Question about Panasonic KX-TGA401B Handset
Unable to phone out of ringer off mode.
Second handset will not ring. How do I get ringer on?
  • Official Brand Answer
  • 350 Answers
Please enter the handset's Initial Settings menu and choose "Ringer Settings".
Posted on Apr 03, 2014
5 Suggested Answers
sandyka77
  • 58 Answers
SOURCE: how do I turn the handset ringer on
Please download the manual from the website below.
http://service.us.panasonic.com/OPERMANPDF/KXTG5471.PDF
Posted on May 04, 2009
  • 299 Answers
SOURCE: Ringer
There is a section on setting the number of rings in the manual for the base unit on page 28. You can download it from here: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/Expandable-Systems/model.KX-TG2740S
c:\documents and settings\bruce\application data\pixelmetrics\capturewiz\lastcaptures\2010-04-21_15-45-33-014.pngc:\documents and settings\bruce\application data\pixelmetrics\capturewiz\lastcaptures\2010-04-21_15-45-33-014.png
Posted on Apr 22, 2010
cnavarro
  • 2460 Answers
SOURCE: kx-dt333 phone rings, red light
You can press the softkey under RingOff and the up arrow on the Navigator button, or just press the up arrow on the navigator button two times. The display will show the ringer volume level as you continue to press the up arrow.
Carl
Posted on Oct 26, 2010
  • 225 Answers
SOURCE: Phone (base and both handsets) rings once, then
This is likely caused by a trouble from the service provider. It is caused by a partial short on the phone line. The service provider can usually test the line remotely when you call the trouble in. Occasionally this problem is caused by faulty equipment(phone, answer machine, modem, etc.), bad line cord, bad outlet or bad building wiring. Inside the outside telephone interface box there is a modular test jack that has a short line cord connected. Remove this line cord and connect a standard telephone to test the phone line. Make a call to your number, if the problem occurs with the phone connected to the test jack, then the problem is with the service provider. If the problem does not occur with the phone connected to the test jack then the problem is in the building wiring, outlets, line cords or devices connected. Use a process of elimination to determine where the problem is. Example: disconnect all phones and devices and line cords, make test call with one phone connected, if problem continues inspect outlets and wiring.
Posted on Dec 29, 2010
Testimonial: "Our phone actually started working correctly again, so I think you were correct in saying it was the service provider. Thank you for your help!"
Turning the ringer on my phone. uniden 6.0
Without the model number of your Uniden phone, I don't know which silencing feature you are dealing with.
Some Uniden handsets have a Silent Mode. To toggle this on and off, press and hold the # key (below 9) for 5+ seconds when the phone isn't in use. When the silent mode is enabled, the handset will ask for a length of time for the 'no-ring' option. If no key is pressed, then the Silent Mode will continue until the # key is held again.
Other Uniden phones have Do Not Disturb. The button to enable/disable this will be on the cordless phone base. The answering system will automatically turn on and none of the handsets will ring when this feature is enabled.
You can also set the ringer volume to zero. Depending on the phone, you can reset this by pressing the volume up/down buttons or going through the menu. Look for the Ringer Volume in the same section of the menu as the Ring Tone options.
If you need additional information, please add a comment with the model of your phone. I hope this helps.
Jun 13, 2016 | Uniden DECT 6.0 Cordless Telephone...
Can't turn the ringer on to notify when a call is coming in.
Without the model, I can't be sure of the method you need to enable the ringer.
Some Uniden phones toggle on a Silent Mode if you press and hold the # key (below 9 on the keypad) for 3+ seconds on one handset. When turned on, the phone will ask how long (1-9 hours) you want the ringer to be disabled for the handset. If no key is pressed within 5 seconds, the handset will not ring until the # key is pressed and held again.
Other Uniden phones have a Do Not Disturb mode. This disables the ringer on all handsets.To disable this, press and hold the DND button on the base. The answering system will be turned on if it isn't already on when DND is in use.
The other options to mute the ringer include the volume down on the handset when the phone is in standby. Some phones will also adjust the ring tone volume in the menu.
I hope this helps. Please add a comment with the model of your phone for additional information.
Apr 29, 2016 | Uniden Cordless Phone
When answering mode is on I do not want to hear the ringing(4x) tones before going to answering.I've switched off the 'call screen' option. still I hear the ringing although not recording at least.
Just set the ringing volume to off.
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level. Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according to their individual settings
May 29, 2015 | Uniden DECT 6.0 Cordless Phone ID
How to take off silent mode? I never programmed it to do this...
See if this helps
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
to their individual settings.
Oct 17, 2014 | Uniden DECT 6.0 Cordless Telephone...
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
Increase number of rings
You can select the desired ringer patterns of the base unit and cordless
handsets. 4 patterns are available for each line. Your phone comes from
the factory set to pattern 1. Programming must be carried out
separately for the base unit and cordless handset(s).
Make sure that the base unit/cordless handset is in the standby mode.
Base Unit Handset
4 Enter the desired pattern using
the dialing buttons ((1) to (4)) for
each line. To move to another
line, press H or I.
• Each time you select a pattern, it
rings.
5 Press (ENTER).
• A beep sounds.
• To return to the standby mode,
press (EXIT).
1 Press (FUNCTION).
2 Press or until the arrow
points to "Ringer setting",
and press H.
3 Press or until the arrow
points to "Ringer pattern",
and press H.
• The current settings are displayed.
Ringer pattern
L1 L2 L3 L4
1 1 1 1
Feb 20, 2011 | Panasonic KX-TG4000B 4-LIne Multi-Handset...
My 2nd phone will ring bt the main one I can't seem to turn ringer on..Help Please
If this is the model I think it is, your phone line cord is pluged into the base of the main handset. So let me see if I'm understanding your problem...You have a single line phone with two handsets, and your remote handset rings, but the main handset at the base unit does not. Since your second handset rings when called,your line is working, and your unit's base is working, as well, or the other handset would not ring. Therefore your problem is within the handset itself. I will assume you've made sure the ringer is turned ON and the volume turned UP. Use the Menu button on the handset to find these variables and make sure the ringer is ON and turned UP. Place the handset on the charging cradle. Press the ON button WHILE the phone is on the cradle. You might have to use the speakerphone button to do this. This will resync your handet with its base.
Feb 01, 2011 | Panasonic KX-TG2631 Cordless Phone
Ge model 28213ee2-a 2nd handset doesnt ring when a call comes in
assuming all the settings are correct, and sometimes there's a tiny switch on the handset for ringer, that has to be on, try the 'page' feature [the button on the base to make the handset ring to find it] - if that doesn't work, there's a very good chance the ringer itself is bad. i've seen that many times.
May 26, 2009 | Uniden Cordless Phone
One handset doesnt ring
There should be a ringer tone and volume control on the second handset. Sometimes there is a ringer on/off switch on the side of the handset.
If that doesn't work, then there is a possibility that the speaker is broken.
Lowering ringer volume on handset v tech 5.8 digital phone
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
Nov 11, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Panasonic KX-TGA401B Handset Logo
27 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
