Rx8 bose audio cd player shows "check cd" on all cd,s
CD player will not play any CD,s,unit shows "check CD" whenever any CD,s are inserted,have tried at least 10 good CD,s that are like new and play with no problem in other players,appreciate any advice please.
    Champion:
    Habit-Forming:
  • 239 Answers
Laser dirty or faulty
Posted on Jul 12, 2014
SOURCE: malfunctioning cd player
Did you try taking out that lttle circle thing that you put your cd into.Well,take that out and then clean it.Then,insert it back and it should play your cd
Posted on Dec 15, 2007
SOURCE: cd player not playing some cds: denon cd player ucd-77
It's not the cds that are the problem as they work in other cd players. Its seems to be the denon cd player itself that doesn't seem to be reading the cds.
Binap
Posted on Jan 31, 2008
SOURCE: Bose Wave Radio w/single CD player on top
My Bose Wave Radio/CD developed this problem about a year ago. I don't use the CD player much and kept the unit clean. The disc spins but, the system does not read it. Cleaning the lens with cotton did not help.
Read that Bose charges $75 to fix this problem.
Posted on Sep 24, 2008
  • 6 Answers
SOURCE: Multi cd bose player will not eject 4th cd.
OK, this problem is everywhere with the bose cd changer addon. Many people can still play a cd with the top one fine, but cannot get cds to eject and/or read in 3 disc changer. My friends mom had one and after finally hearing back from bose, they said send it in with $100 to get fixed. If you have to send in and you value your cds, you may want to open it up and get them out. Use this at your own risk, there are no warranty stickers I saw and there will be exposed voltage, shock hazards, etc.; so if any of this worries you, stop here. By proceeding, you are admitting that you are capable of minor repairs and therefore I'm not responsible for any damage or harm caused. OK, here it is:
Unplug everything. On the bottom of the cd changer unit are 4 screws (silver ones recessed about 3/4" or so, use phillips screwdriver) to remove. Turn unit upright again and lift cover slowly straight up. In the front of the unit is a ribbon cable you will want to disconnect that goes to the cd 2-4 lights. Take note which side the dark blue tab is on and gently pull out by dark blue tab, rocking side to side if needed) You can then pull cover all the way off and set aside. Plug power into back of cd changer (careful not to touch anything inside) and see if the cds want to eject now. If not let the initializing process finish and repeat. This time see if you can gently help the cd out. The problem may also be the spindle not lowering, you can look for this movement during the last step of init. process. Work your way fom the top tray down removing the cds gently, remember we open it up because they were valuable to us, don't destroy them now, and don't ever use anything that could possibly scratch either top or bottom of the cd, use edges instead. Start to replace cover making sure to reattach ribbon cable back into socket the same way it came out. do not force too hard or you may crease and break ribbon. Gently replace cover and grab both top and bottom to turn over. Replace 4 phillips screws making sure not to overtighten or cross-thread. Now you may return to bose or just find an independent repair shop in your area, they are usually quicker, more polite, usually cheaper, and best of all, local!
Posted on Oct 28, 2009
SOURCE: I have an Infiniti I35 with a Bose radio/6cd
I have an Infiniti I35 with a Bose radio/6cd changer. and it dont have a display what should i do??
Posted on Nov 18, 2010
Why won't my Acer laptop play compact discs?
Most units are designed to "autoplay" audio CDs when they are inserted. When they fail to do so, it could be because the CD is dirty or scratched and was bot recognized, the media player that you are using to play the CD was not in a state that it could autoplay the CD, or there could be a problem with the Disk drive or PC itself. Whenever a CD fails to play upon insertion, go to the "My Computer" icon (win7 or below) and see if the CD/DVD drive shows a disk inserted. If so, clicking on the drive will often start the playback.
Dec 30, 2014 | Acer Aspire 5100 Notebook
Wave Music system Multi-CD Changer
The unit has a power supply problem, no user servicable parts inside. Bose uses a thermal fuse built into the power transformer. Take unit apart and check for connection issues first, then look for a possible fuse, if none exist chances are it is in the power transformer, contact Bose for service.
Sep 02, 2012 | Bose Wave music system Multi-CD Changer...
CD's will not play. I was playing a CD with no problems and in the middle of the CD, it just quit. I tried other CDs which have worked fine in the past and now I can get nothing to read. It will say...
hi,
just purchase a lance cleaning cd. It will be available in cd shops. insert it in the player. it will clean the lance. after cleaning insert the CD and watch is it reading. If not then the laser pickup unit of you player have some problem. You have to replace the same.
ok
Mar 16, 2011 | Bose & Wave& Music System
Bose Wave System CD does not eject
Just unplug your power supply for 3 hours to reset the unit and to dissipetate power surges.
Hope it may helps;
Jun 12, 2009 | Bose Wave Music System CD Shelf System
2002 gmc envoy bose 6cd player does not play, shows player error
how to remove a bose cd/radio from dash of a GMC envoy slt cd's are stuck inside
Apr 17, 2009 | 2002 GMC Envoy
Failure to shut down when playing one cd.
Try checking the control and try pressing repeat. Maybe its in repeat mode. Oh...fast forward and you won't need to wait to Check it out. Let me know...
pita3obn
Jan 06, 2009 | Bose Wave music system Multi-CD Changer...
Bose multi cd changer wont work, reads "Disc error"
I think there may be a problem with the system (defective parts) - I, too, am having this issue. I am going to contact the BBB - maybe if enough of us complain we will get a recall. To file a complaint:
http://www.bbb.org/boston/business-reviews/department-stores/the-tjx-companies-inc-in-framingham-ma-97/
Bose
PO Box 9168
The Mountains
Framingham, MA 01701
Dec 01, 2008 | Bose & Wave& Music System
Bose Lifestyle CD not eject
There are some repair instructions available at www.AnyoneCanFixIt.com in the electronics section that will show you how to release the CD magazine and fix the problem where the unit will not play the CDs (you will hear a buzzing, buzzing, buzzing, and nothing will load or play).
Oct 11, 2008 | Bose Lifestyle 20 Shelf System
Error code - 05 shows on the screen
I have the same Kenwood unit and mine worked great for over 2 years.... I now get the same 05 error code whenever i insert any cds.... I havent yet been able to find anything about this on the net... I am about to take the cd player in for the extended warranty I purchased with it.... It is by far the best cd player that I have ever owned...............
Dec 01, 2007 | Kenwood Excelon XXV-01D CD Player
 Grubhead
Grubhead
