Question about LG Televison & Video
My envision model L32W961 volume goes from normal volume to blasting then back to normal. it started after lighning hit a tree beside the house.
Volume randomly goes up and down then settles on where you put it for a while then goes randomly again
  • LG Master
  • 722 Answers
Hi Harry,
Lightening in the surroundings has been known to cause this type of damages to tv sets. Please have your set checked by your local TV Tech. Memory chip on the main board which stores the data for all the operation seems to have gone bad. There is nothing you can do about it yourself.
Good Luck
Posted on May 24, 2015
    New Friend:
  • 68 Answers
Anytime and electrical storm is close enough to hit a tree, it sends all types of energy through everything. Did you have a surge protector on the TV? Sound to me like the TV has internal damage and needs repair or replacement. Have you tried to simply unplug the TV and wait 30 seconds and plug it back in. This sometimes will reset the microprocessor.
Posted on Apr 18, 2014
5 Suggested Answers
maatmartin7
  • 1229 Answers
SOURCE: What is the problem with
There is nothing wrong with your TV. The loud commercials are to catch your interest before you leave the room for another snack or beer. You are not alone here, all other brands of TV will act the same. You may opt into the menu settings and seek an automatic volume control for commercials. Many TVs will have one. Not all, but just some. Thanks for asking and show a few hands of support!
Posted on Mar 26, 2011
  • 6 Answers
SOURCE: Volume on my Toshiba TV 32AV502U goes up on its
First off, take the batteries out of your remote to see if it is a problem with your remote, if it is I would buy a new universal remote and try that. If none of this works then the problem is with your tv itself. Either the volume button on the tv is broken and works on its own, or the tv is having programming errors and you will need to have it fixed.
Posted on Jun 26, 2011
SD Tech
  • 14553 Answers
SOURCE: Volume goes all the way down on its own on my sylvania lc320slx
The volume down button/switch on the set is defective
Posted on Apr 06, 2012
  • 537 Answers
SOURCE: Samsung TV Version CZ04 volume reduces itself and whenever goes back to normal
Your volume goes down or up depending on the demand (number of viewers} viewing the channel at any given moment. That is mormal.
Posted on Nov 28, 2012
Envision Series L32W961. Crashed. Unsynced video/audio. "please Wait" on screen. Off=10 blinks. What's wrong?
Sounds like corrupted firmware. A firmware update might be necessary. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 24, 2015 | AOC Televison & Video
Volume up then pic gone
You've got a bad solder connection,or broken foil line,s on the pcb (printed circuit board1.gif).Narrow it down by pressing in different places,or use plastic or rubber tip.If not,then you got a shorted load on this fuse and diode.do you have a schematic,whats at the end's of this circuit.D represents a <Diode> not a transistor.
Jan 28, 2008 | Mitsubishi WT-46807 46" Rear Projection...
I recently updated stereo software in my 2013 SX4. Now when I start the car, about 5 seconds in the volume is blasted for a split second, then back to normal. I tried turning radio off before shutti
take it back , the magic is broken.
welcome to the digital age.
no analog radio can do that. (scratchy pots sure)
tell em'
the fix is worse that your cure.!
Oct 27, 2014 | 2013 Suzuki SX4
L32W961 screen goes black then comes back on. later when video comes back sound does not
That is definitely a manufacturers error.
If it has been less than a year since you purchased it i would contact them.
They will send you to a service center. If it cant be fixed they will replace your tv.
It is all covered by them.
If it is past a year its honestly not worth fixing it,
You can find name brand 32 inch tv's for less than 250
while fixing it would cost around 150.
Mar 30, 2014 | Envision L32W761 32 in. LCD TV
While watching tv the volume goes up full blast all by its self
bad switch... easiest fix is to just disconnect manual controls and just use remote. buttons go bad from lack of use and do this pretty often.
Feb 09, 2014 | Envision L32W761 32 in. LCD TV
My radio volume goes from full normal to full blast when it wants. I have to turn it off to save my speakers.
I would replace the radio. Especially if its stock. Look on www.craigslist.com and www.ebay.com for a replacement. You should get a good deal between the two.
May 08, 2009 | 1995 Dodge Ram
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sounds like you have a jammed / shorted out button on the control panel... Try un-plugging the tv, and then unplug the "button panel" on the front of the tv...see if you can turn the tv on with the remote. Sometimes if one of the buttons gets shorted, it will "lock" the processor from doing ANYTHING else, as it thinks you are holding down the defective button. If this works, simply have the defective switch or control panel replaced, or just leave it unplugged and use the remote only! Hope this helps!
Jan 03, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Televison & Video Logo
98 people viewed this question
