Question about Lexmark X Office Equipment & Supplies
How do I reset a Lexmark X945 after replacing the toner waste unit
Waste toner life warninf
  • 624 Answers
SOURCE: Ricoh CL3000 Laser Replace Waste toner
Couple of things to try: - If you just emptied the waste cartridge then you have to take the bottle back out and clean the insides as well. The sensor sees the toner on the walls and still thinks it?s full. FYI as typical the manufacturer recommends replacing the bottle with a brand new one. - If not that then you may have toner covering the optical sensor. Try blowing the area where the waste bottle attaches to the printer with canned air. Let us know if you have any other questions and please don?t forget to rate this post.
Posted on Feb 17, 2007
  • 95 Answers
SOURCE: error 357 waste toner full
If you dumped out the full waste toner bottle The gear that drives the gear on the waste toner bottle has broken off.
Posted on Mar 11, 2009
Patzky
  • 240 Answers
SOURCE: Need to reset parts life for belt unit, replaced
Hello mstjean,
You can access the reset menu by pressing the 3 and 9 button at the same time.
Posted on Mar 25, 2010
Testimonial: "Thank you for this timely and simple solution to my problem. I never would have figured it out without your help!"
SOURCE: Dell 1235cn Laser All-in One Printer - Waste Toner Bin issue
Wash it out with rubbing alcohol and let dry. Apparently there is a light sensor that will throw up this error if the bin is dirty.
Posted on Nov 29, 2010
SOURCE: How to reset waster toner bottle full Xerox 3535
Here's what I did.
Emptied the waste toner cartridge. Left it out of the machine. Held the microswitch (located to the right of the optical sensors) in the "cartridge in" position with a paperclip. Printed one document. Inserted the waste toner cartridge. Error now gone!
GCC.
Posted on Dec 18, 2010
Lexmark c 925 reset waste toner bottle
I don't know if you got an answer to this but I found it in the Menus>Supplies menu>Replace Supply and then tick yes for waste toner bottle replaced.
Mar 03, 2014 | Lexmark C925 X925 WASTE TONER BOTTLE
Prints with diagonal bars across pages we just changed the photoconductor kit still prints poorly
X945 Refile or replaced the developer unit.NOTE: if you remove the PC units on the suspected color and shine a flash light on the developer you should be able to see the pattern caused by toner not pushing completely above the auger system. This causes the spiral pattern. When you remove the developer and open it you should it is fairly empty inside. It requires a new box of dev-fil for the color. I would suggest 1 hour set aside to repair and make sure you get your ATC charts for the repair sensor reset/calibrations or you will have 88replacement errors later down the road and/or poor print again. hope this helps. Best bet is to call an experienced tech at Lexmark for a support call its a pretty messy and big job.
Sep 13, 2011 | Lexmark X945E Printer
The toner light has been flashing. I have now put in a new toner cartridge and my amber light is still blinking
Please reset the pc count on your printer. Please click on the link below for the steps. http://bitly.com/r8ZhYJ
If you need further assistance, please contact Lexmark Technical Support Center.
Mar 30, 2011 | Lexmark E260 Laser Printer
While printing, it stopped and orange (error) light went on. Coolers work, it has toner and paper, no paper stuck, everything looks normal. I restart power , but it is the same. printer model Lexmark...
You may still be able to do a printer selftest page.
Press the large button on the printer.
Look at the pages for
Toner
Imaging unit
The Imaging unit may be at end of life.
This is the drum unit and collects the waste toner.
Whilst you can just reset the drum counter (see user guide for this E120, it can lead to problems if you don;t replace the drum unit. I've seen E120 drum units packed full of waste toner, to the stage where they won't take any more, and it just spews all over the mechanism. It's a very small waste collector (but its also a very small printer, and relatively low capacity toner cartridges (1k, or 2k).
Remanufactured drum units for E120 can be found on the usual internet auction sites.
Mar 15, 2010 | Lexmark E120 Laser Printer
Message on Dell 2330 printer PC Life warning
I think you probably need to run the printer on a USB hub, sounds to me like you lack the power to run so many USB devices.
Mar 11, 2010 | Dell (2333R) Motherboard
Replace waste toner tank Does it mean that the toner is already used
Open your user manual.
Or get one - go to google or samsung.
The life of the waste toner container unit is approximately 1,250 pages for full color 5% image printing or 5,000 pages for black printing. When the life span of the waste toner container has expired, Replace/Install Waste Toner Tank appears on the display of the control panel,
indicating the waste toner container needs to be replaced. Otherwise your printer stops printing.
To replace the waste toner container:
1 Turn the machine off, then wait a few minutes for the machine to cool.
2 Open the front cover.
3 Pull the waste toner container out of the machine using its handle.
--- above from manual, following is my paraphrasing due to lack of pictures ---
4. remove the container cap from the back side and cap the opening
5. take the new waste container out of its package
6. install the new waste toner container.
___________
You may wish to TRY EMPTYING the waste toner, but you will find toner is the messiest and possibly dangerous (inhallation, etc) stuff you've worked with. it is an extremely find powder and can cause an awful mess and is best disposed of by capping and replacing the container with a new one (shop around to find them).
DO NOT attempt to vacuum up toner - just my personal opinion - I suspect many vacuums may not have fine enough "bags" to capture this intentionally very fine dust. BUT Toner vacuums do exist and some "may" work.
Jul 17, 2009 | Samsung CLX 3160fn All-In-One Printer
Error message imaging unit is out
Hi rmcday: Here your problem. The imaging unit creates the image using an electro-photo process. The imaging unit consists of the following: ■ An OPC Drum ■ Waste Toner Assembly ■ Charge Roller Assembly 9.0 Consumables, Routine Maintenance Items and Options Item Life based on 5% coverage Part No. Replaceable by Black Standard Toner Cartridge Black High capacity 3,000 7,000 106R00679 106R00684 User replaceable Cyan Standard Toner Cartridge Cyan High capacity 2,000 5,000 106R00676 106R00680 User replaceable Yellow Standard Toner Cartridge Yellow High capacity 2,000 5,000 106R00678 106R00682 User replaceable Magenta Standard Toner Cartridge Magenta High capacity 2,000 5,000 106R00677 106R00681 User replaceable Imaging Unit 50,000 images 108R00593 User replaceable Transfer Belt 50,000 images 108R00594 User replaceable 500-Sheet Feeder N/A 119650600 Waste Toner Cartridge 3,000 to 5,000 pages (color 5%) 106R00683 User replaceable. Your imaging unit may have exeeded it life of 50,000 pages and will need to be replaced. Hope this helps
Jun 10, 2009 | Xerox Phaser 6120/YN Laser Printer
Waste motor error
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
If a new waste toner bottle is in place, then the printer needs a new motor, which can only be purchased through an Authorized Service Center.
Oct 24, 2007 | Samsung CLP-510 Laser Printer
Ricoh CL3000 Laser, replace waste toner displar unit will not print, waste toner cartrige is empty.printer will not print? How do I reset unit?
Feb 17, 2007 | Ricoh CL3000E Laser Printer
99 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
