Question about Sony Ericsson W800i Cellular Phone
Rubber around joy stick
The rubber around my joystick is missing and while it is still functional it is not as free flowing, where can I get a new piece for my phone please?
    Brigadier General:
  • 7,752 Answers
Try any mobile store that sell accessories or parts
Posted on Jun 07, 2008
The black rubber top for the rubber joystick on my wheelchair keeps falling off where can I purchase a new one? It looks like a black rubber nipple
superglue holds rubber to metal very well , just don't use to much to run down inside switch but stays on tip
they now mfg a gel superglue for this very application (no run/no mess)
Jun 01, 2015 | Health & Beauty
The rubbre part on the joy stick turns
Just pull it off very carefully try not to tear it, then put a small amount of super glue on the top of the hard plastic joystick. Put the rubber back on, let dry for 2 hours and good to go.
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
Dx7630 kodak easyshare
the 5-way switch breaks it's solder connections on several Kodak models. if you have a soldering iron with a fine tip and are comfortable working on small soldering joints it is possible to repair the joystick (there are 10 solder connections on a 1/4 inch square switch, 3 on two sides and 2 on the other two sides)
Sep 29, 2008 | Kodak EasyShare DX7630 Digital Camera
Joy stick is not working
Good day
SE K700i is noted for its sensitive joy stick. due to its normal wear and tear, the time will come where the joystick will no longer function properly. i suggest that you have it checked by a reliable technician. they may check for dust and dirt that have accumulated through use or they may suggest for replacement of the joystick.
Sep 26, 2008 | Sony Ericsson K700i Cellular Phone
Logitech Freedom wireless joystick
i have had similar problems... it might be the disk also if the disk is really old it might not play properly becuase your computer is to new.but if that isent the problem your joy stick might only hook up to a desk top if you have considered these issues and nothng seems to effect it well ... get a joy stick that needs to be hooked up ... hope i helped
Jul 27, 2008 | Sony Logitech Freedom (vs9632830403)...
Psp joystick problems
Good day all
I recently ran into this same problem of a PSP joystick "jumping" or hopping around. Since I'm an electronics engineer I was determined to get to the bottom of this annoying problem, I read all the posts on the site and none helped, but the problem turned out to be much easier fixed than I first anticipated.
First of all I assume that you know how to take the PSP apart and take out the joystick module as well. The Joystick module connects to the PSP mainboard by means of 4 contacts, seperated by a spacer conductor that appears like a rectangular rubber, be careful not to lose this during the process.
Here is why the problem occurs, when you have a faulty joystick module, one or more of those 4 contacts don't connect to the main board anymore, so the when the PSP is trying to measure the resistance to determine the joystick position, it reads a varying value, i.e. the contact is floating.
This happens for mainly 2 reasons, dirt or a faulty module, as stated in the previous posts, the contacts could be dirty, but this can usually easy be seen, and this wasn't the problem in my case, I had a faulty module, but luckily all is not lost.
Here's how to fix a faulty module in most cases. Remove the joystick module from the PSP completely, put that little rectangular rubber on the 4 contacts (clear in my case) aside and keep it safe. There is metal clasp on the bottom of the module, you can simply pop it off with a screwdriver, by slightly bending the clasps on the side and taking it off. Now you should be able to see a VERY SIMPLE mini circuit board with tracks on, on the bottom of the module, you can indeed pop this off too. On this you will see tracks where the joystick sliders move. Put the circuit board aside too. Now look at the now completely open joystick module, you will see the two sliders each having a metal part, each of these metal parts has 2 very small contacts that run on the circuit board tracks that you just removed, most times these small contacts get bent inward and they can't make contact with the circuit board tracks anymore. Just bend them slightly outward again, so that when you put circuit board back, they touch the tracks on the board nicely. Put the circuit board back, it just slips back on, put the metal clasp back, put the rubber back in over 4 contacts on the module and voila, if all goes well you will have a nice working joystick module again. Put it back in the PSP and test it to see if it worked. In my case it worked 100% and saved me a few bucks. Hope this helps everyone. Let me know if it worked.
Oct 16, 2007 | Sony PlayStation Portable (PSP) Console
Nokia 6600 joy stick problem
Open the phone..remove the joy stick & rotate it by 90 degree & insert it again.there r 4 points beneath it for 4 directions ,it is not sensing either one of them.otherwise u can replace the joystick from nokia care centre.
Oct 03, 2007 | Nokia 6600
Joy stick
you need to clean the joystick. Sometimes just a pressured air can can solve it.
Sep 24, 2007 | Nokia 6600
Sony Ericsson W800i Cellular Phone Logo
19 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
