Question about Hobart AM14-253 Free-standing Dishwasher
Where can I purchase a heating element
The heating element is no longer functional. We are situated in Roodepoort Gauteng and I need to purchese a element deperately
  • Jim Uff Apr 01, 2014
    hobartcorp.com lists europe manufacturing and various north american offices for service and parts. In Canada I contact hobart directly and order parts. Hobart should be able to give a European supply or allow delivery from North America. If you submit your serial and ML# you and get accurate parts diagrams to give an exact part number.
I am in Vanderbijlpark Gauteng south africa and need to know where I can take my Tomtom to for repairs.(think it needs a battery.
TomTom service centre is situated at Regenersis, Unit C, Alphen Square West, 338 George Street, Randjespark, Midrand, Gauteng.
I think they offer a pick up and drop off service incase you cannot find the place with a faulty Tom Tom. Call them and see 0800 980 670
Mar 30, 2017 | Tomtom GPS
How do I check heating elements?
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
May 19, 2014 | Frigidaire GLEB30T8A Electric Double Oven
Sewing Sevice
try typing in your browser for a sewing machine repair shop in your area.
Apr 02, 2014 | Sewing Machines
My Kennmore 790.95312300 will not heat up on Bake
If the element tests good, the clock / control is most likely the problem and will need replacing.
Oct 20, 2017 | Kenmore Kitchen Ranges
Dryer want heat up what's problem
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it. Disconnect the power source to your dryer before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Dryer heating elements come in various shapes and sizes. They are all strung with a coiled wire made of a nickel and a chrome alloy. This wire receives, but resists, a controlled electric current and as a result, the wire heats up. The heat produced is used to heat and dry the clothes in your dryerOnce you have gained access to your dryer's heating element, set your multimeter to the R x 1 resistance scale. Touch each meter probe and to one end of the element. If you receive a reading of infinite resistance, then your heating element is no longer functioning properly and you will have to replace it, thanks to parts direct
May 31, 2011 | Maytag Neptune MDE6800 Electric Dryer
Drivers seat heater no longer heats as it used to. Passenger side heater still works. Is there a fuse that controls the heater function under the seat?
Without knowing what vehicle you have Im just guessing.The element that heats up is a possibility that it may have a broken wire and the element needs replacing
Sep 07, 2010 | Chrysler Sebring Cars & Trucks
Toaster no longer heats. Can I purchase the heating element and install myself?
mcdevito75 here, Chances are the heating elements are soldered in on the toaster and may take special tools to fix, if the heating elements sre burned out, maybe better to get another toaster.
Jun 19, 2010 | Dualit Vario 2 Slices Toaster
My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
dryer_heating-element.jpg Heating Element
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
I purchased all Whirlpool appliances for my new home in August, 2005. The refridgerator is a whirlpool gold s/s with water/ice dispenser. After one year of use, the ice stopped being made. We contact the...
I would definetly contact Whirlpool and complainn about the shoddy service you received from the store Tell them all about your situation .I am sure that they will be very happy to help you I believe you have a good beef with them re that store
Dec 29, 2009 | Dryers
Hobart AM14-253 Free-standing Dishwasher Logo
26 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
