Question about Toshiba 32RV635D 32" LCD TV
POWER BUTTON NOT WORKING
The power button is not clicking when pressing to turn on the tv
    Top Expert:
  • Toshiba Master
  • 74,136 Answers
Main power supply regulator [SMPS] board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Posted on Mar 31, 2014
Mitsubishi wd-73738 turns itself back on
It sound like the remote is powering off the cable box but not the TV. The remote control may need to be reprogrammed to the TV. When you press power it may only power off the Cable box. At that point, try pressing the TV button on your remote and then Power. If it does not power off the tV after pressing the tV button, the remote may need to be reprogrammed to the tv. Cable companies usually have the codes needed to program their remotes to the TVs.
Jul 09, 2016 | Mitsubishi WD-73738 73" 3D Ready DLP HDTV...
How to shut off manually
UN55D6400UF TV Will Not Power Off If your TV is on but will not power off when you press the power button, you could be having an issue with your remote control or a faulty circuit inside your TV.
To determine the source of your problem, follow these steps:
  1. Power the TV on if it is off.
  2. Unplug the TV from the wall outlet for 30 seconds, and then plug the TV back in.
  3. namo_fileview.jsp?type=nfs&pid=decisiontree&did=57355&cid=yokn68wxkhym@namo.co.kr&sep=%7c
    1. Press the POWER button on the remote control.
    2. [img src="http://support-us.samsung.com/cyber/namo/namo_fileview.jsp?type=nfs&pid=decisiontree&did=57355&cid=79HKC8BOY9YC@namo.co.kr&sep=%7C" height="51" border="0" width="50">
      • If the TV powers off when you press the POWER button on the remote control turn the TV back on continue to Step 4.
      • If the TV does not powers off then there is a problem with the remote control. Click here to go to the Remote Control troubleshooting section of this guide.
    1. Press the POWER button on the TV.
      • If the TV powers off with the remote but does not power off with the power button on the TV there could be an issue with the touch sensor on the TV. Before setting your unit up for service try these two things.
        1. Try sliding your finger accross the power button.
        2. Have other people try using the touch buttons on the TV.
        3. If either of these two options work then there is not an issue with the touch sensor on the TV. There are many variable that can limit the conductivity of a persons fingers. The conductivity of your fingers might not be enough to easily control the touch sensor on the TV.
        4. If the TV does not power off when you press either the POWER button on the TV or on the remote control, then the TV will need to be serviced. Click the Create online service request button below to have the TV repaired.
Mar 26, 2014 | Samsung UN55D6400 - 55" 1080p 3D LED LCD...
I need a code to program a remote for a sanyo tv
all you need to do is press the code search button until the red light is on then press tv button...then point the remote at the tv and continue to press the power button until your tv turns on/off...then press enter. Be patient...it may take any wear from 2 or three clicks up to 100 clicks....but it will eventually operate your television....be careful though...if you press the power button even 1 more time after it turns your tv on or off...you will have to start all over....Good luck! and if this doesnt work..you can always buy a universal remote from any department store..some are as cheep as 5.00. and they all come with program guides.
Nov 03, 2011 | Sanyo DP42849 42 in. HDTV
I have a Philips 52PFL7422D/37 52" TV. For the last year now the TV will make a clicking sound like it is turning on but never does. After a couple of seconds to a minute the TV makes another...
I have the same model and the same problem... I am told the power display board is is the issue and may need to replacing. New board costs around $80,or a bad capacitor depending on your paitence.
Nov 23, 2010 | Philips 52PFL7422D/37 TV
The TV will not turn on.
I have the same problem, push button to turn on tv but it only does a click like it is going to turn on and then another click bit it wont turn on. Finally a red light is just blinking.
Any suggestions, is there a freeze button or code that I need to push.
Jul 03, 2009 | RCA HD52W140 52" Rear Projection...
I need a service mode code for TV "RCA" J20531BL, chassis CTC176I2! "Menu"(hold down"), Power, Vol+ not working!
If you are asking how to enter service mode in tv...procedure is like that...
1. TV turned on
2. Press and hold the 'Menu' button at the tv.
3. Press and release the 'Power' button.
4. Press and release the 'Vol up' button.
5. Release the 'Menu' button.
6. The initial security parameter displayed will be 'zero' Change this to '76'.
You are now in the Adjustment mode
For more info, click THIS we blink.
Sep 18, 2008 | Televison & Video
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
I have a Sole Control SC-545 and would like to know how to program so will work with my Zenith TV
CURTIS Universal Remote Control setup
  1. Turn ON your TV.
  2. Press FUNC button.
  3. Press TV button.
  4. Enter 2-digit code No. (either 01 or 05)
  5. Press TV button.
  6. Press POWER button to confirm.
Search Mode Method
  1. Turn ON your TV.
  3. Press TV button.
  4. Repeatedly press POWER button until TV go's OFF.
  5. Press TV button to confim.
Red LED will blink 3 times if wrong input is detected.
Jun 26, 2008 | Televison & Video
Power button makes a click, click sound
The sound is coming from a failed flyback auto transformer. You will need to replace that.
Jun 14, 2008 | GE 25GT507 25" TV
Toshiba 32RV635D 32" LCD TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
