Question about Refrigerators
Hotpoint ff200e Freezer door left open overnight!! Came down this morning to beeping and 2 amber lights flashing. Help! Ps I've thrown away all meat products!!!
  • Refrigerators Master
  • 842 Answers
I would be better for the unit if you unplugged it and allow to completely thaw. Also, double check all food as salad dressings also goes bad in higher than normal temps. I reason behind the unplugging is to allow the unit to thaw and reset. 50/50 change if you close up the unit it will function as normal.
Good Luck
Posted on Mar 31, 2014
SOURCE: flashing lights super chill super freeze
This is probably because you turned off the fridge at the mains (to defrost??). To stop the flashing lights and to restore normal operation, turn both the Supercool and Superfreeze knobs counterclockwise to "off" and then back to the operating position. Thats all!
Posted on Jul 06, 2009
SOURCE: hotpoint frost free ff200e flashing lights and
Make sure fridge OFF freezer OFF ... then turn mains on. ONLY turn freezer to max, after 30mins put fridge to 1care ... this should overcome the problem of the flashing lights. When both nice and cool turn settings down. it worked for me
Posted on Sep 27, 2009
justinbur167
  • 257 Answers
SOURCE: two amber flashing lights on
Hello Dawntucker69,
This is a code that the Freezer temperature is too high not cold enough. If this is the case you will want to check and see if the coils on the back and bottom of the fridge are clean and free of dirt as this will cause your freezer to warm up and not work properly. Also listen to the fan in the freezer and make sure that it is running, if it is not running you will need a service tech to come and check your freezer.
Thank you for choosing Fixya.com
Justin
Posted on May 08, 2011
ginko
  • 19396 Answers
SOURCE: I accidentally left the freezer
Hi.
If the fridge has been left open for so long you may need to perform a complete defrost. First try disconnecting power for five minutes. To do this trip the circuit breaker or disconnect the fridge's power cord. If that does not work, remove food from inside the unit and perform a complete defrost by leaving the fridge not connected overnight. That should solve the problem. In case the beeping does not stop, even after defrosting, it means that the overload caused by the door left open had damaged parts inside the freezer. Compressor relay and parts in defrost system must be tested. While door was open the fridge has been under load most of the time, and this results in parts blowing. In that case call Hotpoint at the number listed in the user manual.
First try disconnecting power and performing a full defrost. Most of the times that is enough to stop the beeping.
Regards.
Ginko
Posted on Aug 08, 2011
caroldon
  • 17130 Answers
SOURCE: my hotpoint fridgefreezer model FF200E.the
When the door was replaced it was necessary to check the aligment and specially if the ddoor switch is closing in .Also if you have tilted the fridge to replace the door then it is possible that the oil could have flow out and disturbed the settings. So shut down the fridge for few hours and try again. Now If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off. If not the auto defrost timer, or the thermostat must be checked.
The ventilation fan that circulates the COLD air from the evaporator coils could get clogged with frost and so could be jammed. Also the wires to the fan can be worn out due to the frost. If so check if the defrost timer works to switch the heater to remove the frost. Also the check if the compressor is shut down by the timer /thermostat . If the heaters are not working, check continuity of the heaters.
So attempt to test using a multi-meter / clamp tester from the outside and make your observations so that we come to the solution.
Please check this link for tips to work.
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Thank you for using Fixya.
Posted on Aug 31, 2011
Hotpoint FZFM171 freezer door left open all night, has defrosted and the 'super freeze' light and alarm light wont stop flashing. How do we fix it?
Turn the power off to the refrigerator and manually defrost the freezer until the freezer bis no longer cold and then replug the power cord
.APPLIANCE 911
Jan 27, 2016 | Hotpoint Refrigerators
Fridge light not working
door light switch Need full model # for better idea .
but normal switch should be at bottom of door or at hing side of ref
some model have at top it may be broke off and thats why you don't see it send us a full model number we will find for you
Feb 28, 2015 | Hotpoint Refrigerators
Left door of F/P fridge part for a week. Now red light is flashing, beep stopped but fridge not cold enough.
Hello Jennifer;
My name is Peter. I am a retired field service refrigeration technician.
No. Your problem is not defrost.
The normal temperature setting for a freezer is -2 to +2 degrees F. or -18.8 to -16.7 degrees C. The fresh food section should be set at 35-40 Degrees F. or 1.6 to 4.4 degrees C.
Reset your temperature controls to the recommended settings.
Up plug your unit for 10 minute to power down. Plug your refrigerator in.
Jan 01, 2015 | Refrigerators
Two amber flashing lights on a hotpoint ff200e fridge freezer
Hello Dawntucker69,
Justin
May 08, 2011 | Refrigerators
Left door open, closed next day, but only blowing cool air now
You will need to turn the unit off and let it completely unthaw. There is frost that builds up in the ducts and behind the panels when the door is left open that will cause the unit to not cool or circulate where needed.
May 10, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My hotpoint quadrio amber lights at the top of the fridge door are flashing is this anything to worry about - they are indicated with the words ''super cool'' and ''super freeze'' (sorry but cant find...
my hotpoint quadrio is causing problems the fidge part is no longer cooling the light is coming on but thast is all what can cause this. can anyone help
Feb 20, 2010 | Refrigerators
I left the Freezer door open and now it seems like the freezer is not cold enough to freeze things. It has been 5-6 hours since it has been closed. Is it just taking a long time to completely cold or...
Place a glass of lukewarm water on one of the freezer shelves. Leave the freezer door closed overnight. Check the water in the morning to see if the freezer has brought the temperature down. It takes quite awhile for refrigeration units to recover from heat loads such as door open for extended periods of time.
Jan 06, 2010 | Freezers
Hotpoint frost free ff200e flashing lights and beeper freezer food defrosting
Jul 05, 2009 | Hotpoint Refrigerators
Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Feb 24, 2009 | Hotpoint Freezers
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
