Question about NorStar Meridian M7310 Phone
Changed offices, but the functions on the phone didn't move with me
Two people switched offices and took their phone with them (the tags are all pre-printed on the phone buttons) but the functionality didn't change.
  • 2 more comments
  • Scott Cuddy
    Scott Cuddy Mar 31, 2014
    When I use FEATURE *0, and then press the INTERCOM button, the phones display the extension and username of the person who used to be in that office. I am trying to use the SET RELOCATION function now. I used it previously, but I didn't have both phones that were going to move plugged in.
  • Scott Cuddy
    I used SET RELOCATION again and everything is working well.
  • Scott Cuddy
    For future reference for other users
  • Scott Cuddy
    1) FEATURE **266344, Password 266344, 2) SYSTEM PROGRAMMING 3) FEATURE SETTINGS 4) SET RELOCATION change to yes, 5) Wait 5 minutes 6) Disconnect and Reconnect all phones to be moved, 7) Re-set SET RELOCATION to No.
Do you have info on paper shredders that just stop
shredders have a small tag next to the cutter wheels that move when you insert paper to shred. This tag is easily jammed or damaged during operation. It is normally about the middle and will be positioned between two blades. If this is not moving when paper is inserted it will not switch the machine on. It is the same switch that wwhen jammed by paper will not switch off the machine after paper has been shredded.
Nov 08, 2014 | Office Equipment & Supplies
SIR, I wish to known MS Office 2007 advance functining & sortcuts
Function keysTo do this Press
Get Help or visit Microsoft Office Online. F1
Move text or graphics. F2
Repeat the last action. F4
Choose the Go To command (Home tab). F5
Go to the next pane or frame. F6
Choose the Spelling command (Review tab). F7
Extend a selection. F8
Update the selected fields. F9
Show KeyTips. F10
Go to the next field. F11
Choose the Save As command (Microsoft Office Button ). F12
SHIFT+Function keyTo do this Press
Start context-sensitive Help or reveal formatting. SHIFT+F1
Copy text. SHIFT+F2
Change the case of letters. SHIFT+F3
Repeat a Find or Go To action. SHIFT+F4
Move to the last change. SHIFT+F5
Go to the previous pane or frame (after pressing F6). SHIFT+F6
Choose the Thesaurus command (Review tab, Proofing group). SHIFT+F7
Shrink a selection. SHIFT+F8
Switch between a field code and its result. SHIFT+F9
Display a shortcut menu. SHIFT+F10
Go to the previous field. SHIFT+F11
Choose the Save command (Microsoft Office Button ). SHIFT+F12
CTRL+Function keyTo do this Press
Choose the Print Preview command (Microsoft Office Button ). CTRL+F2
Cut to the Spike. CTRL+F3
Close the window. CTRL+F4
Go to the next window. CTRL+F6
Insert an empty field. CTRL+F9
Maximize the document window. CTRL+F10
Lock a field. CTRL+F11
Choose the Open command (Microsoft Office Button ). CTRL+F12
CTRL+SHIFT+Function keyTo do this Press
Insert the contents of the Spike. CTRL+SHIFT+F3
Edit a bookmark. CTRL+SHIFT+F5
Go to the previous window. CTRL+SHIFT+F6
Update linked information in an Office Word 2007 source document. CTRL+SHIFT+F7
Extend a selection or block. CTRL+SHIFT+F8, and then press an arrow key
Unlink a field. CTRL+SHIFT+F9
Unlock a field. CTRL+SHIFT+F11
Choose the Print command (Microsoft Office Button ). CTRL+SHIFT+F12
ALT+Function keyTo do this Press
Go to the next field. ALT+F1
Create a new Building Block. ALT+F3
Exit Office Word 2007. ALT+F4
Restore the program window size. ALT+F5
Move from an open dialog box back to the document, for dialog boxes such as Find and Replace that support this behavior. ALT+F6
Find the next misspelling or grammatical error. ALT+F7
Run a macro. ALT+F8
Switch between all field codes and their results. ALT+F9
Maximize the program window. ALT+F10
Display Microsoft Visual Basic code. ALT+F11
ALT+SHIFT+Function keyTo do this Press
Go to the previous field. ALT+SHIFT+F1
Choose the Save command (Microsoft Office Button ). ALT+SHIFT+F2
Display the Research task pane. ALT+SHIFT+F7
Run GOTOBUTTON or MACROBUTTON from the field that displays the field results. ALT+SHIFT+F9
Display a menu or message for a smart tag. ALT+SHIFT+F10
CTRL+ALT+Function keyTo do this Press
Display Microsoft System Information. CTRL+ALT+F1
Choose the Open command (Microsoft Office Button ). CTRL+ALT+F2
Jan 05, 2011 | Microsoft Office Computers & Internet
PROSTAR 816 SYSTEM WAS MOVED FROM OLD OFFICE TO THE NEW OFFICE. WE HAD 12 PHONES WORKING IN THE OLD OFFICE NOW ONLY 10 WORK. THERE IS ONLY ONE PHONE THAT RINGS. THE TIME AND DATE CAN'T BE CHANGED.
This sounds like you need a Samsung engineer to visit, however I have sent you the instructions for changing the date and time in the form of a youtube video, more info can be found at www.abbeytelecom.com. hope this helps
Aug 24, 2010 | Samsung Prostar 816 Phone
My watch ar2434 is not functioning properly. the seconds hand moves for some time and then stops. i changed the battery but the problem still persists. what could be the problem?
mcdevito75 here, The quatrz movement could need a little quartz oil or the quartz movement could be going bad, but foirst check make sure you have the correct battery and that it didn:"t work loose Return to whoever changed the battery to have it checked.
Jul 21, 2010 | Watches
I cannot get my software to install and function
NOTE: QuickVerse Smart Tags will only work with Microsoft products that support the technology. (Your version of Microsoft Word must be 2002 or newer.)
during the installation of QuickVerse. However, if a Microsoft document was open during installation, you may have to walk through the following steps manually.
Phase 1 - Manually register the QV13SmartTags.dll file
  1. Download and extract this ZIP file to your desktop
  2. Windows XP: Right-Click and select Open
    Windows Vista: Right-Click and select Run as Administrator
Phase 2A - Turn ON Smart Tags in Microsoft Word 2007
  1. Start Microsoft Office Word 2007.
  2. Click the Microsoft Office Button, and then click Word Options.
  3. Click the Proofing tab, and then click AutoCorrect Options.
  4. Click the Smart Tags tab.
  5. Verify that the Label text with smart tags check box is selected and that your smart tag is both listed and selected in the Recognizers list.
Phase 2B - Turn ON Smart Tags in Microsoft Word 2002 or 2003
  1. Start Microsoft Office Word 2002 or Microsoft Office Word 2003.
  2. On the Tools menu, click AutoCorrect Options.
  3. Click the Smart Tags tab.
  4. Verify that the Label text with smart tags check box is selected and that your smart tag is both listed and selected in the Recognizers list.
click on this link directly for more troubleshooting
http://www.quickverse.com/shopfiles/Faq.asp?ID=41221
This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya.
Nov 28, 2009 | Findex QuickVerse Bible Suite 2008
The keypad 3, 6 and 9 of my sonyericcson k750i are not functioning....
If you feel confident and competent enough, try taking your phone apart and giving the internals a good clean, take the white keypad PCB out and clean both it's contacts and the contacts on the phone's mainboard, and clear out any dust. Put the phone back together and see if that's solved the problem. It could also simply be that the keypad connector has worked loose
Key Pressed : Key presses phone appears to see
3 : 3 then left soft key
6 : 6 then right soft key
9 : 9 then back
c : c then #
left soft key : 3 then left soft key
right soft key : 6 then right soft key
(All the other keys worked correctly)
As I didn’t know what was causing this I attempted to move all data stored on the phone to the memorystick so I could master reset and possibly reflash, although after this I returned to the homescreen to find all keys had started functioning correctly again,
9 : 9 then back
c : c then #
Jun 25, 2009 | Sony Ericsson K750i Cellular Phone
Switching extensions
What do you mean their phones do not work when transfering to them... their phones still are working, but they might be different extensions now.
If you goto a set, and do a FEATURE * 0, and then press their intercom button, and see what extension comes up.
Lets check the system programming for autoset relocate:
-> get into the system
-> find SYSTEM PROGRAMMING and enter
-> find FEATURE SETTINGS and enter
-> look for SET RELOCATION: this is probably set to NO...
(when autoset relocation is set to yes, the telephone sets become smart phones, meaning when you move the sets- the extension(s) and buttons follow the set; if it set to no, the programming remains in the room/jack/port.)
There are a couple of options; but the easiest is to get the people to put back their phones to where they were, go into system programming after everyone put their phones back, turn Set Relocation to YES... and then get them to move the sets to their new offices... the phones will take sometime to come up(flashing alot longer than usual), that is because the system is reprogramming the sets to their new port assignment.
Mar 24, 2009 | NorStar M7310 Corded Phone
Wont stop running
The auto switch is stuck. Feed more paper in it to clear it, and kick once for me. The shredder has a paper jam. You can try 3 or more sheets at one time to clear it. Also try 'paper shred oil'. You can buy it at Office Depot or Office Max.
Jul 06, 2007 | Office Depot Ativa DQ60M Shredder
NorStar Meridian M7310 Phone Logo
32 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
