Question about Garden
With engine running presents of fuel in the fuel filteris next to none. engine runs awhile then stops. it will always start back up. ran engine on seperate gravity fuel tank. with line fromm fuel pump into a gas can. fuel flows great and none stop. i replaed fuel pump anyway. same problem. engine is kawasaki fh680v. with engine running you can disconnect fuel line from pump to carb and fuel filter fills like it is suppose to and flows fine. i am thinking tere is a vent for the float bowl plugged. gas cap vents are ok. ran with gas caps off. same problem.
  • Anonymous Mar 26, 2014
    Fuel pump
    Sergeant:
  • 353 Answers
Clean carb bowl
Posted on Jun 20, 2009
Intermittent P0191 error code
I had a similar problem that turned out to be dirt contaminated gasoline. The "fix" was always to replace the fuel filter but it would not stay fixed. In particular, each time I started having problems it was after I let the gas tank level get low.
What I did that you can consider was:
  1. But a new fuel filter.
  2. Get a 5 gallon gas can.filled with fresh gas.
  3. Get some cheap gasoline proof container (or several containers) for waste gasoline.
  4. Make a "vacuum cleaner" out of an electric in-line low pressure gas pump, some low pressure gas hose, and a couple of pieces of copper tube, 20 ft of two conductor wire, and two alligator clips. It connects hydraulically copper tube to suck out the gas tank, fuel hose, pump, fuel hose, copper tube to go into the gas can. The wire and clips are to hook the fuel pump to your car battery.
  5. Drive the car until the fuel level is low.
  6. Remove the fuel pump module.
  7. Vacuum the gas tank into the waste gas container through the opening left by the fuel module. Try to get the dirt off the bottom.
  8. When you have vacuumed all you can get, stop awhile and let the dirt settle in the waste container.
  9. Vacuum the gasoline from the waste container back into the gas tank. Vacuum high in the container so the dirt stays in the waste. Try to wash any dirt in the gas tank to below the fuel module opening.
  10. Stop a while and let the dirt settle.
  11. Repeat vacuuming and washing as many times as needed to get the tank clean and empty.
  12. Inspect the tank interior with a mirror and flashlight looking for rust, dirt, etc.
  13. Replace the fuel module.
  14. Install the new fuel filter.
  15. Pour in the new gasoline.
And hopefully you are good to go.
May 09, 2015 | Ford Cars & Trucks
Cranks but won't start like it has no gas
did you reset the alarm/immobiliser system every time the power was disconnected???
May 21, 2010 | 1997 Volkswagen Jetta
I run twin 115 4 strokes,2001 model.Port engine started to drop rpm while running at wot. Dropped to 3700. No skipping,missing,etc. Stop and fish for hour, start over again and runs fine than starts...
check Compression and spark. Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local dealer). I know all these are expensive but if your going to be a outboard owner you will always need them. troubleshooting (1) check compression. I'm giving you average numbers. Look at your
Clymer manual for specific numbers. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester, all cylinders should jump a half inch gap.
Aug 31, 2009 | Boating
Engine starves for fuel after running about 50 miles or so...
Has Neon do same, I ran fuel at low level, on hot day, ran engine until it started to act up & threw a fuel pressure gauge on it. Was at approx 5 psi. Cold next morning, 48-50 psi. Always hot day about 30-40 miles into work in morning, o.k. Sit in hot sun all day & would happen 3-4 times on way home. Sit and let cool, 20 minutes or so & go again for a while. Cool day, no problem. Change pump I would.
Jul 21, 2009 | 2004 Chrysler PT Cruiser
My car starts and then dies
sounds like a security issue they installed a factory security system which will prevent the vehicle from running unless its reset go to passenger door lock turn key twice it worked for me after chasing other problems for a few hours
Dec 03, 2008 | 1995 Jeep Grand Cherokee
Still does not start
Hello what you need to do first is determine fuel problem or spark problem when this happens again take your gas cover off the fuel filler listen for a hum from your fuel pump if its not present the pump is most likely bad if the fuel pump relay checked out good you need to test for spark buy your self a cheap spark tester that lights put it on to the coil check for spark while turning over if none present you need to trace from coil ,to ignition module,possible heating up cutting out goodluck please rate
Oct 02, 2008 | 2003 Dodge Grand Caravan AWD
Garden Logo
310 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
