Unicel oil furnace
The furnace will sometimes not shut off,,it will keep running. Forced hot air oil,,unicell
    Problem Solver:
  • 12 Answers
I would check your T-stat. It's possible that it is still sending 24 volts down to the W terminal.
Posted on Apr 01, 2014
Steve realize plenum needs to cool before shut down but even after cold still does not stop.
Ok - let's back up a little bit.. Do you have a forced hot air furnace? Does it run either oil or natural gas (or liquid propane)? Do you have a chimney or power vent?
Sep 28, 2015 | Heating & Cooling
Does anyone know the right filter for a Key Backyard Spa 331?
Key backyards went out of business.
Most common filter was a standard 50 sq. foot cartridge element.
Unicel C4950 is a common filter. Pleatco and Filbur are other brand manufacturers of replacement filter cartridges.
FIT Pool spa C4950 UNICEL 4950 PLEATCO PRB50 IN FC 2390
if you think this is the one, we got lucky. If not, please go to the comment section of this thread and provide the information of where your filter should go. Maybe even upload a picture of this area and we would be able to help you better.
Apr 09, 2015 | Pool & Spa
My furnace runs for a short time not long enough to heat house then shuts off but the pilots still light
It may be a limit, keeping the heater from getting too hot. If so, there is an airflow problem, not enough air going across the heat exchanger, clogged filter, colapsed airduct, bad drive belt, what kind of heater do you mean, forced air?
Jan 06, 2015 | Heating & Cooling
After the heater cycle runs the circulation pump runs forever i have to shut the breaker to stop it
It sounds to me as if the cycle for filter may be set to 24 hours per day. Is the tub staying hot?
Look at your manual and see if there is a way to set the filter cycle. You may need to reset it to the filter cycle you want again.
Rod
US Parts Center
888-521-6183
Feb 25, 2013 | Pleatco Filbur Psg275P2 Unicel Desc...
I have an oil forced air furnace. The blower fan works sometimes and sometimes not. The furnace turns on and the burner works, but at times the fan does not come on and the burner shuts off. What is...
With out brand and model # don't no for sure, but i would check fan relay, and connections for loose wires and also the fan or capacitor could be going out.
Dec 20, 2010 | Heating & Cooling
Furnace runs OK, but blower runs again a few seconds later
Could be a defective thermostat in the plenum.
When a gas furnace shuts down the fan(blower) will run until the plenum cools to the safe range. Usually 1 and 1/2 minutes.
Intermittent operation is a defective thermostat or relay.
Mar 11, 2009 | Carrier Heating & Cooling
LG KE970
You may need to get a newer SIM card the Shine is 3G and some 3G phones don't like none 3G SIMs
Jan 05, 2009 | LG Shine KE970 Cellular Phone
150000 1974 national gas forced air furnance does the fan come on the same time the gas comes on. ...
not familiar with that particular model but on virtually every type and style of furnace i have worked on in the last 21 years. the fan is delayed. usually the burner lights then 3 to 5 minutes later after the heat exchanger has gotten nice and hot the fan comes on and blows nice and hot air. on old furnaces there was and is a switch usually on the upper right side of the furnace bulkhead that has a spring like device that heats up and rotates till it makes a set of contacts that turn the fan on. if it gets to hot the set of contacts breaks the power to the gas valve and shuts down the burner. as the furnace cools down on shut off there is a third set of contacts that open to turn off the fan so you don't get a draft. sometimes the stat can be wired up wrong, and it will bring the fan on right away ,and air will be cool and drafty till furnace catches up.
Nov 12, 2008 | Heating & Cooling
RAZR V3 Unlocking
since ur phone i sim locked with cingular and now changed to unicel it happened,u contact any cingular center where in they can help u r problem regarding network migration..
ne other probs do tell me n do rate me..
thanks,
cya
Apr 15, 2008 | Motorola Mobility RAZR V3
Heating & Cooling Logo
119 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
