Question about Raymarine GPS
E 160 keeps beeping gps - Raymarine GPS
Keeps beeping and displaying approaching turn
The "Approaching Turn" message is coming from an active navigation on your device. To turn it off, press and hold on the left side of the bezel (GPS), then press the lap/reset/quit key to exit the compass screen. You should then be in the GPS menu. There should be an item in this menu titled "Stop XXXX" where XXXX is "Navigating", or "Back to Start", or something like that. Select that option, and it should stop the navigation, and eliminate the "Approaching Turn" messages.
Sep 29, 2013 | Garmin Forerunner 405 Handheld GPS...
My ups won't stop beeping
The beeping on your ups is the sound of an alarm it will come on when starting up due to slow start circuit, there are a reset switch on the front display press once and beep will despair.
Aug 19, 2012 | Computers & Internet
Keep blowing fuses on gps 21 pro
Might want to list it in another area. If its blowing fuses you know you have something wrong--if it (I presume it does) has an external unit for power the problem is there. Also be aware not all fuses are the same--a generic fuse like radio shack etc may even if correct amperage pop for no reason.
Either a incorrect fuse (not talking about wrong amperage) or a short in the unit--one or the other.
Jun 15, 2012 | GPS
My Packard bell pc won't turn on an keeps making a
The number and timing of beeps will tell you what's wrong. You'll have to find the motherboard manual to find what the beeps mean though. Would be worth taking the RAM chips out, blowing any dust away and putting them back in.
Apr 20, 2012 | Computers & Internet
Computer wont boot, the fans keep running
Does it come with any beep sound, because beep sound clarify the fault. Check it by the way.
The list is given below.
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine
Two Beeps POST/CMOS Error
One Long Beep, One Short Beep Motherboard Problem
One Long Beep, Two Short Beeps Video Problem
One Long Beep, Three Short Beeps Video Problem
Three Long Beeps Keyboard Error
Repeated Long Beeps Memory Error
Continuous Hi-Lo Beeps CPU Overheating
best of luck!
Mar 07, 2012 | Compaq Presario S4040SE - (refurbished)...
Can I enter GPS coordinates into a gamin zumo 550
Turn on Zumo. Select WHERE TO. Depress ARROW DOWN beneath ROUTES icon. There, revealed, are 5 additional icons, one of which is COORDINATES. There are more different choices of ways to enter coordinates than you're likely to learn what they are in a lifetime.
Happy motorcycling. Keep the shiny side up.
Patrick
Nov 05, 2011 | Garmin zumo 550 GPS Receiver
Lms-332c lowrance fishfinder unit turns on as soon as the power wire is plugged in and goes to blinking pinging beeping between hi and low light settings constantly. All other features seem to work fine. A...
Hello
I don't know whether you have made a factory reset to this device or not. If not, set it first and see whether it helps you. To make it factory settings:
[1] Press 'MENU""MENU" (down arrow to system setup) "ENT" (down arrow to RESET options/ ENT
[2] The unit asks if you want to reset all the options. Press [<---] to YES and then ENT. All options are reset, and the unit reverts back to map page at 4000 miles zoom range. Any recorded sonar logs of GPS data will be unchanged. OK.
Sep 23, 2011 | Lowrance LMS-332C GPS Receiver
Garmin fishfinder 160 blue . no powerup
I have a 160 blue also, and this morning I had the same problem. I called tech support while I was out on the water but no help. When I got home I double checked my connections on the battery minder/selector and the fuse panel. My GPS worked fine but the FF only beeped, like it had low power and the display wouldnt come up. It came up once for about a second and then faded earlier on the water. I pulled the power and ground connections from the fuse block and put them directly on the battery, it came right up. I now run the FF wired straight to the single battery and the GPS and other items on my other battery.
Hope it helps.
1998 19' Proline Center Console
"Lucky in Love"
CD
Mar 19, 2009 | Garmin Fishfinder 160 GPS Receiver
Reset the garmin 405 and now it just keeps beeping
Sorry...I don't have a solution because I'm having the same problem with my Garmin FR60...just took it to a watch repair shop, and they can't fix it. Any solutions?
Mar 01, 2009 | Garmin Forerunner 405 Handheld GPS...
Beeping
The beeping could be low batt. check to see if charged.
Dec 29, 2007 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
13 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
