Question about Pool & Spa
LED Light Malfunction
I recently purchased a used 2006 Cal Spa 6100. I'm having an issue with the LED lights. They operate perfectly if I'm only running one pump on low speed and the secondary pump. When I turn the jets on as well, about 2/3 of the lights go off. Any suggestions?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,448 Answers
Loose wires
Posted on Jul 12, 2014
Recent purchase of 1999 sprint st having all sorts of issues with headlight not working or coming on but not staying on then no light at all has led lights fitted
probably find that the led lights were fitted in a back yard and attention to current required to run relays and light control modules was not carried out properly
talk with an auto electrical shop to find out all that is required to fit LED lights to a vehicle that did not have them fitted as standard
Nov 24, 2016 | Cars & Trucks
This sounds like a transformer is going out possibly. You are losing power in the system.
I would have an electrician check the system before moving forward.
US Parts Center
Mar 31, 2014 | Pool & Spa
Cal spa led lights
not enough power, are you running all the lights from the same power source, if you are find another circuit to hook the other set to.
Mar 31, 2014 | Radio Communications
No LED light?
check voltage from wall then transformer voltage
Apr 24, 2012 | Pentair Control Board - 42002-0007s
I have recently purchased a preowned escape and today my abs light came on and is staying on, can you tell me what is wrong with it as I have a 2 year extended warranty on the suv
It is an OBD2 Emission System Malfunction,
as are all lights that you get on the dash
You have a possible ABS Braking System Failure
Mar 03, 2011 | 2006 Ford Escape
Colorlogic Pool Light flashes like strobe
These swimming pool lights have a power-cycled feature. THis means that you can power down the light and then power back up in 10 seconds and the light pattern will change. It sounds like your light is not cycling properly. Power it down for a full 60 seconds. This will reset the power cycle. Then try turning it on and off in 10 second intervals. If it doesn't reset, you bulb may only be partially functioning and it may need to be replaces.
Jul 06, 2009 | Hayward 12v LED Color Logic Pool Light...
Blinking light on Westell 6100 DSL modem
Blinking light means that firmware on your DSL modem just got updated. The modem is pinging the Networ/Computer connected to it. If you open your Modem Page 192.168.1.1 you will see the difference, unless you never have done it before.
Jan 25, 2009 | Westell Wirespeed LiteLine 6100...
Malfunction indicator lamp
The Malfunction Indicator Lamp or MIL (Also called the check engine light or service engine soon light) comes on when the on board computer detects an issue with the operation of the engine or transmission.
The best thing to do is to take the vehicle to an auto parts store like Autozone and have them hook up their scan tool to the vehicle and read the code. They can read it, tell you what it is and also tell you what the code means.
If it is pointing to a faulty component or sensor and you replace or repair the component the the light will go off on its own after the computer sees that the malfunction is no longer present.
You can have the code cleared, but if whatever caused the light to come on in the first place is not addressed then it will just come back on eventually.
Dec 31, 2008 | 2006 Toyota Tacoma
Pool & Spa Logo
73 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
