Dell 7010 will not boot
Power button is white windows screen flashes and then black screens
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 61 Answers
Can you see the computer logo before the screen flashes and turn to black?
Posted on Mar 31, 2014
mewms_14904
  • 1027 Answers
SOURCE: cant see anything but white screen after bootup
Plug in an external monitor and use the F key with the FN to toggle between lcd and external monitor. On my laptops It is the FN and F5. If the external monitor works the problem is the the inverter board, the flex ribbon cable or the LCD. If the external monitor is also messed up then the problem is probably the video card/ motherboard.
Posted on May 15, 2008
acdr
  • 1913 Answers
SOURCE: "Disc Boot Failure" upon powering up the compaq
your harddisk is not detected.
open your cpu case.
then reattch the power code and datacode to hard disk.
Posted on Nov 03, 2008
  • 62 Answers
SOURCE: Screen Wiggles, CPU Shuts Self Off, Powers Up Very Slowly
#1 Sounds like a video card resolution setting problem. This can happen when the settings are too high for the monitor. What size is your monitor?
#2 Sounds like hibernation. You can adjust the power settings if you right click your desktop and select "properties" . The select screen saver and then power settings.
#3 Sounds like the bios settings have been modified to boot from other places than the hard drive. Make sure nothing is in the computer when you boot like CDs, Floppy disks. When the computer first turns on hit "F2" to enter the bios. Then look for boot order in one of the drop down menus at the top. It will tell you how change the boot order usually on the right hand side ont he screen.
I hope some of this helps you.
Regards
Posted on Dec 06, 2008
e-Guru
  • 3917 Answers
SOURCE: dell dimension 8200 flashing yeloow power button
Please find the complete error codes for dell 8200 and their fixes.
http://support.dell.com/support/edocs/systems/dim8200/codes.htm
This will help you to figure the type of error u are getting and its resolution.
Please feel free to rate this solution link.
Posted on Mar 19, 2009
benwabnick
  • 2404 Answers
SOURCE: Dell Dimension 3000 flashing yellow light
Replace the power supply with a known working one. If it goes away then you know that the original power supply is bad.
If it doesn't go away with the new power supply then you know the motherboard is bad and would need to be replaced.
Posted on Jun 26, 2009
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
I recently bought a dell latitude xt2. It kid currently running windows 7 professional. I installed the new BIOS for it (A13). It restarted and the opperating system screen came up. Shortly after the...
The BIOS flash was ok, or you never would have seen windows boot up.
This is not a driver problem.. Are the lights staying on when it's plugged in, if not it's a bad charger and the battery is to low or dead. Have you tried to boot into safe mode, tapping F8. There is a video connector, plug in a monitor, borrow one if you can, if it works and the OS boots and windows run's, the screen is bad.
Mar 30, 2013 | Computers & Internet
Dell monitor screen suddenly went white. Can it be fixed?
I have a strong suspicion that you have burned a capacitor or two on the monitor. You will need to bring this in to have it serviced as it will require the monitor to be opened up and new capacitors replaced/resoldered.
Mar 18, 2017 | Dell Model 2208WFP - 22 Inch Widescreen...
Hi there! i have dell 1537 studio and the screen is all black now. the laptop does not boot and the volume light button flashes for few secs after i turn the power button on and the laptop shuts down...
Hardware failure, most likely in the motherboard. Take the laptop to a repair shop for an in-depth testing. Beware, the repair will be expensive.
May 11, 2011 | Dell Studio 1535 Notebook
The dell logo flashes then the screen goes blank. The hard drive keep flashing like the laptop is booting up okay it is a xps m140 and has vista home as a o/s
After the logo flashes, press F8, repeatedly, until a white-over-black "boot menu" is displayed. Choose "Safe Mode", to see if this "minimal" version of Windows will startup successfully.
Dec 13, 2009 | Dell Inspiron XPS M140 Notebook
Dell inspiron 1000 never boots up, screen black
go into bios and fix boot menu
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_541ceb86d69e7743
Dec 06, 2009 | Dell Inspiron 1000 Notebook
Can't get pass the background screen when pc load
The sequence is:
a) The Dell bios splash screen is displayed,
b) the screen will go black,
c) the disk activity light will flash for about 5 - 7 seconds, then will remain off.
d) you force a power off,
e) wait a few seconds,
f) then turn the machine back on.
g) The bios splash screen is displayed,
h) then a black screen with white text is displayed, reporting that Windows was not shut down nicely and would I like to boot into safe mode or safe mode with networking, or others.
g1) If you choose Safe Mode, Windows will boot up successfully. If I restart, the computer will usually (probably) boot into Windows fine.
g2) If you choose Boot Normally, the computer will usually (probably) enter the black and hung state.
see if that helps and the if possible do a do a system restore to when the system was working correctly.
Aug 03, 2008 | Dell Dimension 2400 PC Desktop
Dell wont come boot
sound like you have corrupted the operatint system u have to redo the hard drive reinstall windows this will help
Nov 15, 2007 | Dell Inspiron 1100 Notebook
MRM 700 won't start; screen flashes white . . . help.
stonelinton, It's not your LCD, otherwise you would have heard the sound of buttons being pushed. If your units first screen is white and there is no logo screen or any legible images, then it's your NAND flash on your main board. The first image produced upon boot is the blue magellan screen. This is produced from the NAND flash and will show it no matter if a hard drive is present or not. After the Magellan screen it pulls images from the hard drive. So, it is the mainboard and the only way to fix it is to send it to Magellan repair and they will have to put in a new mainboard then reprogram your serial number, etc.
Jun 07, 2007 | Magellan RoadMate 700 GPS Receiver
Computers & Internet Logo
David Payne
David Payne
