Question about Whirlpool Cabrio Washing Machines
Warped door The door is warped and the right rear corner of the glass is raised.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Damaged machine. maybe is worth fixing..go to
how-2-repair.com
Posted on Mar 31, 2014
1998 ford explorer rear window removal
Hi there:
  1. Remove the door trim panel and speaker if applicable.
  2. Remove the screw from the division bar. Remove the inside belt weatherstrip(s) if equipped.
  3. Remove the 2 vent window attaching screws from the front edge of the door.
  4. Lower the glass and pull the glass out of the run retainer near the vent window division bar, just enough to allow the removal of the vent window, if equipped.
  5. Push the front edge of the glass downward and remove the rear glass run retainer from the door.
  6. If equipped with retaining rivets, remove them carefully. Otherwise, remove the glass from the channel using Glass and Channel Removal Tool 2900. Remove the glass through the belt opening if possible.
To install:
  1. Install the glass spacer and retainer into the retention holes.
  2. Install the glass into the door, position on the bracket and align the retaining holes.
  3. Carefully install the retaining rivets or equivalent.
  4. Raise the glass to the full closed position.
  5. Install the rear glass run retainer and glass run. Install the inside belt weatherstrip(s).
  6. Check for smooth operation before installing the trim panel.
Hope this helps.
Feb 28, 2013 | 1998 Ford Explorer
Need to remove the door panel and replace motor
This is the best I got hope it helps!
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove the door speaker.
  3. Temporarily reconnect the power window switch to the door harness.
  4. Operate the power window switch to raise/lower the door glass until the door glass bolts can be seen.
  5. Remove the door glass bolts.
  6. Raise the door glass up into the door frame/channel and hold in place with a suitable tool.
  7. Remove the module assembly bolts and the module assembly.
  8. Disconnect the harness connector for the module assembly, and disconnect the harness clip from the back.
  9. To install, reverse removal procedure.
Rear
  2. Remove the rear door finisher.
  3. Remove the plastic vapor barrier, being careful not to tear/damage it.
  4. Temporarily reconnect the power window switch to the door harness.
  5. Operate the power window switch to raise/lower the door glass until the bolts can be seen.
  6. Remove the door glass bolts.
  7. Raise the door glass up into the door frame/channel and hold in place with a suitable tool.
  8. Remove the bolts and the regulator and guide channel from the panel.
  9. Disconnect the connector and remove the regulator assembly.
  10. To install, reverse removal procedure.
Jan 12, 2011 | 2004 Nissan Altima
How to Replace the Right and Left Run channels on a 2004 Toyota Corolla S?
I suspect you mean the glass runs that get all deformed at the top rear corner and front corner by the mirror?
Open the door and lower the glass all the way.
Grab the rubber at the top center of the door frame and dig it out of the channel with your finger nails.
Once you have a bite, pull it off to the corners, then at the front and rear corners pull upwards to pull the rest of the run out of the rail.
To install, it helps to lubricate the back edge of the new glass runs with silicon spray or similar.
Place it into the rail and grabbing a fistful near the top push doward with firm force to slide the rubber down into the rail. It will get more difficult once you reach the glass.
If you get to a point where you can not get it to down any further yet you have further to go, run the window up partially, then while pushing down on the down window switch, force the rubber to slide with the window. The glass will help carry the run the rest of the way down.
When you get the front and rear to the correct heights so the corner line up, peel the tape off the front corner by the mirror and stick the run full into the rail at the mirror and the rest of the way over the door to the rear corner If it is a little short you can tug on it to get a little slack.
Sep 10, 2009 | 2004 Toyota Corolla
R/H rear quarter window repalcement
tv is the wrong adhesive. you must use urethane with a primer. it is available at any QUALITY parts store (NAPA or Carquest comes to mind)
Material Item Specification Urethane Metal Primer Essex U-413
WSB-M2G234-C Urethane Glass Prep Essex U-401
WSB-M5B280-C Urethane Glass Primer Essex U-402
WSB-M2G314-B Urethane Adhesive Essex 400-HV
WSB-M2G316
Removal
All vehicles
ani_caut.gif WARNING: To prevent glass splinters from entering the eyes or cutting the hands, wear safety glasses and heavy gloves when cutting the glass from the vehicle.
  1. Remove the C-pillar trim panels. For additional information, refer to Section 501-05.
3-Door, 5-Door
  1. ani_caut.gif CAUTION: Make sure the cutting blades are changed where the cutting depth changes to avoid damage to the body and trim panels.
    NOTE: Some resistance may be encountered when cutting through the glass locating pegs in the lower corners of the glass.
    NOTE: Lubricate the existing urethane adhesive with water to aid the special tool while cutting.
    Using the special tool, place the flat side of the knife against the quarter glass window. Start at the top and work towards the corners cutting to the given maximum depths:
    1. 20 mm
    1. 60 mm
    1. 75 mm
    1. 90 mm
Wagon
    NOTE: Some resistance may be encountered when cutting through the glass locating pegs in the upper right and lower left corners of the glass.
    1. 20 mm
    1. 30 mm
    1. 50 mm
    1. 40 mm
4-Door
    1. 20 mm
    1. 25 mm
    1. 45 mm
    1. 50 mm
    1. 55 mm
    1. 70 mm
    1. 150 mm
All vehicles
  1. Remove the rear quarter window glass.
  1. Using a soft brush or vacuum, remove any dirt or foreign material from the pinch weld.
Installation
ani_caut.gif CAUTION: When installing urethane installed glass parts, the vehicle must not be driven until the urethane adhesive has cured. At temperatures above 21°C (70°F) and relative humidities above 50%, adequate cure time is typically 24 hours. (Refer to Essex drive away chart for the cure times as temperatures and humidity vary.) Inadequate or incorrect curing can adversely affect the retention of the quarter window glass.
  1. NOTE: Avoid scratching the pinch weld.
    Trim the remaining urethane adhesive. The urethane adhesive must be smooth and free of cuts and contamination after trimming. Avoid touching the urethane adhesive after preparation.
  1. Apply the urethane metal primer to any exposed or damaged metal on the pinch weld.
  1. If reinstalling the original rear quarter window glass, remove the excess urethane adhesive.
  1. Clean the rear quarter window glass with a non-alcohol based window cleaner.
  1. ani_caut.gif CAUTION: Wipe off the urethane glass prep immediately after each application because it flash dries.
    If installing a new rear quarter window glass, apply urethane glass prep twice around the glass surface to be urethaned.
  1. If installing a new rear quarter window glass, apply urethane glass primer to the same area that was prepped in the previous step. Allow 5 minutes to dry.
  1. Cut the urethane adhesive applicator tip to specification.
  1. Apply a bead of urethane adhesive on top of the existing urethane bead on the pinch weld. Make sure that all gaps in the urethane adhesive are smoothed into one continuous bead.
  1. Position the rear quarter window glass to the flange, and press the retaining tabs into the flange to engage.
  1. Install the rear quarter window glass.
  1. Check the rear quarter window glass installation for air or water leaks through the urethane seal.
  1. Install the C-pillar trim panels. For additional information, refer to Section 501-05.
May 29, 2009 | 2004 Ford Focus
I have a grinding sound (like metal on metal) when I turn my Kenmore 70 Series dryer on. So right now we are not using the dryer. Any solutions. I was going to open the top up but cannot figure out how to...
Your drum seals may need replacing.
Unplug the dryer.
Remove 2 screws under the lint filter flap.
Raise the hood by prying under the front top corner.
remove 2 screws from the top right and left front inside corners.
Remove the door panel by lifting up.
unplug the door switch wires.
remove the belt from the motor pulley.
remove the drum
also check the drum rollers attached to the inside rear cabinet.
Mar 10, 2009 | Kenmore Dryers
Hey when i push the power botton for the rear window it doesn't go down,I checked the power button,and its good ! Can i replace the power motor in the rear window,and where is it located,i would like to...
  1. Raise and support the rear door window glass to the full up position.
  2. Remove the interior door handle.
  3. Remove the rear door speaker.
  4. Remove the water shield.
  5. Disconnect the rear door window regulator motor electrical connector.
  6. Remove the rear door window regulator rivets.
  7. Remove the rear door window regulator by sliding the regulator arms off of the window glass track.
  8. Installation is the reverse of the removal procedure, noting the following:
    • Cycle the door glass to make sure of engagement of the drive mechanism.
    • Remove the rear door window glass-to-regulator bolt or rivet.
    • Position the rear door window glass as necessary to access the rear door window glass-to-regulator rivet.
    • Secure the rear door window glass in the full UP position with tape.
    • Disconnect the window regulator motor electrical connector.
    • Remove the 2 window regulator nuts.
    • Remove the 3 window regulator motor bracket nuts.
    • Install the window regulator assembly. Tighten the 3 motor bracket nuts to 89 inch lbs. (10 Nm).
    • Install the 2 window regulator nuts. Tighten the nuts to 89 inch lbs. (10 Nm).
    • Connect the window regulator motor electrical connector.
    • Remove the tape securing the rear door window glass in the full UP position.
    • Position the rear door window glass as necessary to access the rear door window glass-to-regulator rivet. Tighten the bolt to 62 inch lbs. (7 Nm), or install a new rivet.
    • Install the window regulator motor
    • Remove the window regulator assembly.
Remove the window regulator motor
Feb 23, 2009 | 2001 Ford Explorer
Door warped.......
Hi, These cabinets have 2 sheets of tempered glass with an airspace between and are fully reversible I would doubt they are warped. My best guess is that the cabinet is not square. If you have a level, check it across the top of the cabinet not the door. Also check it diagonally both directions. The cabinet has feet which are adjustable unless you have a low spot on the floor for which you may have to use a shim. Remember that it needs to lean slightly to the rear for the door to close on its own if partially open. Good Luck to you! Let me know how this works for you.
Feb 08, 2009 | EuroCave Comfort 260 Collector's Package...
'88 toyota camry rear window stuck in down position
To get to the Window:
Remove Door Inside Handle:
remove screw, slide the handle forward.
Disconnect the control link and remove the handle.
Remove Door Trim with Inner WeatherStrip:
Remove the two screws from the armrest.
Insert a screwdriver between the trim retainers and the door panel to pry it loose.  Eight hidden fasteners. 1 top left side of door.
1 right side about same height as top of armrest. 1 (each side) about same height as bottom of armrest. 1 on each corner bottom. 1 bottom in middle.  1 on left side between bottom corner and the previous at about lower armrest height...
Remove Service Hole cover.
Remove Door Glass Run.
Remove Division Bar (upper window section divider):
Remove the two screws under the weatherstrip
Remove the bolt.
Pull out the division bar.
Remove the Window Glass:
Place the glass in the door cavity.
Remove the two glass channel mounting bolts.
Remove the window glass by pulling it upwards.
You now have access to the Power Window Regulator; possible replacement of motor etc.
What type of 'things' have you tried for fixing the window and restoring operation?
Jan 22, 2009 | 1988 Toyota Camry
Rear up down door window
The window should slide right in from the top of the window.. you may have to angle it in... but you shouldn't have to remove the corner window...
Dec 24, 2008 | 2003 Land Rover Discovery
My Whirlpool Cabrio Washer keeps giving me the DL (Door unlocked code) even though I can look under the lid and see the latch extend out. I think the plastic to the glass lid has warped, keeping the...
try the lid switch/lock first ..press clips under edge each corner raise top 2 screws hole switch in place remove 3 screws along back of control panel lift console up and forward switch plugs into control bd on left side
Jul 08, 2008 | Whirlpool Washing Machines
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
