Question about Refrigerators
Samsung srl38nmb I have a Samsung SR-L38NMB fridge/freezer combo which starts up, then stops with led light 5 flashing (has 5 led's in top panel). Have replaced the main pc board AND relay switch, same thing. Please assist ?
SOURCE: Samsung RCS21DCNS Side by Side
probly the evaporator coil in fridge all frozen up you need to pull all the back out inside the fridge section and defrost with air drier
Posted on Sep 21, 2007
bobotfel
  • 236 Answers
SOURCE: samsung fridge RS2630SH, side by side, icing up on freezer.
You have to pull out the sensor from the board and test with tester, both sensor should read the resistance of 10,000 to 20,000 ohms. The reading that you show is very low it means that the thermistor is out of range and need replacement.
Posted on Mar 08, 2008
  • 3 Answers
SOURCE: Problems with my samsung fridge/freezer SR-L36/SR-L39
is whisker growth like ***** hairs?
Posted on Jun 04, 2008
SOURCE: Samsung twin cooling fridge/freezer model
My husband removed the covers inside the fridge which contain the lights and the cooling fan. The problem was the icing up of the cooling fan (which circulates the cold air) preventing it from rotating also the drain hole at the bottom of the fan was also iced up.
The fridge was switched off at the wall socket whilst working on it. After removing the panel containing the fan and unplugging the connection take the panel outside. A hair dryer was used to thaw out the ice. The drain hole was made slightly bigger to hopefully prevent this happening again.
When panel is screwed back in fridge make sure the black sealing tape is in position also take care not to damage cooling pipes which are attached to the evaporator unit. Defrosting a couple of times a year might prevent this happening again. It seems to be a design problem which im sure the makers will be aware of and modify future appliances. Q Will the makers repair this problem free of charge even if the warranty has expired !?
Posted on Aug 01, 2008
SOURCE: Samsung SR-L39 fridge freezer switching off
tarsia upatvane
Posted on Aug 30, 2008
Freezer temp light flashing and freezer and fridge have both defrosted. What the matter with it
Seems like you have Problem in Defrost timer (fixed near the Compressor or may be on the top back-side of the refrigerator). Replace it, problem will be solved.
Oct 02, 2015 | Samsung Refrigerators
Samsung srl38nmb
We found that the problem was the sensor that regulates the evaporator flap. Replace that and it should cure the problem. Each light represents a certain sensor in the fridge, if that sensor isn't working, the according light will flash. If you go to a Samsung agent, they will be able to assist you.
Nov 13, 2013 | Refrigerators
Hi I have a samsung SR-L38NMB no frost cooltech dynamic first the fridge went off and the number 5 flashed had the pc board replaced now number 3 and 4 flashes.
Aug 06, 2012 | Refrigerators
Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Jun 28, 2009 | Refrigerators
Flashing freezer temp on Samsung SR S22
how to remove cover from twin cooler samsung sr-s20-s22
Mar 25, 2009 | Freezers
I have a samsung RS21DCNS fridge but i have jus had apower cut for 10mins and now the fridge is not working. the lights are coming on inside but there is nothing on the contol panel and none of the buttons...
unitl you either cleanr the code or repair the fault that is what you see.the fault is the ice maker sensor is not reading correctly. check the plug connections for the sensor. if you would like you can contact me and i will help you with this problem.
Jan 17, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung SRS2028CVW fridge freezer
check out this samsung diy repair channel on youtube ... some great stuff on samsung
samsung fridge freezer problems
Nov 02, 2007 | Refrigerators
Samsung model SR-L38NMB refrigerator
that problem very likely is the control board. there is another brand of fridge in S.AFRICA THAT DOES THE EXACT THING OF WHICH THE BOARD HAS TO BE CHANGED.
Mar 15, 2007 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
104 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
