Question about Saeco Odea Go Plus Automatic Espresso Machine Aroma System Rapid Steam
Saeco Odea Go Plus not working
My Saeco Go Plus is down for the count. I had just finished the first stage of descaling and was getting ready to run a clean tank of water through the unit, when the red exclamation point began blinking slowly. The blinking light occurs when you turn the steam knob to the on position, which fails to generate steam. The water button also no longer works. Pressing it generally has no effect except that it occasionally causes the grinder to spin. Pressing the grind button produces a click sound but fails to grind the beans. I tried removing and cleaning the assembly and bins on the right as well as the water tank. I also tried unplugging the machine overnight and trying again to no avail. I even tried the high powered magnet reset trick posted by the technician. I'm not sure it it's still under warranty. Any advice?
SOURCE: Coffee Grinder not working
the grinder is most likely stripped and needs to be replaced:-{
Posted on Aug 08, 2007
  • 487 Answers
SOURCE: Saeco Vienna Deluxe
ok which red light are you talking about. the water or the beans or the warning
Posted on Apr 16, 2008
  • 515 Answers
SOURCE: Saeco coffee machine
I think your grinder engine has broken and have to be replaced.
Posted on Jul 18, 2008
  • 1618 Answers
SOURCE: Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Posted on Jun 24, 2009
SOURCE: Saeco Odea Giro - alarm light continually slow flashing
I had the same problem. I filled everything up and closed it then took the hopper top and placed a small magnet that fit the circumference of the hopper sensor (I took one off of a refrigerator magnet and it fit down into the sensor) and it immediately went green. Hope it works for you.
Posted on Jun 30, 2009
The descaling light and water drop is constant flashing preventing machine from working, what to do?
Did you check if your hot water know was fully closed
Try turn off the machine, press the water drop button and turn on the machine . Keep pressing for 20 sec.
You may attached a recording video if problem not resolved
Good luck
Nov 12, 2014 | Saeco Odea Giro Plus Coffee Maker
How to open the saeco odea
After descaling and rinsing, you need to hold the hot water button for 6 seconds to reset the descaling indicator.
Mar 26, 2013 | Saeco Odea Giro Plus Coffee Maker
How do I descale my Saeco Odea Giro Plus Coffee Maker
do you have a video on how to operate this machine
Nov 27, 2011 | Saeco Odea Giro Plus Coffee Maker
Flashing Red bulb
That is the descale light, you should run a descale through the machine. After you have done that hold on the water button and the descale light will go away
Jun 26, 2010 | Saeco Odea Go
I Have descaled my Saeco Odea Go but still it doesnt brew coffee
That is serious, that means the grinder is jammed or not working. To check the components of the machine follow these instructions.
Press and hold the steam button and turn on the machine, when you see the lights going around in anticlockwise direction, release the button. Turn the coffee dial to the left and press the steam button, the grinder should turn. Dial on the right and pressing coffee ****. water pump runs. Press steam ****. brew group go up, dial 1/4 to left B/Group down.
If grinder not turning the motor is bad. Hope it will help to find out.
Mar 23, 2010 | Saeco Odea Go
My Saeco Odea Giro has the element light permanently on (not flashing) and the strength light is set to 3, I cannot change it. I have tried descaling, cleaning etc. Any ideas?
The element light is saying it,s time to descale. Since you have done that you can remove it by holding down the water button for a few seconds until it goes off.The strenght light?.checked whether it is not sticking.
Dec 15, 2009 | Saeco Odea Giro Plus Coffee Maker
I have descaled my Saeco Odea and the coffee beans light and the descaling light keep on flashing from one to the other
Hi, Try holding down the steam button for 10 seconds. It should reset the descale warning lamp.
Hope it helps.
Dec 06, 2009 | Saeco Odea Go
Saeco Odea Go Plus Automatic Espresso Machine Aroma System Rapid Steam Logo
52 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
