Question about Kids II 1001174 Baby Einstein 2-in-1 Safari Adventure Gym and Tunnel
Lost instructions to the tunnel
Need help
Replace light tunnel infocus 4805
Hi, to get the basic instruction on how to clean/fix the 4805, click on this LINK...
Thank you.
Jun 06, 2012 | InFocus ScreenPlay 4805 Multimedia...
We have had our ants for 3 days and they don't seem to be interesed in making tunnels. We put in four holes, like the instructions, but they are just staying on the surface. Help?
According to the Uncle Milton site, ants are much less active in the winter. This is probably why your ants are not being active and tunneling.
Jan 08, 2012 | Uncle Milton Ant Farm Gel Colony
I have lost the instructions for the plan for the track belonging to Thomas and friends take along lights and sounds bridges and tunnels set and following the picture on the box isn't working. Can you...
  • This picture of the entire layout will do you better than the picture of the box. The manual is pretty hard to come by, even the Thomas the Train website does not offer one because it is no longer manufactured. Hope the picture itself serves to help you get it put together like you wanted.
Regards, Tony
May 23, 2011 | Toys
Dark haze left side of screen about 4 to 6 inches wide only in the wider screens not in the native
Its a Light Tunnel failure. Go to www.avsforums.com and search for 4805 Light Tunnel. There are instructions to open the PJ and repair the Tunnel. Also, I posted a DIY replacement option in lieu of fixing the very fragile tunnel.
http://www.avsforum.com/avs-vb/showthread.php?t=1304694
Jan 02, 2011 | InFocus ScreenPlay 4805 Multimedia...
Thomas the train blue track layout
Try looking for your set here and downloading the manual
http://www.tomy.co.uk/webcare/product-instructions/track-master-tmrr-instructions/
Dec 21, 2009 | Tomy Thomas The Tank and Friends Track
Tranlucent dark spot on Optoma image. Looks like something is on the lens.Off center--top to bottom. Cleaned lens, blew out case, changed bulb, still with dark spot.
is it an optoma or an infocus? if it is the infocus, it needs to be replaced. however, to replace it, you need to remove the entire optical engine. now off of that, remove the clorwheel and clip, the main board, and the tunnel (on this model it is called an integrator rod) assembly. to get that out, remove the 3 tap screws and the large screw. once you can slide it out, remove the foil from the front, slide out the inside tunnel assembly, remove the clip, then the tunnel. because the clip is an exact fit, you cannot have anything on the tunnel that increases the size. reverse the instructions to reassemble (but you will need to replace the foil with a new one). warning: you now need to realign the tunnel using 2 of the tap screws. if you have not done this before, it is very difficult and dangerous, as you need to have the projector powered on and the screws are way inside next to the power supply. there is a risk of electrocution and damage to the projector. best bet- send it in to an authorized infocus service center for repair. try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 15, 2009 | InFocus LP70+ Multimedia Projector
How to change the V belt on hoover wind tunnel U6435-900 ?
Below I have listed a link to the manual which has instructions and a link to the V belt you need.
Windtunnel Manual
Windtunnel Replacement Belts
Nov 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Light engine/light tunnel replacement instructions
No, I don't know of one. The service manual might or training manual but you would probably need to buy that.
I've never done one on a Samsung. Do you actually need to change it or just wondering?
Dec 31, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Replacing light tunnel (instructions)
Hi, if you did not get help until now, i can send you step by step instructions and photos how to do it. I did several of these and it is not a big deal.But you will have to take apart a very sensitive optical device and if you are not confident that you can do it do not start this.bp67-00291a is the part number for the light tunnel.post a message here if you need that file with instructions
Jul 09, 2007 | Samsung HL-R5678W 56" Television
Kids II 1001174 Baby Einstein 2-in-1 Safari Adventure Gym and Tunnel Logo
131 people viewed this question
Top Kids II 1001174 Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Kids II 1001174 Toy Expert? Answer questions, earn points and help others
