Samsung HiTron, CD50F2, high bright, flyback line white visible, menu text blurred
Hi, Samsung hitron 50cm (CS50F2) refers -On switch-on, the screen is quite bright as if the'brightness' has been turn full. Can see the fly-back line in white. The text (eg when pressing menu) seems to be blurred, out of focus. I am an electronics technician, was hoping to investigate myself? Any pointers, besides taking it to a repair-shop? Thanks Gert
    Top Expert:
  • Televison & ... Master
  • 75,311 Answers
Check the screen voltage. Adjust it to a little lower and check. Check the supply voltage to its video output stage [CRT base card]. If this voltage is less than normal, this kind of fault can occur. Check the smoothing capacitor [the electrolytic capacitor of low capacitance value] is bad. If it is bad, the voltage stated above will go low,and the retrace lines will be visible. Check these.
The fault you now see is technically called vertical retrace lines with picture. The above said are the main causes for this.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts.
Posted on Mar 31, 2014
silly girl
  • 513 Answers
SOURCE: TV focusing problem
It's good that you know how TV's can bite, I'll still have to post this in case someone having your problem and reading isn't aware of this and feels lucky- If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. could be a problem with the screen potentiometers block. should be located on the chassis close to where the HT lead passes on its way to the picture tube. Good luck
Posted on Mar 16, 2006
ice man
  • 68 Answers
SOURCE: Late turn on
seems like you are having some problems in the power section of the tv. they are either one capacitor gone bad or some of them gone bad. do you know how to check capacitor? if not just take it to a repair man. good luck
Posted on Apr 02, 2007
Arpi
  • 326 Answers
SOURCE: Screen went full bright one day.
Hello, please check the 10uf/200V capacitor around flyback transformer. Best regards, Arpi
Posted on Jul 17, 2007
salt56
  • 373 Answers
SOURCE: White Lines and Bright Screen
I believe you have a shorted transistor on the crt board on the back of the picture tube which should be Q5104. Let me tell you my experience with these Zenith's The original problem is the picture tube shorting out and caused this problem. If you replace the transistor the same problem could arise again because of the tube and it could even knock out the main board power supply. I have seen this happen. And I have put in the transistor and no problem. You can get one at the Radio Shack by taking the bad one out and get them to cross reference it for you. All Zenith transistors have a prefix number (not on the transistor) which is 121- (with the dash!) and the number on the transistor The new one must go back in the way it came out! I recommend someone with electronic soldering and desoldering experience. Hope this helps
Posted on Dec 30, 2007
SOURCE: fly back lines
Check the connector of the crt maybe got a resistor open or a transistor in short circuit.
Posted on Jul 06, 2008
Hitron modem
Could you please provide me the model number of your Hitron moden is that Hitron Technologies CVE-30360 Router or different one ?
Mar 12, 2014 | Computers & Internet
Hi, I had a problem with my Sony CRT television.
The faint background lines are vertical flyback lines. Start your diagnosis by turning the brightness and contrast controls to minimum and view the screen in a darkened room. If you can now see a raster with horizontal lines visible then it is likely that the tubes A1 screen voltage is excessive. The screen voltage is usually within the range of 400v to 600v. Adjustment for this is often part of the flyback transformer. Check all high value resistors
in the screen and focus circuitry. Some of these reistors may be
built into the flyback transformer. As the picture gets brighter the beam current increases, this will eventually cause the X ray protection circuits to trigger shuting off the set. A fault in the video drive circuits to the cathodes of the tube will cause similar symptoms but usualy results in a predominance of one colour, ie
bright red, blue or green raster with flyback lines.
Oct 20, 2013 | Sony KP-53HS10 TV
How can I go to av mode without remote control in samsung hitron tv
Yes, you change your channel to '00' or go up to '101' and then press up button on tv then it will automatically comes to '00'
Nov 08, 2012 | Samsung Televison & Video
My TV, HITRON CS 6404SV gives a mild whistling noise when switched on.
The mild whistling noise is usually caused by a fault in the HV circuit of the tv. My money would be on the flyback transformer. Since this is un-doubtedly the most dangerous repair that can be performed on a CRT tv, I strongly suggest that you seek the assistance of a qualified tv tech. I am talking about a part that generates 25000V.
Dec 05, 2010 | Samsung Televison & Video
Samsung hitron Remote
If Samsung 00026B remote is compatible with 0026b remote, any one tell me
Feb 24, 2009 | Samsung TV Remote Control
Samsung hitron
i have an old solo tv - visa electronic remote that i would like to set up for my Hitron tv (samsung), but i lost the my book to help me set it.
Dec 06, 2007 | Samsung TV Remote Control
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
