Exit setup screen, no remote control?
My TV is stuck on the setup screen and I have not got the remote control for the actual TV. Can you help please?
  • 54 Answers
Call The Stereo Outlet, 724-225-1292
Posted on Mar 31, 2014
4 Suggested Answers
SOURCE: the adt/dtv button was pressed
try re-booting your TV
Posted on Jan 30, 2011
SD Tech
  • 14553 Answers
SOURCE: my rca is stuck on channel d9-1 and all buttons only control my volume please any answers
Try to unplug set and whatever is being used for signal from power, if set returns to normal operation you may have to delete that channel from the set memory.
Cable or Sat boxes can cause this issue by confusing the micro processor in the set.
Posted on Dec 03, 2012
SD Tech
  • 14553 Answers
SOURCE: TV stuck on setup menu, no remote
Its possible if side menu does not stop it that button (switch under it) is bad.
About the only remote chance you have is to remove set and a box from power and after several minutes power them back.
Posted on Dec 17, 2012
Why i have a white screen with the message v3.05.0 and the remote control has no response!!!
Does your remote control unit has an exit button
if yes try using this then add a channel and then close your tv set
After this you should be fine
Jul 19, 2014 | LG M1962D TV
PAL, NTSC
Pls tell us which tv set u have..
Dec 08, 2007 | Mintek DVA-8700 System
Digital tv channel stuck on Setup blue screen
Just contininue to try that it if not then you'll have to do a hard reset.
Feb 01, 2014 | Philips Televison & Video
How d I activate an external antenae
1. Press TV to select the TV mode.
2. Press POWER to turn on the TV. The STARTING SETUP function
begins and the language setup menu appears on the screen.
Press upArrow (^) or downArrow (v)to select your desired
language, then press ENTER.
3. Press (^) or (v) to select TV or
CABLE, then press ENTER.
4. Press (^) or (v) to select START, and
then press ENTER, which
starts the AUTO SETUP.
Note:
To cancel the setup and return to the regular TV screen, press (^)
or (v) to select CANCEL and press ENTER.
5. When the AUTO SETUP is complete, the regular TV screen
appears.
Notes:
• AUTO SETUP of channels may take 15-30 minutes to complete,
depending on your regional cable service.
• To cancel the AUTO SETUP and return to the regular TV screen,
press EXIT.
from TV manual that uses a CT885
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0CEcQFjAD&url=http%3A%2F%2Fwww.hdtvsolutions.com%2Fpdf%2F50hp66_om_e.pdf&ei=_KppUvWPNqjSyAHTr4DIAg&usg=AFQjCNGar3aphbJ5yNHl9QMUJsSI6SjCTQ&bvm=bv.55123115,d.aWc
Aug 15, 2013 | Toshiba Ct885 Remote Control
Can you help, i have a toshiba tv (quite old, not flat screen) and i broke the remote control. I now have a [URC22S Universal Remote Controller] and I'm having a lot of trouble getting it to work
Please provide more details. What do you want to know. Setup codes? If so, check this site. Setup code list and setup proceedings to many popular brand remote controls are given.
Apr 22, 2013 | Televison & Video
Dec 17, 2012 | Televison & Video
Black and white tv
Hello
Your RCA, system setup has changed I thinks.To change this you have to go to the Menu option surf for system settings, and change the system reception to "AUTO".
Setup
The Setup menu allows you to access the GUIDE Plus+ system setup information. To access the
Setup option:
1. If the GUIDE Plus+ system isn't on your screen, press GUIDE on your remote control.
2. Press MENU to select the Menu Bar.
3. Use the right arrow to highlight the Setup menu selection.
4. Use the up and down arrows to select Change system settings, Review options, or
View demo.
Change system settings Confirms the settings you completed in the GUIDE Plus+
system setup are correct.
Review options Displays the GUIDE Plus+ system auto display options.
On Automatically displays the GUIDE Plus+ system when you press the ON•OFF
button on the remote control.
Off Disables the GUIDE Plus+ system from being displayed when you press the
ON•OFF button on the remote control.
View demo Runs the GUIDE Plus+ system demonstration
Note: If you have not completed your GUIDE Plus+ system setup, these options will not be available. A
screen will prompt you to complete your setup.
Getting In & Out of the GUIDE Plus+ System
To enter the GUIDE Plus+ system:
• Press GUIDE on the remote.
• Press and hold MENU for 2 seconds on the front panel.
To exit the GUIDE Plus+ system:
• Highlight a program and press OK to exit the GUIDE Plus+ system and tune
to the channel.
• Press GUIDE to exit the GUIDE Plus+ system and tune to the channel
displayed in the video window.
• Press CLEAR to exit the GUIDE Plus+ system and return to the original
channel
OK.
Dec 04, 2010 | RCA 32V420T 32" TV
Tv continues to go to menu screen (not dish menu, tv menu)
sounds like a button is stuck. Remove the battery from the remote and see if this fixes the problem
Sep 07, 2009 | Televison & Video
Sylvania TV stuck in Game mode remote no longer works
go up to your TV and go into the menu. Go to the channel selection and run the auto select for channels. This will take some time but the TV will end off the first channel found, the only thing is you cannot get back into video mode without the remote
Mar 26, 2008 | Sylvania 6413TC 13" TV
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
