Question about Marantz Audio Players & Recorders
My Marantz CD 53 CDplayer door is not opening. what is the solution
When I manualy press the door button, door is not opening.If use the remote the door is not opening. In both cases the disc indication blinks for few seconds. When play button is pressed ,the play indicator blinks but it does not play.
    Champion:
    Habit-Forming:
  • 239 Answers
You probably have a broken belt on the cd tray so it's neither open or closed, if the laser's ok thats why it wont play
Posted on Jul 12, 2014
SOURCE: Marantz CDR420
Simply switch the analog to digital button on the front to analog, turn off the machine and turn it back on.
Posted on Dec 19, 2007
  • 395 Answers
SOURCE: CD player won't play random
the most likely problem is a weak or failing optical pickup. try a cleaning disc first there may be dust on the lens. do not use any liquid to clean the lens. remember this is an optical system if it can't focus properly or "see well" it can't read.
Posted on Feb 03, 2008
hardrocko
  • 1476 Answers
SOURCE: The cds won't play. Once you press play, the cd
Sounds like you have a powre supply issue. It could also be a display issue but if the display is working OK before you hit play I wouldn't think so. When you hit play does the display dim? If it does then the power supply is the problem. If not then the control board has a problem. Let me know how you make out.
hardrocko
Thanks for using FixYa
Posted on Feb 13, 2010
  • 99 Answers
SOURCE: marantz cd67se mk 2 Door does not open when button pressed
i had the same problem on a marantz cd-63 which is virtually identical
and it turned out to be a faulty button on the control PCB.
i replaced it with one out of a scrap PCB and all worked as it should.
hope this helps.
Posted on Sep 12, 2010
tunde007
  • 2382 Answers
SOURCE: I have a 2 year
Hi, There could be damage to the tray contact switches
(these tell to the control unit the position of the tray - open/closed), so that the control unit can start/stop and reverse the direction of the tray ejector motor.
These contacts are located somewhere underneath the tray (usually near the front unit cover), and since you mentioned that the tray was bumped while it was open, it is possible they were damaged. Also, the behaviour of the tray suggests that the control unit can no longer tell whether the tray is open or closed so it operates the tray motor in a wrong manner, which, again, points to these same contacts as the possible cause.
Repairing the contacts may be a somewhat delicate procedure, first you need to locate them (it may require partial disassemby of the tray mechanism), if they are bent a pair of tweezers might do the job, if there's hard damage, it's probably better to replace them (scrapped CD ROM units or a dead CD unit might be a good source, they just need to be of the same dimensions).
There may also be other causes for this malfunction, i just mentioned the first thing that i would check
Posted on Dec 14, 2010
CANT OPEN THE CD DOOR
Take out the complete mech, look for a small pulley wheel under the tray and turn it with your finger until it releases the disc
Apr 19, 2014 | Kenwood Audio Players & Recorders
Central locking 53 vivaro
I don't know if this will help in your situation, but on my Toyota Sienna minivan, the doors autolock after a few minutes if I use the remote to unlock it and no door was opened. I think the user manual has a way to change that setting, but I like the feature so I never tried to change it. (I keep my remote on my belt, so if I accidentally unlock the van by bumping into something that presses the button, it locks up again.)
If I want to unlock it and keep it unlocked, I press the unlock button on the remote and then press the button that opens the automatic side door, and then shut the door again so the van will stay unlocked.
If your van's users manual doesn't have a way to disable the autolock feature, you can probably get the dealer to do it. If you don't have a manual you can probably find one online so you don't have to pay a dealer the full price.
Mar 30, 2017 | Locks & Locksmithing
CD-72 Marantz CD Player disc tray is stuck in the shut position.
You might have to open the player and see why. remember to unplug till you need to see if you can get it to work or not.
Sep 06, 2012 | Audio Players & Recorders
The wrong button was pushed on remote and I can't increase sound and/or switch from tv to cd and etc please help
The 'wrong' button?? Would it be one that switches the remote to talk to a different device?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR4600-Receivers-manual/id/511dj793/t/2/
Then treat it like a new installation and guard the remote from unintentional key presses.
Look at every indicator on the receiver and evaluate what they mean and if/how they could affect your symptom.
Start at Page 7 to understand the remote.
May 12, 2011 | Marantz SR4600
Remote not working on Marantz 63cd. Tried
check the back of your marantz player, some old marantz products have a buttom at the back saying system or intermal, if it is on the system side, the remote will never works.
May 06, 2010 | Marantz CD-67 SE CD Player
Marantz cd67se mk 2 Door does not open when button pressed
hope this helps.
Dec 13, 2009 | Marantz CD-67 SE CD Player
I have a jammed cd in the stock cdplayer in my
You can pry open the door, the pull back open as far as it will go, remove cd, press eject button and see if the system corrects itself. If not, you probably have a faulty capacitor in the unit.
Oct 13, 2009 | 2000 Lexus RX 300
CD door not opening.
Usually failure to open means a faulty motor - when you press eject ca you hear the motor spinning or is it quiet? If in the UK contact me via ebay - fluffcat1 - and I can help further.
Jan 20, 2008 | Marantz DR-4050 2-Disc CD Recorder
Ate my CD
looks like the tray is offline so basiclly its not reading the first disc because its far away from the eye so by putting another disc in and it reads it because the eye is close enough to read it .  u may have to open the player up to get the first disc out.  good luck.
Oct 24, 2007 | Pioneer DEH-P690UB CD Player
SEARS/CRAFTSMAN 53628SRT Not Closing properly
sounds like the safety door sensors are at fault,also did you reprogram the remotes by pressing the smart button on the logic board,when the safety sensors are bad the door will reverse to open state.you can pully the rip cord to manualy close the door untill you solve the problem.
Sep 04, 2007 | Sears Craftsman LiftMaster Chamberlain...
199 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
