Question about Pelonis Heating & Cooling
On/off swith knob broken
Roating control knob broke
    Problem Solver:
  • 14 Answers
Check out my solution for a broken knob at this link:
http://www.fixya.com/support/t2513159-plastic_knobs_off_fan_speed_broken_need
Posted on Jul 24, 2014
    Problem Solver:
  • 6 Answers
Is it the actual knob that is broken or the little tab the knob holds onto that is broken. You either need a replacement knob or a replacement switch assuming the know is also the thermostat for the unit. Does that same knob control the fan speed? Temprature or timer?
Posted on Jun 30, 2014
Can't open safe, locking mechanisim broken
wont hurt to ring the safe maker or a locksmith
for a second opinion
Mar 29, 2017 | Home Security
I have a u2-1887. the speed control knob has broken off. i need a new speed control switch and knob
SAME THING HAPPENED TO MINE...THE SWITCH BROKE APART IN PIECES...WHERE CAN YOU GET ANOTHER SWITCH?
Oct 12, 2010 | Patton U2-1887HO Floor / Box Fan
The washer control knob came off in my hand..how to reattach?The white sharp things behind the knob..some are broken? Can I glue it? With what kind of glue or are there replacement parts?
Most likely the knob itself just broke. You would do better to replace the knob than glue it because if you glued it and ever had to replace the timer then you might cause more damage getting the knob back off.
Nov 19, 2009 | Whirlpool LTE6234D Top Load Stacked...
Control knob hangs
Timer has small gear pull panel off and see if gears are stripped in one spot meaning no teeth on the gears
Aug 24, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Broken control knob
go to a used appliance store, they have tons of those things!
Jul 24, 2009 | Fahrenheat Built-In Baseboard Thermostat...
Knob broke off my A/C with the peg inside!
Simple you either replace the knob assembly or use araldite and fix off the broken knob. It is only a temporary remedy and for a permanent solution please replace the knob assembly and get rid off this problem
Jul 14, 2009 | Heating & Cooling
Broken knob
You can take it off, but unplug first. Does this knob control the heat or turns it on? If it turns it on, this is a contact switch and can be replaced at a fairly low cost and you can do it yourself. Just match wire for wire. It sounds like it has come loose from the frame.
Feb 03, 2009 | Frigidaire FEQ332E Electric Dryer
Volume control broken
You can purchase clear 2-part epoxy products at most home improvement stores. You will also need masking tape (or similar) a popsicle stick (or similar) a small piece of cardboard and a toothpick.
Mix the epoxy with the popsicle stick and apply a small amount to the exposed surface of the volume control's stem. Holding the knob in place, run a strip of tape from the top of the unit, across the knob and to the bottom.
These epoxies are very strong and fast setting. It's probably best to leave the tape for at least 8 hours but you should refer to the instructions for the epoxy you buy.
Good Luck,
BB
Jan 05, 2009 | Yamaha HTR-5830 Receiver
Need orden parts for models #655,657&659
Mode control knob broke. I need replacement.
knob for Hampton bay Model HBLG100. Air diverter was also broken and only have pieces left, any ideas?
Jun 05, 2008 | Heating & Cooling
Broken Knob for fan control
once you take off the front housing, the switch itself shoud be easy to remove and replace...sometimes, a used appliance store/repair office can get a suitable replacement part. Trick is to mark the wires as you remove them from the switch and take hte switch with you while you go part hunting. Also would help to have model and serial number (and brand name) noted to take along. Papdaddy
Sep 22, 2007 | Comfort-Aire CS-101A Air Conditioner
Heating & Cooling Logo
321 people viewed this question
Top Pelonis Heating & Cooling Experts
paulcarew
Mack Baxter
AJMAL KHAN
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
