Question about NEC Dx7na 12txh 80573 22btn Phone Telephone Ds1000 Ds2000
Line three comes up busy and says vacant number
Line 3 comes up busy when no one is on line 3.
  • NEC Master
  • 3,320 Answers
There is either no outside line connected to that port on the switch or you do not have access to that line.
Posted on Apr 04, 2014
At my office when we have more then 2 calls come through on an extension line, the 3rd caller gets auto directed to general mailbox...can i change this? would like private calls to stay at correct number...
Check Forward Busy under Capabilities in programming, any phone that has lines ringing this setting should be set to NONE.
Also make sure line 3 is assigned to ring at those phones.
If unsure of programming the phone system or password call your local tech to come in.
Nov 27, 2012 | NorStar M7208 Corded Phone
Tip
Add Horizontal Lines in Word 2007 Document Quickly
You can add horizontal lines in Word 2007 document quickly without having to use the ribbon on the top of the page. A very easy way to add horizontal lines in Word 2007 quickly is by using the keyboard shortcuts. This method will save your time. You will be able to insert lines of many different designs by using the keyboard and not having to use the mouse at all. In order to add horizontal lines in Word 2007 document quickly, you can use one of the following procedures:
1. If you want to add a simple straight line, type three dashes (---) and press Enter on the keyboard.
2. For this style of a horizontal line, type three asterisks (***) and press Enter.
3. Type three underscores ( ___ ) and press Enter to get this line:
_____________________________________________________________
4. Type three equal signs (===) and hit Enter to get this line.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
on Jun 29, 2010 | Microsoft Word for PC
Would you please be able to tell me how to programme a number in this phone.... on a specific button down the side.
What happens when you dial "9" on the intercom? If you get an outside line, then your phone is programmed properly. If you get an empty line, then you need to disable vacant lines in system program 400.
To program the right side buttons for speed dial, press PROGRAM a button on the right side, and dial 9+ the number as you would dial it on an outside line, then STORE.
On the left side, a waste if you're putting speed dial number sin, you dial 29 instead of 9, but normally you reserve them for lines, extensions, and features that require lit buttons. The codes would begin with 0,1 and whatever the magic code for the features are.
Carl
May 05, 2011 | Panasonic KX-T7730 Corded Phone
How do I program a speed dial out side number on the buttons to the right?
What happens when you dial "9" on the intercom? If that gets you an outside line, then press PROGRAM, one of the buttons, and dial 9 plus your number and STORE.
Hmmm...Speed dial :-)
If you get a vacant line at "9", then you need to reprogram your 400 line access on your phone sytem to disable the vacant lines.
Carl
Aug 31, 2010 | Panasonic KX-T7731 Corded Phone
Chaging number of rings
To change the number of rings enter Feature 983, if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant).
The 3 soft key selections GRTG, TABLE, and LINES
Press the LINES soft key
Enter the line number on the line you want to change ringing on and press OK
Press the TABLE soft key then the RINGS soft key
Press the CHNG soft key and enter in the amount of rings you wantand press OK
Press the NEXT key to go to the next line
Repeat the procedure for the remaining lines
Press Rls when finished
Apr 15, 2010 | NorStar M7324 Telephone
Where is the serial number of my Canon Vixia HF200 Handycam? I'm not able to find it anywhere, the number mentioned under the battery is not accepted
I have Canon Vixia HF20 A and I when installing the Pixela Application that comes with it, I used the numbers under the battery. You'll need to concatenate all three numbers together as in my case for it to be correct... e.g 111122223333, 1s represent line 1, 2s line 2 and 3s line 3.
Apr 09, 2010 | Canon VIXIA HF20 High Definition Camcorder
I have 3 lines they will not ring up when you are on the line no one can call they get a busy singal but the other line work when you dial that number
Hunt groups are set up by the service provider and not related to the phone system. In a 3 or 4 line hunt group, you're given a pilot number and 2 or 3 other lines. In some exchanges, you can dial any of the numbers and they will hunt to the rest of the numbers in the group....it's very rare. Instead, you must always dial the pilot number and each line is tested, with the first idle line being rung.
If your callers are getting a busy when the first line is busy and the other lines are idle, call the phone company and discuss your telephone plan. Tell them your lines won't hunt and they'll tell you why or fix it.
Carl
Nov 14, 2009 | AT&T Lucent MLS-12D Phone
Mitelsx50 redusing total no. of lines.
In order to reduce the 6 line to 3 line you have to conatct your phone company. They can only reduce the phone line for you.
If you have 6 phone numbers meaning you have 6 lines coming in. Only the phone company can help you
Sep 07, 2009 | Uniden 5.8GHz Cordless Phone
I have a kx-ta624..one of my extensions was programmed to co1 and now I want to program it to co3... how do I do this?
It's been a few years since I programmed a 624, but here goes.
IIRC the 624 selects lines in 1,2,3 order vs. the 824's 321. Dial "9" from the intercom and you can verify this.
The system has 3 modes of operation when it comes to outside line access, No preference (gives you intercom dial tone) Idle line preference (gives you the same as if you dialed "9", and specific line preference.
From the phone, do not pick up the handset but press PROGRAM or use the set switch to program, dial 1 1 for none, 1 2 for idle, or 1 3 x for a specific line. Any of those commands would be followed by STORE.
Put the system back in SET or press the PROGRAM button to exit.
With any line preferenc, you have to press Intercom to dial internally or page. If your specific line is busy, you won't get anything when you pick up the phone or press SP PHONE. It also disables Last Number redial if the line is busy.
Did I mention that I don't use it :-) Of course, I don't use the 624 either.
Carl
Jul 16, 2009 | Panasonic Lands Phones
A busy signal
Hi Kevin,
Sorry for being off line so long. If you have not fixed the problem already, I would try de-registering the handset 3 (from both the base and handset), then re-register it, it should re-register as HS 3, unless 1 and 2 are vacant. If that does not do it, de-register just the handset (not at the base), then re-register it to the base, it will grab the next sequencial intercom number. If it is still failing, then the handset is most likely defective. As a last resort, you can try initializing the handset and the base. Let me know how it goes. CG
Apr 03, 2008 | Panasonic KX TGA400B Cordless Expansion...
NEC Dx7na 12txh 80573 22btn Phone Telephone Ds1000 Ds2000 Logo
78 people viewed this question
Top NEC Audio Players & Recorders Experts
richie46
Trippy Tripp
Najib Cambris
Najib Cambris
Level 1 Expert
Are you a NEC Audio Player and Recorder Expert? Answer questions, earn points and help others
