Sounds like the power converter to the LCD. Need to get it repaired or buy a new monitor (which will most likely be cheaper). If this monitor has a "brick" between the plug and monitor, that may be the culprit as well. Those are probably pretty inexpensive.
Sep 02, 2014 | HP Computers & Internet
PS3 shows a blank screen when I use the RCA jacks but works well when watching DVD movies when using a HDMI cable. When using the HDMI cable the sound is distorted whe I insert a game disk
Well heres the problem when you set your ps3 to be on 1080p using a hdmi cable the rca jacks wont work. to reset it power down the console. Then hold your finger on the power button you will hear it beep twice i believe rca jacks should be working now you will have to do that everytime unless you change it with hdmi cable plugged in to where you can see.
Jun 06, 2011 | Sony Playstation 3 (PS3) Console
I have a Gateway solo 9550 laptop. When I turn it on it says ERROR Invalid system configuration data- run configuration utility. What exactly is wrong? Windows boots up when I press f1. How do I stop this...
You usually gets this message when you leave the system unplugged for a long period of time. Whe the internal battery drained out the system loses the configuration data. Normally the internal battery will get recharged when you plug the power back. Just have to go into the BIOS and set the date back to the current date. In some case the internal battery needs to be replaced if no longer holds a charge.
Dec 18, 2010 | Gateway Computers & Internet
I set the date and time then turn of the camrea then whe i turn it back on i have to set it again cannon 75
Please try to press the OK/Set button after setting the date & time. Probably you are not doing the same
May 19, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Wont turn on
your power supply is faulty or if youve set your comp to hibernate and it loses power it battles to turn back on . If so turn off at wall socket and watch battery light on the mother board , when it switches off turn plug back on.
Jan 18, 2008 | Computers & Internet
Coby 40 TFTV4028 LCD TV Logo
57 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
