Question about Refrigerators
I have a whirlpool K40 ice machine. The compressor comes on then cuts out immediately. everything else seems to be working ie water flowing, pump on
It was producing ice, has water flow. Now the compressor just cuts off as soon as it kicks in.
  • 146 Answers
The compressor seems to be overheating try replacing the start components or install a 3 in 1 unit you can buy at any refrigeration supplier...good luck
Posted on Jan 05, 2015
  • 50 Answers
Sounds like overload is kicking on compressor, bad compressor, have to ohm out compressor windings.
Posted on May 04, 2014
fridgetech
  • 473 Answers
SOURCE: Whirlpool Side-by-Side Refrigerator No Water to Icemaker or Door
Check to see that you do have water to the water valve on the fridge. You can disconnect right where the water line goes into the valve on the fridge. Next, if you can, check power at the valve while activating the water dispenser. If you have power at the valve when activating then the water valve is bad. Let me know what you find.
Posted on Oct 10, 2007
  • 1073 Answers
SOURCE: Water not flowing into ice maker
yes there is a problem with the water valve or the fill tube that puts water into the ice maker is frozen not letting water into the ice maker
Posted on Apr 17, 2008
  • 3 Answers
SOURCE: slow water flow on Whirlpool Gold 25.6 cubic
The water line tap may be screwed back into the water line or you did not sufficiently poke a hole into the water line with the tap. We had the same problem. Shut off the water supply, remove the tap from the line and check the size of the hole. my bet is the hole is very small. Either drill out the hole with a drill and replace the tap (with a new rubber grommet) or add a tee into the line with the proper size compression fitting (that is what we did) and the water will flow freely..
Posted on Jun 21, 2008
  • 864 Answers
SOURCE: No Ice is being made. Water is being despensed at the door but it seems that no water is going to the ice maker. Have good water flow to the pump.
Is the ice maker turned on?  The on/off switch is located on the top right side of the freezer compartment.  The manual says that there is a sensor beam that passes from one freezer wall to the other to shut off ice making when the bin is full.  Check to make sure nothing Is blocking that signal beam and that the bin is correctly installed.
Posted on May 30, 2009
mrfixit3667
  • 262 Answers
SOURCE: the ice maker stoped producing ice and the water
First I would check your water Filter :)
Posted on Aug 11, 2010
Have a scottsmanc1448 ice machine shows codes 1 an an 2 longharvest cleaned all water sensors descaled machine works threw all cycles water flows over both curtain coils ...
ok, what you have not told me was the temp of the ice plate. If you have an inferred thermometer now is a good time to use it. what is the Temp of the plates or ice collection try. Ice will never collect if it is not below zero C. 32F my guess is it must be below 28F. you need some kind to thermometer.
Dec 09, 2014 | Kitchen Appliances - Others
I have a KUIC18PNTS0 it will make a few batches of ice then the water level tends to drop until the pump cavitates from low water, ice production halts.. Turn off and let warm up it will do the same t
I was going to post a manual but wasn't sure if the model I have is close enough to work with yours. e-mail me if you want one. I don't like to give them away here to everyone and neither does Whirlpool, Sea Breeze
Jul 06, 2012 | Refrigerators
I have a Whirlpool Gold top-mount fridge (GR2SH/GR2SHM). It's about 6 years old. About a year ago the freezer started to have ice build up and water would over flow into the fridge. I defrost the...
The defrost cycle is not working. After a predetermined number of hours of compressor running time, a timer actuates the defrost cycle, which stops the compressor and turns on a heating element to melt the ice. Either the timer or heating element is not working. Also, make sure the melted ice water is actually draining and not re-freezing.
Aug 31, 2017 | Whirlpool Microwave Ovens
After 13 minutes water runs back up drain hole thus melting ice then just before next slab drops emties drains clear new pump fitted why does this happen its a whirlpool k40 2 half y old
The drain is partially plugged... so when the water dumps right before the harvest cycle it back up in the drain...
Blow out the drain and you will be good again...
heatman101
Oct 19, 2010 | Whirlpool Refrigerators
We have a Whirlpool K40 Ice Maker but it seems to have stopped producing ice. The motor is running but there is no water coming into the machine & therefore no ice is being frozen & cut by the...
a few things to check, first off is adequate water supply(obviously).. next check your drain system, if your unit gravity drains look for a blockage, but if you have a secondary drain pump to pump away water check for proper operation, if that pump fails the machine will no longer let water in( thinks it full and no need to produce more ice if it cant get rid of old water
Jun 09, 2009 | Whirlpool Freezers
Water dispenser and Ice maker not filling with water.
You need to replace inlet valve for the dispenser and ice maker .
Dec 09, 2008 | U-Line Refrigerator Ice Maker
Whirlpool k40 ice maker... its been working fine then suddenly its hardly producing much ice, the cutting grid has been replaced and thats okay just very little ice. it goes through its process drops the...
Check the water hose. Is it kinked? Is the screen clogged. After a while minerals build up and could have clogged the intake making it hard to get the water necessary to make the ice,
Jul 01, 2008 | Whirlpool Refrigerators
Slow water flow on Whirlpool Gold 25.6 cubic
Apr 20, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
100 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
