Question about Daikin Mini Split Ceiling Suspended Units
Blinkin light not cooling
  • 29 Answers
Turn the main power to the unit off, leave off for about 20 seconds then turn back on. Unit should restart. The blinking light is a fault light that can be reset by turning main power off. Most times it will restart no problems but if the fault re occurs there is a problem with the unit itself. If the fan starts and runs for around 4 minutes on cooling mode then stops and blinks there is a problem with the outdoor unit.
Posted on May 17, 2014
The ligths of the air condition panel are blinkin.
It needs to be recalibrated. Likely because it failed the cool down test. Have you checked the freon level. After you fill the A/C it will have to be recalibrated. Check the freon and let me know. I'll post the calibration procedure if you need me to.
Apr 14, 2010 | 1999 Plymouth Voyager
Overheating fan stop working. all lights stat blinkin. turned of my car and its not tuning on until it cools down. what should i look for ?
Sounds like the temperature switch that turns the fan on went bad. Im not exactly sure where its located but if you find a repair manual (or someone on here with knowledge of the car) you should be able to identify it! Usually they are mounted on or near the coolant outlet on the intake manifold.
Mar 16, 2010 | 2001 Pontiac Aztek
It turns off and the red light blinks.
blinkin red light usually means hardware failer the only 2 easy tricks to try that wont void your warrenty is
#1 remove the hard drive and boot it up without it and see if it boots and says no hard drive then shut it down and plug the hard drive back in if it works now then was just a drive error if it goes back to blinkin you have a bad drive.
#2 the fan test that also seems to clear any over heating or other blinkin light problems --- turn the ps3 off for 40 seconds by the switch on the back then hold down the eject button and flip the power switch back on while still holding the eject button and see if that clears it.
Sep 24, 2009 | Sony Playstation 3 (PS3) Console
I try to my console on and it does turns on for a second and then shuts itself off and blinks red. its not hot or anything and idk whats wrong with it. my only controller was dead could that be the...
#2 the fan test that also seems to clear any over heating or other blinkin light problems --- turn the ps32.gif off for 40 seconds by the switch on the back then hold down the eject button and flip the power switch back on while still holding the eject button and see if that clears it.
Sep 23, 2009 | Sony Playstation 3 (PS3) Console
Red light of death
Two light are blinkin' in from panel. and tv
This seems to be a common problem. I have the same issue. Repair man says its a power supply (he thinks). When the lights start blinking, press the power button on top of the tv (not the remote) and most of the time it will come on and work. I am going to try to replace my power supply and see if that fixes the issue. If so, I will update this post.
Aug 28, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Hello, my Metabo WE14-125 won't work anymore, there's a small red flickering light on my machine and I don't know what it means! At first I thought it were the carbon brushes, so I changed them, but the...
The light is an overload indicator that should come on when the tool is really hot. Internally, a sensor monitors the motor temperature and when the motor becomes too hot, tells the electronic to limit the voltage to the motor. This causes the tool to feel like it has no power. It should be run no load until it cools off, the LED goes out. The tool should have full power again.
If the light is on continuously, even when cool, and it doesn't run, get the tool to an authorizied service center; it may need a new armature. You can find your closest service center here:
http://www.metabo.us/Service-Centers-USA.5317.0.html?&no_cache=1
May 17, 2009 | Metabo W14 125 Ergo Angle Grinder 5"
INTERNET LIGHT BLINKIN
Contact your internet provider and have them ping your belkin,I am sure your provider can help you.
Jan 29, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Projector Panasonic PT-LC50U
MI PROYECTOR PANASONIC PT-LC50U ,SOLO ENCIENDE DE 2 , 10 NINUTOS LUEGO SE APAGA Y SE ENCIENDE LA LUZ O SALE LA LETRA L-n QUE DEBO DE HACER POR AQUI NO HAY CENTRO TECNICO ..
MI CORREO ES : jcasaperalta@hotmail.com
gracias por darme solucion.
Sep 18, 2007 | Panasonic PT LC50U Multimedia Projector
Daikin Mini Split Ceiling Suspended Units Logo
441 people viewed this question
Top Daikin Heating & Cooling Experts
bobalix
coolworks
Are you a Daikin Heating and Cooling Expert? Answer questions, earn points and help others
