Motor clatering noise
There is a piece of tape or something hitting the compressor blade. Remove the object as this could eventually stop the compressor from working. There usually is a piece of insulation that gets in the way when you move the fridge. Tape this up or out of the way. If no object hitting it, then the compressor is starting to go.
Hello friend, thank you for your inquiry!
Based off what you have described your Frigidaire washer is making a clattering noise during the initial spin cycle. This sounds like a possible problem with your belt, pulley, or motor. Unfortunately in order to find out which component is causing the problem you would need to disassemble the entire washer and inspect each part. This may not be a simple DIY job since all components need to be tested. I hope this information is helpful. -Matt
