Question about Garden
Throttle linkage parted replace
The throttle linkage parted whilst cleaning, where do they link to
    Guru:
  • 145 Answers
Whats the make and model? whilst? LOL you lost it right?
Posted on Apr 13, 2014
2 Suggested Answers
  • 4088 Answers
SOURCE: Throttle linkage
It seems that Mac engineers could have come up with something better than the M.M. kluge that they did. The problem is hooking the wire link to the plastic hook on the trigger plastic casting while juggling the front case and engine body. It appears that it should just snap together, but knowing how plastics get with age, it would appear that the trigger should be replaced every time the case comes off. I had trouble with mine and wound up straightening out the wire link end somewhat to force the parts together--it continues to work though. Hope this helps!
Posted on May 06, 2010
How to replace throttle cable on mcc1635a chainsaw
http://www.mcculloch.com/ddoc/MCCI/MCCI2008_USen/MCCI2008_USen_MCC1635A-9096311037_966001701.pdf
This link gives a breakdown of the Chainsaw. The trigger is mounted internal, and has a linkage to the throttle plate on the carb.
Determine which part if any need replaced and turn saw on its side, then remove the screws and lift one side off. replace the broken parts and reinstall cover.
Sep 12, 2017 | Garden
I have a Robin eh 34 engine in a Simpson power washer. The engine starts and runs but wont rev much past a fast idle. Carb has been cleaned thoroughly. gas is fresh. Suggestions
Butch if carb was good and clean and linkages were re installed properly including governor, it is possible the throttle tab/lever (what linkage hooks to) is loose on the shaft that opens the throttle butter fly. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DIY Tecumseh Snowblower Carburetor Throttle Shaft Lever Repair PART 1
Apr 13, 2016 | Simpson PS2600 PowerShot Commercial-Duty...
Throttle going wide open in 1st gear and staying there for about 5 sec
sound like throttle cable could be binding the cable clip broken or missing or throttle body linkage and plate has carbon build up.throttle body need taken off remove all plastic parts and rubber parts remove all electrical parts like idle air control valve and remove tps sensor the carburetor cleaner will destroy.clean throttle plate and throttle shift linkages spray clean real good remove all carbon build up.
Jun 21, 2013 | 1995 Toyota Camry
My 93 ford f-150 is stuck in high idle!
IAC or Idle Air Controller. Thatd be the place to start.
Oct 31, 2012 | Ford Cars & Trucks
I have a 1989 ford bronco full size. my throttle cable is sticking open a bit and in order to get it to rev down i have to pop the hood and push it back with my finger. how do i fix that?
probably is not the cable and more likely the throttle that is biding on you
disconnect the throttle cable from the throttle body and try increasing the engine speed with the linkage on the throttle body
if you find the engine is still running fast then your concern is in the throttle body. Clean the inside with a soft, link free rag and some good soap and water...avoid brake cleaner at all costs!
if when controlling the throttle with the cable disconnected and the engine does NOT race, then your concern is in the cable and you'll have to replace it ASAP
Apr 04, 2010 | 1989 Ford Bronco
Gas pedal sticks
does it stick in the cab or on the throttle body? make sure the cable is wrapped around the throttle linkage properly first and then id spray some wd40 on all the moving parts down by the pedal. sometimes gunk can get built up in that area and it just might need a good cleaning. odds are pretty good that the moving parts are really dirty or the cable isnt lined up properly on the throttle linkage. id start there.
Mar 28, 2010 | 1999 Chevrolet Silverado 1500
Poulan Lawntractor 13.5HP throttle linkage missing
The easiest thing for you to do is look at another mower that has a single cylinder Briggs at how the linkage is set up. They will all be the same linkage from 12 hp- 20 hp.
Jul 03, 2009 | Oregon Scientific Oregon Fusion Blade For...
Stop safely now light and Hybrid component failure
There is a technical service bulletin that may apply to your problem the no. is 09-8-9
ISSUE: Some 2005-2009 Escape Hybrid and 2006-2009 Mariner Hybrid vehicles may exhibit an intermittent Red Triangle On and Stop Safely Now message displayed on the message center accompanied by a sudden RPM loss/no start symptom with a diagnostic trouble code (DTC) P1A0C. Vehicles may exhibit this symptom on the first start of the morning or after an extended idle. The symptom will clear on the next key cycle.
ACTION: Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE For vehicles outside the new vehicle limited warranty, if diagnostics lead to replacing the throttle body you may use this procedure to clean the throttle body as an alternative to replacing it. This procedure is not covered by the new vehicle limited warranty. NOTE: THIS CLEANING PROCEDURE CAN ONLY BE USED ON NON-COATED THROTTLE BODIES. Refer to Workshop Manual, Section 303-04C Removal and Installation - Throttle Body.
  1. Remove the throttle body.
  2. With the throttle body positioned to the side, open the throttle plate.
  3. Using Motorcraft® Choke and Linkage Cleaner or equivalent, spray the throttle body plate and bore.
  4. Using a suitable (nylon) brush, clean the edges of the throttle plate and the mating surface of the throttle bore to remove all carbon build up.
  5. Reapply Motorcraft® Choke and Linkage Cleaner or equivalent and wipe clean with a lint-free cloth.
  6. Remove old throttle body gasket and discard. Install a new throttle body gasket.
  7. Install the throttle body.
PART NUMBER PART NAME PM-14 Motorcraft® Choke and Linkage Cleaner
Apr 18, 2009 | Mercury Mariner Hybrid Cars & Trucks
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
