Question about Jenn-Air Kitchen Ranges
Electric start model JDR8895BCS13
Sears model 1150 snow thrower how repairing the electric connecter for sears model 1150 snow thrower
It's just a simple AC pronged piece. You can buy the actual piece from Sears OR you can buy an Electric Line-cord and wire it into teh plastic box where the Push button 'Start ' switch is.
Mar 01, 2015 | Garden
How do I troubleshoot the key electric start system?
using a five dollar test light (from any auto store) walk thru each device(in/out) along the path of each electric device on mower starting with the battery ,till you arrive at the electric starter , if power gets that far and it wont start, starter is defective
Oct 10, 2014 | Husqvarna XT722FE-CA 22-Inch 173cc Kohler...
Why will my toro 5198 leaf blower not start?
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Jun 28, 2014 | Toro 51599 Electric Blower 12 Amp
Electric motor make, lamco, model no.EC34-1(93) reversing 120v 16.5amps
Here are electric motor links that might help.
Or not.
http://waterheatertimer.org/Color-codewire.html#motor
You have to test the windings with multimeter to identify start winding, vrs run winding.
Both windings receive power at same time.
The start winding is like first gear on a car. It starts the motor rotation.
The run winding brings motor up to rated speed.
Sometimes categories at Fixya are muddied, and people do not say which product they have, or give UL number instead of product number, and sometimes fixya questions are truncated onscreen ... so person answering question thinks the product is a gasoline powered bobcat, instead of hybrid car, or 120Volt single-phase electric motor.
Nov 25, 2012 | Hardware & Accessories
I have a RYOBI E530 Touch Start Push Button weed wacker. Model RY29550. I took it in for repair since the cord wouldn't recoil back in and was told to just use the batter/electric start. I do not...
Most Ryobi manuals are available on their site: http://www.ryobitools.com/discontinued_manuals/ . The direct link to the RY29550 manual is: http://www.ryobitools.com/product_promotion/discontinued_manuals/string_trimmers/RY29550_310_trilingual.pdf .
Are you sure of the model number? The RY29550 lists electric start with 12V battery for all models, no pull cord. It takes battery pack 130269012 and charger 140295003. This site has parts for the RY29550: http://www.ereplacementparts.com/ryobi-ry29550-string-trimmer-parts-c-7931_15633_15647.html .
I hope this helps.
Jul 10, 2011 | Garden
Dryer won't start. It's electric. Model #LE5200XTWO
It sounds like the motor is getting weak. A motor for that unit is part # 279827 and runs around $110.00
Apr 24, 2010 | Dryers
Dryer will not start when button pressed. Several times yesterday it did start but stopped few minutes later.Kenmore brand. Model 11062812101. Serial MM1310180. Thank you
is it a gas or electric model, if gas the ignitor,flame sensor,control board,if its electric,element,hi-limit,thermistor switch, control board, lack of correct input voltage,bad motor start capacitor on either model
Nov 01, 2009 | Dryers
Start Button Failed on Whirlpool Electric Range Model GY396LXPQ02
It sounds like you have an oven problem rather than a start button problem. Is there an error code? If so list your model and error code on a search engine and you will find error codes. Or you can just list make model number and error codes and you can find a chart of Whirlpool error codes. I have done this with no problem. That should tell you the exact problem and things to try.
It may be neither issue you mentioned. It could be a bad element or a short.
May 29, 2009 | Whirlpool GY396 Electric Kitchen Range
ELECTRIC DRYER WILL NOT HEAT
Can you verify model number, it usually starts with WE
Jan 21, 2009 | Whirlpool LER5636P Electric Dryer
Don't know if my dryer is gas or electric
the E in the model # means it is electric. It would start with LGR if it was gas.
Nov 20, 2008 | Whirlpool Dryers
Kitchen Ranges Logo
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
