Question about Gateway Computers & Internet
Computer powers up, MONITOR says no signal
Allcables are good and correct. The mother board seems to be ok. All fans come on,hard drive gets warm, DVD powers up, but sounds like the disk will not spin. Front panel power button will not shut unit down, have to use power swith on back panel. The computer does not seem to recognize any exterior devices, key board, mouse, eathernet cable, speakers,OR MONITOR: NO SIGNAl. I am useing a WORKING monitor,a HP f1523h. With no signal I have no info to work with. What can or should I do.
  • Jemuel Osorio Sr.
    Jemuel Osorio Sr. Nov 07, 2016
    Your computer have a power when you switch the on but the motherboard and the Processor are not working. That's why the keyboard and mouse and other phereperals are not working. If you can able to open the casing of your computer can you remove the memory and clean it by eraser and insert again to the memory slot. Also if you have another PCI external card like Video card can press it to insert them properly. I hope i can help you
  • 64 Answers
Had same problem...re-install windows ...bad drivers and such
worked fine after that
Posted on Mar 31, 2014
exspert
  • 55 Answers
SOURCE: Computer Won't Boot (Anything?)
ok sounds like a bad power supply , i would get a new one
Posted on Jan 21, 2008
Bubbabear64
  • 2794 Answers
SOURCE: amber light on power button
Check to see if there are any loose connections to the memory cards on the memory board. Make sure the data cable to the drives are connected properly. Is the fan in the power supply on?
Posted on Jul 27, 2008
  • 166 Answers
SOURCE: No video signal to Monitor.
Lack of video signal is usually 1 of 3 things, Power supply (PSU), Video card or Motherboard (mobo).
Situation #1: If you get a blank screen and no sounds or movement it either indicates that the power supply unit (PSU) has failed or something on the motherboard has failed, preventing normal startup.
Situation #1A: You might get some power lights coming on and some fans spinning but the video output does not happen, usually indicates that motherboard is going out or has gone out. Ocasionally it will be due to a weak (damaged) PSU.
Situation #2: If you get sounds and lights but nothing on the screen then it indicates a failed or loose video card.
Always try a different power outlet that you know is working. (Eliminate the easy stuff first!)
If it is out of warranty, try opening up the case, with the power off, of course. If you have Sit #2 and have a video card that you can reseat (take out and then put back in) try that. If it is onboard video then you may have to buy a video card for it.
Also take this time to inspect the capacitors on the motherboard (they look like tiny soda cans) and check for tops that are bulging, swelling or leaking anything. Capacitors should be perfectly flat on top. If you find these then your motherboard is bad (well technically the capacitors on your motherboard are bad). The bad caps will need replacing to fix (not a job for an amateur). If it passes the visual inspection then it may just be your power supply is bad. Notice that a bad PSU does not mean you are getting no power, just not enough to start and run the computer.
A few years ago a company stole the recipe for making capacitors and started making their own capacitors at really cheap prices. The stolen "recipe" was not complete and not correct so these caps started failing after about 2-3 years of use. Emachines, DELL and Gateway were the computer companies most affected by the bad capacitor issues, although any of the big companies could have the same problem. Power supply maker were also affected by these bad caps.
Do you hear anything during startup, beeps, fans or drives spinning, lights on the front or back of computer flashing or lit up? Do you hear the Windows starting sound?
Let us know more then we can troubleshoot better.
Posted on Mar 26, 2009
  • 644 Answers
SOURCE: My HP Pavilion a6300f powers up but no signal to the monitor
It could be the motherboard, try resetting the the bios first by either taking the lithium cmos battery out and then replacing after 30 secs or finding the the cmos jumber and unshort it for 30 secs, and reboot the mechine.
If the same and no monitor responce then the onboard graphic electronics may have failed, the motherboard does have a AGP expansion slot which you may want to test with a graphics card to see if that will work.
If you find that you do have to replace the motherboard, try to find one that uses the same processor and memory that you already have, that way you will keep expence down to a minimal.
Replacing the motherboard will mean you will have to contact microsoft to give you the installation codes for the operating system to work with the new motherboard, when you boot for the first time with the new motherboard fitted you will have to phone the number on the screen to reregister the system just follow the instructions, it is quite self explanetry.
Once all booted up and drivers installed the computer should run as normal, as for the hp recovery disks it should still work as all the information on the disk is on the harddrive any way, the only thing you would need to do is keep the motherboard installation disk with all the drivers on.
hope this helps.
Posted on Mar 23, 2010
Testimonial: "Thank you for taking the time to reply and for your suggestions."
  • 181 Answers
SOURCE: I got a dell optiplex
I recently worked with a couple of used Dell desktops that someone got from work. Sound familiar? I couldn't get them to come on because the plastic bracket that holds down the CPU heatsink was broken. The heatsink was also covered with a carpet of dust. The new owner could've bought a new heatsink/bracket online, but they declined to spend money. Open it up, make sure everything is in order to diagnose the problem.
Posted on Aug 15, 2011
Computer don't start,
If it doesn't start at all, check motherboard for a short by unplugging the processor power cable (4 pin normally), and turn the computer on. If the fans start rotating, it is probably a short. If that isn't the problem, check for cables that should be connected, and test the processor in another computer. Hope it works (it did for me)
May 27, 2014 | Powerspec G213 Desktop Computer; Intel...
My computer has no signal
Hello, Sounds like you don't have the right power supply, only and emachine power supply from emachines will work.
Feb 22, 2014 | E-Machines eMachines Desktop PC
Computer is not booting to windows
Reseat the ram. If that doesn't work, try reseating whatever you can --without shorting out the chips. Follow proper procedure for not frying your setup with static electricity while you do this.
Here is a link offering the possible fix and/or some company in similar situations.
Computer fans turn on but nothing else
Sep 18, 2017 | Computers & Internet
Crashing
its not the mother board you need to up grade (yourself as in apple will not do it for you) the ram to at least 8 gigs and get a new mac book pro processor that runs on at least 80 gigs
Mar 15, 2013 | Apple Mac Book Pro 13 In Laptop Computers
Hp pavilion slimline x3507c pc. when I boot up the monitor remains in standby mode. I have already determined that the problem is in the computer not the monitor. The power supply is good, the fans run,...
very simple bring a new AGP card and plug in it on your pc and plug the monitor pin in new agp now start your computer . monitor will turned on.
if the monitor is not turned on its mean your have problem in your ram or mother board for that pluged out your all rams from your pc and start your computer if cpu ring a beep its mean you have ram problem and the mother board is ok but if you cant hear any beep its mean mother board's problem ram is ok.
Jul 16, 2011 | HP Pavilion Slimline s3700f PC Desktop
Computer randomly fails to boot
how many video cards do you have installed?
Nov 14, 2008 | E-Machines eMachines Desktop PC
EMachine T3406 wont boot
is there a post beep when the pc is switched on. check the memory if it is a beep beep beep sound , also disconect the hard drive, dvd drive, floppy, and any usb devices and see if it boots up. if that fails it does seem like the mother board, also check the cpu fan has it stoped. also find out the power switch conector on the mother board, from the base unit switch to the mother board. also chech the power connector from the power supply to the mother board , on newer boards there are two that go to the mother board its self , a big one and a very small one .
Jul 05, 2008 | E-Machines eMachines Desktop PC
Computer Not Booting Up
normaly ther are two reasons for pc not showing the disply
1 memory card mismach
2 graphics card mismach
get the specification of the mother board and correct the above errors the pc will work if u need more assistace please write to me
Oct 23, 2007 | ASUS AI Lifestyle P5N32-E SLI...
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
