Question about Universal Supco PRO ERP Washer Washing Machine Pump LP116 TJ90LP116 ER3363394
Hoover DYN8163D8P pump just hums !
Old pump just hums, fitted new pump ,same fault it just hums, will turn ok by hand ?
  • 64 Answers
If nothing wrong with pump, check drive motor
Posted on Mar 31, 2014
How to get to motor on hoover vhc691b?
Very rare a motor fails on a hoover drier normally its the capacitor that fails. you can hear the motor humming but the drum wont rotate to proof its the capacitor turn the machine on press start listen for the motor humming open the the door of drier turn the drum by hand fast then shut the door as fast has possible then the drum should start going around . then this proves its the capacitor fault you are doing the job of the capacitor giving the motor a start .
May 16, 2014 | Hoover HDC6 Electric Dryer
Dyn8163d8p
Has the programme finished but the door remains locked? Turn the machine to OFF to reset the machine and this will allow the door to open.
Then look at this > Has the programme finished? Is the END light illuminated? If not the programme is not complete. Has the door locked light gone out? If not wait a further couple of minutes and the light will go out and you will be able to open the door.
If nothing happens and door still locked, and you live in the UK you need to ring this number > Phone 08444 995 599 to book your repair
E05 is a fault on the temperature sensing circuit. You need to check the wiring to the temperature sensor at the bottom rear of the tub. (circular item near the element). Unplug it, check the terminals and the wiring, check the connector on the sensor. If all ok, take the sensor out, clean it and refit it. Try the machine again. If the fault persists and the wiring and connections are good, you'll need to try a new sensor. Check it out, see how it goes and get back to me if you need more help Hope this helps
May 12, 2014 | Hoover Washing Machines
Does anyone have a user booklet for a Hoover washing machine DYN8163D8P please I just need to know how to turn it on
have you been on the hoover web site you will need your model no all so you may need the siral no
Jan 02, 2014 | Washing Machines
Brand new motor replaced old pb4. After installation it just hums and does not pump. Before installation it works fine without water going through? Any body know what is wrong?
Double check the wiring installation. One wire wrong will stop it. Don't let it hum! Compare old motor to new, are they the same voltage? Can you rotate the motor by hand? It should be free.
Oct 26, 2013 | Polaris Pb460 Polaris Booster Pump...
I have a A O Smith SN 1152 pool pump. The motor just hums when the switch is turned on. The pump is eight years old and I have had no problems until now.
Remove the 4 fasteners that hold the pump head onto the motor and try to turn the motor shaft by hand. If it turns freely, apply power and see what happens. If it turns Ok, then your problem is the pump head not the motor. If the motor does not turn by hand then it needs to be replaced. If it turns by hand but not when power is applied, you may get away with replacing the bearing in it.
Nov 18, 2010 | A.O. Smith SQ1102 Pool Pump Motor
Was using the SteamVac and it just stopped doing
Bad news! The humming is the pump so it is still good, but that means either the ac to dc converter is bad or the motor went up. The good news, neither would be your fault.
Apr 16, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Fisher & Paykel intuitive code 37
As a serviceman for 18 years I have seen this numerous times.
The fault sounds like the motor control module.. Assuming your test on the pump windings was ok..?
Nov 12, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Hoover wind tunnel cyclonic U5780900 1 year old. brush will not turn. too much slack in vbelt when in carpet position. Belt is good
Well, the V belt is normally fairly slack until the handle is dropped below 45 degrees, which is when the belt tensioner assembly drops into place. If turning the brushroll by hand when the vacuum is in this position fails to rotate the self propel pulley, the tensioner is not functioning properly and will need to be replaced.
Also ensure that the brushroll can spin freely by hand, as these have a tendency to melt at the ends and seize the brushroll. I have also seen the groove that the v belt fits into melt itself out of round, which can cause the same symptom as you're describing.
Keep in mind as well that while the rubber belt may appear to be ok, it does have to be replaced every 3-6 months whether it breaks or not. Even though it hasn't broken, if you were to hold it up against a new belt, you would see that the old one has stretched significantly: which can decrease the machine's ability to rotate the self-propel transmission pulley and, in turn; the brushroll.
Feel free to contact me with any further questions.
-R
Oct 01, 2008 | Hoover Vacuums
Dishwasher stopped washing just making a humming noise
humming noise is the wash pump energised but not turning.
this can be:
wash pump seized up
foreign object stuck in the pump impellor.
pump capacitor faulty - a common fault. if pump turns freely by hand but not when energised, then the fault is probably the pump capacitor - cheap part
Aug 22, 2008 | Whirlpool Dishwashers
Universal Supco PRO ERP Washer Washing Machine Pump LP116 TJ90LP116 ER3363394 Logo
32 people viewed this question
Top Universal Washing Machines Experts
Are you an Universal Washing Machine Expert? Answer questions, earn points and help others
