Question about TP-LINK Computers & Internet
Yellow star mark in laptop wifi
I have a TP-LINK TD-W8901G router. some of my office laptops are connected nicely, but only two specific laptops are unable to connect through wifi. there is a yellow star mark in wifi signal.
  • TP-LINK Master
  • 3,320 Answers
Get the proper drivers for your net cards.
Review the security settings in the net cards set up.
Posted on Mar 31, 2014
  • 16 Answers
SOURCE: My ps3 won't connect to
Try connecting the PS3 to the router via ethernet cable, their may be some buttons with numbers on the back of your router, one the PS3 is connected press one of these.
the PS3 should know the paired with the router and the wireless should work.
hope this helps!
Posted on Mar 02, 2011
jsbasrao
  • 54 Answers
SOURCE: Hp Pavilion dv6929nr not connected with D-link DI-624
There are a number of factors that can cause the signal of your access point to deteriorate and the performance of your network to fall under par. Practically any appliance that operates on the same frequency level (2.4 GHz) as 802.11b or 802.11g can cause interference with your wireless network. Be sure to keep cordless phones, microwaves and other electrical equipment at least 1m away from the access point. Try changing channels on the access point and test it out on one of the clients. To change the radio channel on the access point login to the configuration (usually a web based interface) and go to the Wireless Settings (will vary depending on vendor) section, select a different channel and save settings. On the client, go to Device Manager, right click your wireless network adapter and go to Properties. In the advanced tab select the Channel Property and change the Value to the same number as the one you chose on the Access Point. Disable and then re-enable the wireless connection. Also you can try by select the speed manually 802.11b or 11Mbps on your laptop wireless properties.
PLZ GIVE RATING BY CLICK ON YES or NO.
Posted on Mar 21, 2009
govinda123
  • 2260 Answers
SOURCE: cant access internet but can connect to wireless TP-link router
Your friend is able to go online using the same wireless network. that means the wireless network is working properly and there might be a problem with your computer .
You said that you can connect to the wireless network but you can not go online.
Check the IP address and the default gateway of the computer.
Try to ping the router and DNS server and check what happens.
Make sure that there is no static IP address on the computer.
Click Here for more information about the routers and Internet.
Posted on Feb 01, 2010
shademand
  • 114 Answers
SOURCE: I'm using TP-LINK TD-W8101G ADSL
Unfortunately, you can't use two routers together in that manner. You must have a device in between them such as a switch or bridge or you'll have to disable the DHCP server settings in the second router. The second router then pretty much becomes a switch you may then use all the ports on the second router with the exception of the WAN port it must remain unoccupied. However, if you need wireless connectivity in another location far away from your main router then your only solution would be to indeed purchase an actual access point/bridge device
Posted on Sep 06, 2011
nasro2
SOURCE: TP-Link TL-WR642G recovery after failure upgrade to latest firmware
may find this page helpful. http://www.dd-wrt.com/wiki/index.php...om_a_Bad_Fl ash Its not for the TP-Link router but the same principle could be applied to you with the correct firmware. Its worked for me on more than a few occasions. Providing you can ping the router via a lan cable then the chances of recovering it are very high.
Posted on May 22, 2012
How to update whole firmeware of tplink for w8901g
Sameer, First thing to do is establishing some facts of this router. Please look at the labels at the bottom of the unit and let me know the firmware version. Something like v1, v2 or v4. Pls look here for the example http://www.tp-link.com/lk/Article/?id=46.
You now have to connect the router to a pc with a network cable, that pc is NOT connected to the internet. For instance with a separate laptop, disable the wifi. The network cable connects the router (one of the LAN connections) to the pc.
Invoke a browser and write in the address line 193.168.1.1 with ID admin and password admin. This should open the service program from the router. Go to Firmware upgrade. And follow the rules. Generally you have to check the latest firmware in the TP-Link site and download that file to your pc. IF you have any questions we are always here to help.
Success, Fred
May 03, 2014 | TP-LINK TD-W8901G Router
How can i block some site all over my office from TP-W8901G router?
You can find the entire user manual here.
http://www.tp-link.com/resources/software/201161016042811.pdf
Look at section 4.5.2 on filtering. It will give you all the details you need.
Aug 27, 2013 | TP-LINK TD-W8901G Router
TD-W8901G issue after upgrade to V6
I'm an electrical and electronic engineer (Iranian and Persian native speaker) that had the same problem,exactly my modem went to death (just power LED is ON) after upgrading from version 3 to 6 and I have precisely similar TP-LINK TD-8901G ADSL2+ router but I found a great "step by step" tutorial in a Russian website(in their forum) which contributed me significantly;
I hope it might help you too.
iman28aban@gmail.com
+989358817467
http://www.lan23.ru/forum/showthread.php?t=6859&page=1
Dec 27, 2012 | Computers & Internet
I have disabled DHCP server and now I can't connect to the internet. what can i do? i am really stuck!
Here is a support site from TP-Link that tells you 2 options for resetting your options to factory defaults so you can setup your network again.
http://www.tp-link.com/en/article/?id=82
May 19, 2012 | TP-LINK TD-W8901G Router
Hi my problem is i want to learn my routers password without resetting it. its TD-W8901G . I tried to connect to 192.168.1.1 but my password or my username was incorrect. i have tried admin as usname and...
You can't do it, it has to be reset if you have forgotten the password. Otherwise, it defeats the purpose of a password. The default password is usually admin/admin or admin/password
Mar 20, 2011 | TP-LINK TD-W8901G Router
Computers & Internet Logo
75 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
alex metro
alex metro
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
