Question about Velux VSE-C06-2104-RM Copper Frame VSE 21-1/2" x 46-1/4" Electric Vent
Velux blind problem stuck
My Velux blind is stuck all the way down. Any ideas on how to open it up again ?
    Master:
  • 560 Answers
Check the wires to the blind mechanism. Power might not be getting to it.
Posted on Jul 27, 2014
How to fix a velux exterior shutter which is stuck half open, half shut
I am a Velux installer I am assuming you are discussing an exterior shade on the outside of the unit rite?
Mar 31, 2014 | Velux VSE-S01-2104-RM Copper Frame VSE...
How do I get window out of car door
got to take the door panel off to access the down window not a hard fix Chrysler Plymouth and Dodge all have that problem its a little plastic tab that break causing the window to fall you will need the window regulator.
Sep 21, 2012 | 2002 Dodge Caravan
I have a Canon PowerShot SD1000 and it turns on, but the screen is blank. It will upload any photos taken (although you can't see what pics you take), but even then you have to click the button on the...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife happens to own a SD1000. Great little camera, but it's prone to stuck shutter every once and a while. Easily fixed each time though by simply opening the battery door while on, and gently flicking the lens barrel a few times. Again, see the link.
May 31, 2011 | Canon PowerShot SD1000 Digital Camera
The screen on My Canon Power Shot SX 120 IS camera will not show any images when I turn it on. It simply shows black, if I take a picture, the picture will record on the memory card but it is also just a...
Nov 18, 2010 | Canon PowerShot SX100 IS Digital Camera
When camera is turned on no picture appears in the viewfinder or on the LCD screen, it remains black. The batteries are new. I can access the menu, change settings. Everything works but there is no image...
Sep 04, 2010 | Canon PowerShot S2 IS Digital Camera
New pictures I am taking with my camera are showing up completely black. I can view previously saved pics on the SD card on the screen, but any new pics only come up black. Any ideas what this could be?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Feb 21, 2010 | Canon PowerShot S2 IS Digital Camera
I have a powershot s3 is and when I turn it on I have no pic. It just started doing this and last time I hit the display button and the pic came up. It will show images of pics that I have already taken....
Nov 08, 2009 | Canon Cameras
Black LCD
Oct 01, 2009 | Canon PowerShot A630 Digital Camera
Sediment in lines -Bosch Tankless Water heater
I would recommend a simple sediment filter housing be installed on the main water line coming into the house. Material cost about $100. Have a plumber install a bypass loop so you can just shut off 2 valves when you need to change it. I always install one with any tankless heater as cheap insurance against such a problem. As far as adding something to clean the lines I would refer to the manufacturer's instructions and use only what they recommend in order to preserve your warranty. For a solar water heater I prefer Velux.
Please rate if this helps-
Mar 28, 2009 | Bosch & Tankless LP Hot Water Heater
Velux VSE-C06-2104-RM Copper Frame VSE 21-1/2" x 46-1/4" Electric Vent Logo
1,144 people viewed this question
Top Velux Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Velux Hardware and Accessory Expert? Answer questions, earn points and help others
