Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
HITACHI 60VG825. YOU SEE GREEN ON SUPPOSE TO BE BLUE COLOR
I HAVE THE SAME PROBLEM WITH HITACHI 60VG825. NO BLUE COLOR. YOU ONLY SEE GREEN COLOR ON WHAT IS SUPPOSE TO BE BLUE. ONE EXPERT SAID, THIS IS AN EXPENSIVE PROBLEM WITH HITACHI COLOR ENGINE AND HITACHI IS AWARE OF IT. SUGGESTED TO CALL HITACHI TO GET CONSIDERATION WHICH I TRIED, BUT FAILED. HITACHI TOLD ME 'OUT OF WARRANTY? NOTHING THEY CAN DO ABOUT IT!' DID ANY ONE GET ANY LUCK WITH HITACHI?
5 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: HITACHI 60VG825 REAR PROJECTION LCD 2005
seems to me you may have bad color wheel.going to see if i can find out any more information if i do i will post it!
Posted on Jan 21, 2008
  • 1153 Answers
SOURCE: need new lamp for hitachi 60"
vancebaldwin.com, don't think this model is on here but by my books it's showing the lamp ***. (ux21516)
Posted on Apr 13, 2008
  • 27 Answers
SOURCE: green picture and distorted
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Posted on Jun 14, 2010
Ecollier2012
  • 3459 Answers
SOURCE: 50" hitachi 10 years old has blue and green colors
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Posted on Dec 15, 2010
Color red gone out of picture
Comment by other expert is a valid one----also look with color turned off to see if screen is black and white or another color.
Set does based on model given have 3 picture tubes---a peek inside with set on will reveal if red, green and blue tubes (lens point up) are lit or not.
Jun 07, 2012 | Hitachi 57F500 57" Rear Projection...
My hitachi 53udx10b was supposedly just serviced but the picture is extremely blue. Have tried adjusting picture to no avail. Help.
I am going to tell you a simple thing to do to know what your problem may be.
With the set on turn the color all the way to zero. Go to a channel if you can that is in black and white. What color is the screen?
If the answer is that it is blue in the background whoever serviced the set did not and could have removed front speaker grill and inspection plate behind it; there is a black plastic block with three screen controls (red,green,blue) and 3 focus controls (do not touch the focus ones.)
I suspect if the blue screen is there a slight adjustment of the blue screen down will correct this.
The picture with the color at zero should be black and white or gray. If blue is background color it will also be with color.
This is called gray scale; picture with color off has to be gray or black and white.
Before you rate this solution if you have questions make a comment right here and I will advise you.
SD TECH
Jun 29, 2011 | Hitachi 53UDX10B 53" Rear Projection...
I have a 42" Hitachi HDTV Model Number 43UWX10B which I bought 12 years ago. I was having problems with the color about 2 years ago, and replaced the part, but now I am having similar problems where...
Over time a thin layer of fungi grows over the top of your BLUE CRT preventing light fronm shining through. This causes you to loose the blue color in your set. Check and clean. Also when the back is off your set check to see if your blue CRT is on. If not you may need to replace it.
Aug 14, 2010 | Hitachi 42V710 42" Rear Projection HDTV
My Hitachi 60VG825 projection TV is 3 years old. For the past several months the screen has been turning blue around the outer edges & this past week a large yellowish green spot the size of a...
Sounds like Calibration is needed on the projection internals. Your TV uses a rear-projection system and the problem is either in the imaging LCD Unit or the light filter. I see in a previous thread you have changed the bulb. You can invest in a voltage regulator to keep the hardware in factory condition.
Also you can burn a DVD of a stuck pixel remedy video and run it on the screen with full brightness and full contrast. This is used for plasma burns and stuck pixels on conventional Flat panel TVs but can repair color issues with projection systems. This therapy is focused on the imaging unit between the projector and the main drop of your tv.
please feel free to post a more in-depth description or any changes
Nov 06, 2009 | Hitachi 60VG825 60 in. LCD Television
50 inch Hitachi Ultravision LCD Rear Projection Television
Hitachi has had problems with their light engines. Very expensive. Contact Hitachi as they may give you consideration even if this is out of warranty.
Apr 15, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 51F710 Lack of green in picture
that is a color channel that is broken...
You need to increase the red or decrease the other colors. this is done with small preset controls on the neck board (or inside in the back of the CRT)
if that doesn't help. you might need to send it to a repairman before you get electrocuted (it doesn't matter if its unplugged or not, the crt stores lots of electricity)
Jan 08, 2008 | Hitachi 51F710 Rear Projection Television
How to change lamp on Hitach 60vg825
Yes, you are due for a lamp. Save yourself some money by ordering just the bulb p/n UX21516 (instead of the whole lamp assy), install it yourself. There are lots of us that sell these bulbs far below what the assy costs. Make sure it is an OSRAM bulb though.
Dec 31, 2007 | Hitachi 60VG825 60 in. LCD Television
Nov 25, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
75 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
