Question about NEC LT35 Multimedia Projector
Dark spot on nec lt35 projector
There is a dark area at the top corner of the projected image.I have been told that it may be the optic base.Will replacing the lamp & it's housing fix this or will I have to replace other parts?
  • 4234 Answers
SOURCE: new lamp but image is dim
This usually means that there is some contamination in the light path. Since many of the mirrors and lenses must be carefully aligned, it is not recommended to have the homeowner dis-assemble +/or clean these. This unit should be sent in for serive, requesting a complete clean and alighment. The unit will be cleaned, any filters changed and the convergence checked.
Dan
Posted on Feb 02, 2009
SOURCE: Nec Lt265 extremely dim
I had this same issue and it was the bulb. We had 2 of the NEC LT265 projectors so we swapped the bulbs between the 2 and it tracked with the bulb.
Posted on Mar 31, 2009
SOURCE: Reset lamp hr feature on NEC projector
Give up chuck. It is futile. Actually looking for NEC number right now. for support.
Posted on Jul 03, 2009
projdoc
  • 2237 Answers
SOURCE: blue haze in top right of screen from NEC mt1075 projector
the light filter on the blue lcd panel is fried due to excessive dust and heat. clean out the projector with canned air. unfortunately, you cannot buy individual parts of the optical engine- you'll have to replace the whole thing. or live with it.
Posted on Nov 17, 2009
  • 32 Answers
SOURCE: My NEC mt1075 projector is projecting a shade of
No. Mostly you need to change the engine. Please take it to service centre
Posted on Jan 26, 2010
Lots of dots on the screen. In light areas they are black dots, in light areas they are dark dots
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.
we supply the new DMD chip,it's life is 6 years, and the price is USD200
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jan 27, 2014 | NEC Lamp for NP215 Projector
Dark spot in middle
A plastic prism between the lens and the lamp is melted. can't find part no. PLNS-A056WJN2
Jun 30, 2013 | Sharp XR-10X Multimedia Projector
The color red is absent when projecting, I am told the board is probabaly shot. Can it be fixed
The red lcd panel or the mirror(s) in the red optical path may have broken.
Feb 27, 2011 | NEC LT35 Multimedia Projector
There is a large dark spot in the lower center portion of the projection area, I have cleaned the external lense and changed the bulb but the dark image remains.
if the spot is circular, check the lamp itself. if it has a flatter edge, chances are your light tunnel has collapsed and needs replaceing. it's not that old, so dell might repair it. but they might replace the entire optical engine, as they may not sell individual parts.
Dec 02, 2009 | Dell 2200MP Multimedia Projector
Canon power shot sd1000 black dot on lens
If by saying the upper right corner of the lens you really mean that there is a dark spot on each image AND the rear display, there may be dirt or dust on the lens itself. Clean the lens with an optical quality cleaner. Do not use paper towels and Windex or the like - as paper towels can scratch the lens.
It is also possible that the dark spot is a "stuck pixel" on the image sensor inside the camera. There is no way to repair a stuck pixel outside of replacing the sensor. Any dark spot (regardless of source) can be edited out by using image editing software. This will allow you to to make the dark spot less noticeable - or practically invisible.
If the dark spot is on the rear display only, it can also be a result of a "stuck pixel" on the display itself. This should not show up an images, but only on the display. There is little that can be done outside of replacing the entire rear screen.
There are other things that can cause these problems, but those listed above are the most common.
I hope this was Very Helpful and good luck!
Nov 20, 2009 | Canon PowerShot SD1000 Digital Camera
I have a BenQ W500 with some dark spots in the image. As far as I can tell, the lenses are clean, and I took out the lamp unit to make sure there was no dust or smudging. How can I get rid of the spots?...
if you can focus the lens on them, they're on the optics somewhere. if you cannot, you may need to replace the fly-eye (diffuser) lens. they tend to fry due to excessive dust and heat.
Nov 17, 2009 | BenQ W500 Projector
I have a viewsonic pj500 projector which has functioned perfectly for 5 years. Now the area around the image area either shows a dark blue with dark stripes and the image area has a yellow cast which seems...
LCD projector 101, your blue device is dying inside of projector. Consider purchasing a dlp based product, they do not suffer from color decay.
Really you are blessed , most lcds last about 3-4000 hours or 4 lamp changes. good luck
Apr 13, 2009 | ViewSonic PJ500 Multimedia Projector
NEC LT35 color problem
If you're trying to project video, then the unit needs professional service. If you're trying to project from a computer, you may have a loose display cable, broken pins in one or both ends of the display cable, or broken conductors (wires) within the display cable. The computer sends its image information as a template of RED image components, GREEN image components and BLUE image components with the projector overlays to create the complete image with blended color values. (The computer also sends HORIZONTAL and VERTICAL synchronization signals, but those don'e affect the color content of the projected image.) That's why I'm suspicious of the display cable, conductors or pins.
Jul 02, 2008 | NEC LT35 Multimedia Projector
HP vp6162 projector spots on projected image
you may have touched the bulb while changing it and minute traces of skin oil are on the actual bulb, with the machine cold, try and very carefully clean the bulb
Jan 05, 2008 | HP VP6121 Multimedia Projector
Open Questions:
NEC LT35 Multimedia Projector Logo
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
