Question about Krups Coffee Makers & Espresso Machines
Krups 967 b parts
We are looking for the little round metal piece that filters the ground coffee. this piece sits inside the funnel piece. thx. Simone
  • 54 Answers
Kohl's should have it or look at ebay or Krups site for parts
Posted on Mar 31, 2014
SOURCE: Revere Ware old fashioned coffee pot
1) Boil the water you’ll need in another pot.
2) Put 1 tablespoon of ground coffee (drip grind, not percolator grind) in the reduced diameter, perforated bottom of the brewing chamber.
3) Put the grind/water separator (the perforated, flat handled plate with cup markings on the handle) in the Brewing Chamber, over the coffee grounds.
3) Put the Brewing Chamber on top of the Holding Chamber.
4) Pour the appropriate number of cups boiling water into the brewing chamber; put the lid with the black knob on the brewing chamber.
5) Let the water drain through the coffee grinds (5-10 minutes).
6) Remove Brewing Chamber, clean out the coffee grounds, and replace the lid on the holding chamber.
7) Enjoy your coffee! Keep it warm on the stove at LOW heat setting.
for the most information on the Revere cookware lines, go to: http://mysite.verizon.net/vzeoywo4/theshineshop2/id1.html
Charlie
Posted on Jun 18, 2008
gandhiforyou
  • 275 Answers
SOURCE: leaking Krups XP4030 Espresso Machine
go to this link http://www.krupsusa.com/Consumer+Services/Services.htm
Posted on Jun 28, 2008
SOURCE: Krups XP7240 leaks
The grind selector knob can be removed with the following steps: 1) Remove screw on side near grinder (do not let the screw fall into grinder, :-) ), 2) use sharp knife or similar to pry off cover with three dots. This should be easy. 3) Now you can rotate the grind selector and see that the white clear plastic does not rotate and the black does. There are two little pieces (one black, one clear plastic) on opposite side from grinder that slide over eavh other to keep this knob 'locked' into place. 4) again with a sharp pointed knife or similar you can separate these two pieces to 'unlock' them. This is made easier by lifting the side of the bean holder by the grinder gently and tipping it up. Be careful not to force anything too much. The black part should pop off. 5) Now you can lift off the clear bean holder.
After this good luck. We made it farther into the machine, but could never get to where we needed to go to fix our problem.
Krups must be congratulated for designing a machine that cannot be repaired and must be replaced with new purchases.
Posted on Jan 11, 2009
  • 5 Answers
SOURCE: krups orchestro 889 coffee maker,
Remove the the four screws at the rear of the machine you will need a pair of pliers to do this and remove the hinged lids on both sides.looking down from the top and to the front you will see a phillips screw on either side,remove these and the top will come off you will then see the channels that the coffee runs from the machine now just use a piece of suitable material to clean the pipe,easy!
Posted on Mar 17, 2009
SOURCE: It is leaking from where the coffee comes out. I
That little screen that lies at the bottom of the bucket needs to be snapped out and the washer replaced. You have to unscrew the bottom, carefully remove the spring loaded lever, ( don't loose the spring) After fishing the lost rubber washer out of the hole, I used a screw driver or other similar item to pop the screen out. ( use care not to poke a hole in screen.) Next replace lever and spring and push the Star ended piece through the bottom and THEN fasten the washer. Replace all excess pieces and it should be fixed provided the washer isn't badly worn. This is the only way I know how to fix it after countless different web pages and searches.
Posted on Jul 25, 2010
I AM LOOKING FOR A krups espresso maker type 967 b MANUAL
http://www.manualsdrive.com/results.php?lang=en&search=KRUPS%20967B%2023097%20M
Oct 13, 2014 | Krups Small Appliances Espresso Machine
EA6935 krups powdered coffee inside grinder and coffee grounds noncompact
You will need to pull the grinder apart & clean it out. Most likely cause of the grinder blocking up is a leak somewhere inside the machine dampening the grounds as they exit the grinder. They bind up, won't fall out and there is your blockage. You will need to find and fix the leak, there are many, many places for the leak to be, it's a job for a Krups Service Agent. I have outer housings with cutouts in them so I can run them and look inside at the same time to find those troublesome leaks.
Feb 28, 2014 | Krups Coffee Makers & Espresso Machines
My Moka Easy Bialetti electric espresso maker switches off before all the water has been percolated through into the upper pot. I have recently replaced the rubber seal etc. at the base of the pot.
I emailed support at Bialetti and here is what I got:
Check the coffee funnel for any dents around the edge of the funnel. Normally if this brewing problem happens after changing a gasket the problem is a dent or the funnel is out of round and the new gasket isn't formed to it like the old gasket was. Don't bang the funnel to get grounds out or it may dent or get out of round. Try pulling the funnel over to one side in the water chamber and if you see a space on one side pull it tight with the other finger to bend back into shape if possible or replace the part.
Take the gasket and filter plate out from under the upper unit and hold the filter plate up to the light to check for any clogs right in the center where the coffee brews up. You should be able to see through all the holes in the filter, brush clean if needed
Jan 13, 2011 | Bialetti Moka Easy 6-Cup Espresso Machine
My espresso machine no longer pushes streams of espresso through the metal filter and into the cup; now it seems to come out in drips and drops. I'm afraid I may have used too fine a grind, and that the...
I had the same problem; I ground the beans too fine and plugged the metal filter. I boiled the filter in vinegar and it works fine now. Only do this if you have an exhaust fan that vents to the outside, it's pretty smelly.
Dec 22, 2010 | Krups XP4030 Espresso Machine
I just recieved a krups fnd1 used..do i have all parts
You should have the main machine, the screw-top to the main machine, a handled cup that holds the grounds, and inside that should have a metal lining. Drain basin. Main body should have: Screw top, turn-switch, milk foamer attached.
Aug 29, 2009 | Krups Allegro FND111 Espresso & Coffee...
Krups xp4030 wont push espresso thru and when you
I had the same problem. The metal filter is clogged with very finely ground coffee. To clear the filter, boil it in vinegar and let it sit for a few hours. Rinse the filter and run water through it in the machine (no coffee in the filter). I found I had to grind the coffee at the medium setting in order to keep the problem from recurring.
Aug 05, 2009 | Krups XP4030 Espresso Machine
Door spring came off filter basket door on Krups FME4 coffee mak
yhere should be a little post th spring goes on in the vack of the basket ...out in pkace hold untill in place
Dec 10, 2008 | Krups FME4 Coffee Maker
Charlie
Jun 16, 2008 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
100 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
