Question about harbor freight tools THUNDERBOLT MAGNUM SOLAR Conversion Connector for 45 Watt Solar Panel Kit
Using solar panel to power small appliance
What appliance will 45 watt solar panel, deep cycle marine battery and an invertor power. power
    Habit-Forming:
    New Friend:
  • 14 Answers
Solar panel installation is an unique power source, you can get a lucrative rate with the electric company. Since the use is smaller, and house is energy-efficient, you can settle on low rates.
Solar Kits Solar Water Pumps Solar Inverters South Africa
Posted on Oct 20, 2015
  • 3 Answers
If you guys want a free way to get your electric and natural gas supply for free in PA,NJ,CT,NH,ME,RI,NY,MD,OH,ILGA.,Texas .Get you Energy company to pay you every month too. Call me : leave a message I will get back to you ASAP .i will be happy to help .People helping people .Scott at 267-549-3746.
Posted on Jun 08, 2014
Can I connect my UPS with my battery which is connected to a solar on the roof? what will the voltage output to appliances?
The UPS has a stated output, that does not change. It is most likely 115vAC. If the UPS does not have enough charge, it will warn you. If you are asking if you can connect your solar direct, no, do not! The UPS is not a charge controller or regulator which is what I think you are asking. Summary: Solar to UPS to appliance is ok. If you exceed the amperage of the UPS, again, an alarm will sound or not work at all. for instance, you will not power a microwave this way.
Aug 01, 2016 | Apollo 1650ETL Swing Gate Motor 20 Watt...
How many watts is 6kva
Six KVA is the same as 6000 watts. As you can see, the appliances have to be totaled up to the amount of 6000 watts to see how many can be used. Each device has its own wattage on the manufactures label and it is usually different for different appliances.
Sep 13, 2014 | Computers & Internet
I am connecting a 1000w Cobra Power inverter to a deep cycle marine battery that will be used to run small appliances while camping. How do I properly connect the inline circut breaker for maximum safety?
The breaker goes in in series.
So, that means (for example) you remove the hot wire to the unit, from the positive battery power source, and hook this wire to one side of the breaker, then connect the other terminal to the positive battery power source.
This will stop current flow if anything over 40 amps happens on the line.
You actually can hook the breaker anywere along the circuit, but the closer to the power source, the better you are protected.
Mar 02, 2011 | Inline 40 amp. In-Line Circuit Breaker
2006 Buick Lucerne/ 10 mo.dead battery told i need to put 1000 ml. a mo. to keep battery????
That is not necessarily correct-if the car sits all the time, parasitic drain on the battery will eventually kill even a new battery. Telling someone that a car has to be driven 1000 miles a month to maintain the battery is not a solution-if you don't drive alot, get a trickle charger ($good one is $30, one that works can be found for $10) that you can plug in and keep hooked up to the battery to keep it fresh. Another way is to get a solar panel charger (1 1/2 watt, about $20 at Harbor Freight) and put the panel on the dashboard, and the other end into the cigarette lighter socket in the dashboard. A third solution is to buy a deep cycle battery (Optima) that can be fully drained hundreds of times yet will recover and work properly-these are expensive ($175), but out perform conventional batteries that die if fully discharged a few times. You could also install a remote starter and periodically start the car, letting it run for 15 minutes-about $200
Jan 25, 2011 | 2006 Buick Lucerne
I have a 1000 Watt Inverter, along with a regular car battery when the electricity goes out; Question: Can I use the 1000 Watt inverter and connect a 100 amp, deep cycle battery? I use regular house...
Yes, just be sure connections are heavy enough wire, and obviously the inverter uses 12 vdc input. Hook jumper wires positive to positive, negative to negative, on all 12 volt batteries. Deep cycle batteries will work better than car batteries. Just remember, when re-charging them, that they last longer when charged slowly, so don't use a high amp setting on charger and to monitor them closely, and do it in a well ventilated area, away from any ignition sources.
Apr 14, 2010 | Schumacher 1000 Watt Inverter with 2 GA....
I am building an off grid cabin but will need to meet code providing all electrical components as per the latest NEC. I will be using a 4100 watt generator for my initial power source but plan on...
I think he cost of the panel and breakers would be the cheapest thing on your list. Your 4100 watt genny is tiny for a whole house, and if you are planning on a solar set up, you will need to convert to dc, so, I take it your 4100 genny is used to charge the battery bank? Then the panel will not need to be anything but a small disconnect for the genny, basically one of those things that prevents the current from flowing back into the source, which you don't have. I would talk to the building dept., they may not want to take liability, and make you get a contractor to figure something out. All your appliances, and lights will be 12 volt, most motors are 12 volt anyway, they are just transformed to 12 volt from 110 current, and I don't think you will need breakers for 12 volt stuff. You could look at some camper supplies, boat stuff, they all run 12 volt appliances, and lights.
Feb 12, 2010 | Your One Source Homeline Load Center, 200...
Is this inverter powerful enough?
You are right. This is not enough to operate this freezer. You are going to need a bigger invertor it get it to work properly 900 or 1000 watt should be efficient even though it is not the best way to run the unit. If the unit has a problem you would be replacing the inverter all the time. Just FYI
Feb 20, 2009 | Black & Decker Husky 750w Power Inverter
Tech Question
Automotive batteries are usually adequate for small inverters, (< 500 Watts). When used in a car, we suggest you run the vehicle of your engine occasionally while operating your inverter. If you use the inverter while the engine is off, you should start the engine regularly and let it run to charge the battery. Deep Cycle (marine) batteries are best for larger inverters as they are designed for several hundred charge/discharge cycles. (Automotive batteries wear out much more quickly after heavy discharge).
Aug 27, 2008 | Whistler Power Inverter
Pls i need an answer
Solar panels come in different ranges of wattages.Add up the wattage of different solar panels you get e.g. Ten 100W solar panels will give you a 1Kw solar system.
Jul 11, 2008 | Sun (PEX75030) 15-Watt Power Supply
harbor freight tools THUNDERBOLT MAGNUM SOLAR Conversion Connector for 45 Watt Solar Panel Kit Logo
1,603 people viewed this question
Top harbor freight tools Renewable Energy Experts
Greg Scott
Greg Scott
Kelly C
Kelly C
Level 1 Expert
Brian Lee
Are you a harbor freight tools Renewable Energy Expert? Answer questions, earn points and help others
