Question about Dishwashers
Aeg favorit 50860
No fault indicated - inlet water not getting passed inlet solenoid - not sure of what the voltage supply to the solenoid is /should be.
  • 64 Answers
Replace solenoid, if water not getting passed
Posted on Mar 31, 2014
I have a Kithenaide refrigerator and the pressure keeps cutting out on the water dispenser I have replaced the dispenser moyorhe but this did not work I have also replaced the filter twice not sure what...
i WOULD CONSIDER CHECKING THE WATER INLET VALVE FOR OHMS AND FOR LIVE VOLTAGE
AS YOU MAY HAVE BAD COILS
The water inlet valve is operated by line voltage supplied through the ice maker control. Power is applied for approximately 7-9 seconds during the harvest cycle and energizes the solenoid on the valve to allow water to flow.
You can check the solenoid for continuity with a multi-meter. On models with multiple solenoid inlet valves, you will need to determine which portion or portions of the valve are used for the ice maker. You can normally follow the inlet tubing from the ice maker back to the valve. Unplug the refrigerator and turn off the water supply to the valve before working with this part.
(HOW TO TEST INLET VALVE: Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear theclog, it will be necessary to replace the valve (the filter is not removable on most inlet valves). Test thewaterinletvalve for continuity using a multImeter. First, inspect the coil for an indication of it's ohm rating. If no information is printed on the coil, then use the range of 170 to 500 ohms. Set the multitester to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multitester should display a reading that matches the coil's rating or if you don't know the rating then it should fall into the range of 170 to 500 ohms. If the water inlet valve does not pass this test, it should be replaced. If the inlet valve has two coils, test the second coil in the same way (note that they may not have the same ohm rating). The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
Check the tap valve.A bad tap valve-the little device that connects the ice maker's water supply tube to the water pipe-may cause the problem where the ice maker's supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the "self-piercing" type). You can buy anice maker connection kitand do this yourself, or call a repair person or plumber to install an inline water filter when replacing the valve.
Mar 23, 2015 | Refrigerators
Aeg 60870 dishwasher water not getting in. Error code.10
The most common cause of a fault "i10" is closed valve on the water supply line. So this failure indicates a problem with filling of water.
Possible error causes:
Closed water tap, Inlet valve faulty, inlet hose bent, softener system clogged, pressure switch or pressure switch hose obstructed or leaking, wiring from pressure switch to printed circuit board (PCB), wiring from inlet valve to PCB and finally PCB.
Dado
Oct 04, 2014 | AEG Dishwashers
Dado
Oct 04, 2014 | AEG 24 in. Favorit 60870M Free-standing...
Aeg favorit dishwasher not filling with water
Dado
Sep 05, 2014 | AEG Dishwashers
Aeg favorit 40010vi dishwasher won't fill with water
I have a similar issue on oko favorit 50700. I have checked the flow from the inlet hose into a bucket and it really seems ok, so I think maybe a problem at the inlet to the machine? Plea update if you get a fix!
Mar 24, 2013 | AEG Dishwashers
My washing machine is showing IE, meaning no water inlet. What do I do, no water is coming into the washer?
If you set the water temperature to "warm" (turns on both hot and cold water) do you get water? If so this will cut your troubleshooting work in half (if you only get hot water, you can focus on the cold water plumbing).
Check the water supply valve for the washing machine to see if somebody turned it off. If you are in a northern state and the plumbing is in an exterior wall, check to make sure the pipes aren't frozen (it happens to me when the temperature drops below -15° F).
The surest test of water supply is to turn off the supply valve, disconnect the hoses from the washer, put them in a bucket and turn the supply valve on again. If you get full flow from both hoses, check the inlet screens on the washing machine's hose fittings to make sure they aren't clogged with lime or or sediment. If they are clear, you'll need to check for voltage on the water inlet solenoid valves. Full line voltage on the valve coil terminals but no water indicates the valve is stuck shut or burned out. No voltage when the machine is supposed to be filling indicates a controller problem.
Jan 24, 2011 | Kenmore Front Load Washer
Water not entering machine when start button is pressed eevn though pump is working
Check the votage in the inlet valve when the start button is pressed, if voltage is present then the inlet is faulty, can be dirt which can be remvoed and ccleaned orr the valve can be faulty if there is no continutiy test onthe coil.
If there is no voltage on the valve the program controller must be checked for fault.
Sep 23, 2010 | AEG 24 in. Favorit 50740 Free-standing...
Our AEG Favorit Sensorlogic dishwasher has had no power to it
Open the lower front panel and locate where the water inlet hose is connected. Shut the water off under the sink, disconnect the hose at the water inlet solenoid, then put the loose end into a bowl or pan and turn the under-sink valve on slowly. Do you get water flowing from the hose? If so, then check the solenoid water inlet valve for damage. If the coil is ok, the valve part may be stuck closed. It should make a firm 'click' when the timer is set to start the machine (leave the hose loose). If it doesn't click, the coil may be bad, the valve may be stuck, or the timer is not sending 115 volts to the solenoid. Try a new valve first. If still no click, you may need the professional service. Good luck!
Mar 26, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
My AEG 18 in. Favorit 54750Vi has stopped working. It sounds as though it's going to start normally then starts to beep. When I open it the 'Rinse and hold', 'Normal 65*',and 'Intensive 70' indicator...
If for any reason (water leak)the anti flood device at the bottom of the washer is triggered it automatically stops the inlet of water via inlet solinoid and puts the washer in pump out mode. Check the float (polystireene plate with micro switch at the bottom of the washer). Dry any water and determine the reason for water and this should let water in again.
Oct 12, 2009 | AEG 18 in. Favorit 54750Vi Slim-Line...
Drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Dishwashers Logo
71 people viewed this question
Top Dishwashers Experts
