Question about Velux VSE-C06-2104-RM Copper Frame VSE 21-1/2" x 46-1/4" Electric Vent
Velux blind stuck
I have a velux window in the roof with an exterior shutter which is stuck half open, half shut so it is impossible to open the window or move the shutter. Any suggestions about how to fix the shutter?
The sunroof is half closed and the other half is slightly open. How do I fix this ?
Do you mean that your sunroof is stuck halfway and now won't open or shut correctly? This sounds like a normal setting with the roof half closed and the deflector at the front beginning to close. If it won't move from there first check the fuse but it would be smart to look for silly simple things like a piece of road debris stuck in one of the runners.
Oct 22, 2015 | 2002 Protege Lx Sunroof Motor
Velux blind problem stuck
Check the wires to the blind mechanism. Power might not be getting to it.
Mar 31, 2014 | Velux VSE-C06-2104-RM Copper Frame VSE...
How to fix a velux exterior shutter which is stuck half open, half shut
I am a Velux installer I am assuming you are discussing an exterior shade on the outside of the unit rite?
Mar 31, 2014 | Velux VSE-S01-2104-RM Copper Frame VSE...
I have a 2004 mini cooper convertible. The roof opens to half way and will then flash red if i want it ti close all the way, All windows shut initally, but now when closing the roof the driver side rear...
I am not sure what you are trying to do. But if the problem is that the roof will only open to the first stage, sun roof, and no further, the problem is the package shelf in the trunk.
If the package lid gets pushed up and is not pushed back to it's normal position, the roof will fail to open completely. If you lift the bottom of the roof at the boot, there are levers on either side to release the bottom edge of the roof, you can make certain that the package shelf is seated correctly. Once the shelf is seated, the roof will open in all of it's glory.
Apr 20, 2011 | 2004 Mini Cooper
The screen of the camera works only for setting and menus, but for shutting photos the screen is black. No more photos could be taken. I seems to be taking photos but all of them are black. But I heard...
And here you go, this should help. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 29, 2010 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S3 IS shutter problem. Shutter does not respond. Screen is black. No pictures are seen. It sounds like it it taking a picture, but doesn't. When looking into lens, it doesn't appear the...
Dec 20, 2010 | Canon PowerShot S3 IS Digital Camera
When camera is turned on no picture appears in the viewfinder or on the LCD screen, it remains black. The batteries are new. I can access the menu, change settings. Everything works but there is no image...
Sep 04, 2010 | Canon PowerShot S2 IS Digital Camera
Viewing screen is completely blank and will not take pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Dec 26, 2009 | Canon PowerShot A620 Digital Camera
Black LCD
Oct 01, 2009 | Canon PowerShot A630 Digital Camera
Shutter is stuck on open position
shutter is stuck half way open and when the camera is turned on it says lens error 0x001110000 and then it shuts off
Apr 30, 2009 | Cameras
Velux VSE-C06-2104-RM Copper Frame VSE 21-1/2" x 46-1/4" Electric Vent Logo
113 people viewed this question
Top Velux Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Velux Hardware and Accessory Expert? Answer questions, earn points and help others
