Question about Kitchen Appliances - Others
Hobart 2912 sc
Slicer is stuck in slow mode, have had a Hobart tech out to work on it several times and they are apparently clueless so I'm going to try to fix it my self. any ideas what would cause this? I know they have replaced the button panel and a few switches underneath.
5 Suggested Answers
bigg t
  • 640 Answers
SOURCE: I am trying to fix the dial on my hobart slicer any ideas
This is the deal jason,get a rubber mallet,mineral oil and a mapp torch.If you look at the guage plate this is the part that the meat/cheese goes on you will see 2 rods that connect it.Heat the rods up and put on mineral oil.Hit the guage plate down while turning the knob left then hit it up and knob to the right ,keep doing this and apply plenty of oil .It will be good as new!
Posted on Aug 07, 2008
  • 5603 Answers
SOURCE: BERKEL 825 THIS IS NOT
It s NOT uncommon to have new parts be slightly different than old version of the part and require slightly different hookup. The part number you have included does NOT appear to be a rocker switch.
I do see a rocker switch part number "823-00039-1 SWITCH, ROCKER" that may be what you need if it is a rocker type. The part number you gave is a "toggle" type with a "bat handle".
I suspect the problem is they gave you the wrong part.
Posted on Jan 04, 2011
  • 405 Answers
SOURCE: hobart slicer 2912. The slicer
HI. Have you tried checking if you can hear the motor is rotating. There are actually gears connecting the motor to the blade.The motor on it is just a dc motor.voltage usually ranges from 20 to 50 volts dc.If you can removed the cover and check if the motor is rotating while the unit is plugged on though this is not advisable to do this but for the sake of observation and making sure that while doing this you haven't touched any of its auxillary parts.Try to check how the gears are moving..Hope this helps.Thank you for choosing FIXYA.
Posted on Jul 18, 2011
kasperaung
  • 43 Answers
SOURCE: anyone have the wiring Scematic for Hobart 2912
let me know the ML number for the slicer.
Posted on Oct 19, 2016
I can not un screw the middle disc please help 410 hobart
I would carefully use a small burner to the local hot and with WD40 to spray this several times repeat is different from the drill or an impact screwdriver
Sep 10, 2015 | Hobart Vintage Model 410 Meat Slicer -...
The dial knob is very difficult to turn, any idea why would that be?
harsh cleaning chemicals (bleaches/soaps ) sometimes removes oil or even produces rust on thread of adj bolt's , a few well placed drops of vegetable oil and working it back and forth a few times will loosen it back up
lubricants on food slicers should always be a "food grade lubricant " that's why I like good ole vegetable oil
Jun 24, 2015 | Hobart 2912-1 - Slicer - Commercial 12"...
Hobart slicer 2912. The slicer works fine on manual but the automatic mode has stopped working. thinking it may be the motor but not sure,,, any idea on how to identify the part that needs changing?
Jul 18, 2011 | Microwave Ovens
Hobart slicer model 2912. Behind the gauge plate seems to be leaking some sort of fine sand. Trying to figure out where the sand is coming from and to stop / seal it off.
I'm quite sure there is no sand or sand-like substance on the 2912. You could be seeing bits of corrosion falling out of the gauge plate. To remove the gauge plate, remove the two large plastic plugs on the back side and remove the two bolts with a 1/2" socket. with the gauge plate opened far enough to clear the knife, you should be able to remove the gauge plate and look for corrosion and attempt to clean it.
When reattaching the gauge plate, be certain to install it such that it doesn't hit the knife. Slip the gauge plate back on, then fully close the gauge plate. Install the bolts removed earlier, but not tight yet. As you gradually tighten the two bolts, position the gauge plate such that there is a small gap between the gauge plate and the knife with the gauge plate fully closed. Tighten the bolts and reinstall the plastic plugs.
Also, depending on you fine this "sand" is, could it simply be fine metal particles from sharpening the knife?
Jul 13, 2011 | Hobart Slicer Automatic 12"
Anyone have the wiring Scematic for Hobart 2912 Slicer
Schematic is located on the back side of the bottom cover. Tip the slicer back and remove the bottom cover to find it. It's usually very dirty with food and, more importantly, oil. Be careful wiping oil off as the schematic often times smears when doing so.
Oct 25, 2010 | Hobart Slicer Automatic 12"
Hello...I am looking for specs for the Hobart 300 slicer....does anyone have them? I would appreicate your help...Diana dlbwholesalers@hotmail.com The county is requesting them as soon as possible...I...
Hi Diana. Have you given us your complete model # for your slicer?
I can't find a listing on Hobart's website for a 300 slicer. Is there a digit missing in your description?
You could call your nearest Hobart parts place and ask them to email your specs. ASAP.
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 24, 2009 | Hobart Food Mixers
Aug 07, 2008 | Hobart N50 Stand Mixer
Hobart Meat Slicer not working..please help!
i have a automatic holbart meat slicer and i can't get the blade to closes all the way any information? thank you:)
May 08, 2008 | Food Processors
Kitchen Appliances - Others Logo
32 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
