Question about Makita Drills
Just stoppd working
Green light shows when trigger is pulled but the tool does not work
  • 42 Answers
Tried the brushes?
Posted on Apr 11, 2014
Dc31 flashes green
Hi there, it's Jack at Dyson.
Usually if the indicator light flashes green when the trigger is pulled, this means the machine needs to be charged. If you have had your machine connected to the charger assembly for over 3.5 hours and continue to see the flashing green light, this could mean the machine isn't recharging correctly.
In order for us to diagnose which part is at fault we'd need to take you through some simple diagnostic checks when you have your machine to hand. You can reach our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Aug 03, 2014 | Dyson DC31 Bagless Handheld Vacuum
Makita hammer drill does not work but green light shows
Could be a stuck brush. Take the covers of the brushes and check they are long enough and move easily back & forth.
Mar 31, 2014 | Makita Drills
Hahnel Giga T Pro II remote function not working
Hi Jack,
I assume you have an answer by now but if not. Cable between receiver and camera is the issue. One of the jacks has 3 black rings on it, which must go into the receiver. The other has 2 black rings and goes into the camera.
regards
Kent
Mar 27, 2013 | Hahnel Giga T Pro Ii Wireless Remote...
Bosch cordless drill not working.
First The model is pretty new. you need to register your tool on line. this takes you from a one year warranty to a three year warranty. They will give you a pro-vantage number. with that said it sounds like a trigger switch. Yhe trigger switch is the brain of your tool. not only does it do your variable speed but it also controlls the brake and your fuel gauge. Because of the cost I highly recomend taking it to your closes Bosch service center.
Oct 13, 2012 | Bosch Cordless Impact Driver, 18V, 1/4 Dr,...
Makita HR3000c green light comes when trigger depressed but doesnt work
From the owner's manual: Indicator lamp The green power-ON indicator lamp lights up when the tool is switched ON. If the indicator lamp is lit but the tool does not start, the carbon brushes may be worn out, or the electric circuit or the motor may be defective. If the indicator lamp does not light up and the tool does not start, the ON/OFF switch or the mains cord may be defective.
The easiest to check is the brushes. Most newer tools have brushes with a spring loaded pin in them so when they wear down the pin pops and stops the motor so you don't wear the armature. Even without the pin the wire from the contact to the brush is short so the spring doesn't contact and ruin the armature. If the brushes are OK, you'll have to check the switch for continuity.
Aug 24, 2012 | Makita Drills
As you pull the trigger slowly the tool cycles several times
It sounds like you have a contact trip trigger that you are trying to operate as a sequential trip. Sequential trip is when you have to put the tool against the work and pull the trigger every time, contact trip is when you pull the trigger and tap the nailer on the work and it fires. If you operate a contact trip like a sequential it will fire but it usually fire more than one nail. Your instruction manual will explain this, sometimes they give you two seperate triggers for the two modes or there is an adjustment on the nailer.
Aug 03, 2009 | Stanley Air Tools & Compressors
USB plug to charge, yellow light not green
t_cosh you must try charging it with the wall-charger, if that doesn't works, try entering BL mode by pressing # and *, and then pull the trigger to turn it on.
It will tell you that battery is low, you can connect then the charger, pull the trigger again, it should start normally.
Jun 21, 2009 | Motorola Mobility ROKR E8 Cellular Phone
I own a 1993 Ford Explorer and my radio just stopped working. I checked all my fuses and they are all fine. What could be the problem
the radio may be defective, pull it out and verify power to the radio, u can buy the radio removal tools at any NAPA parts store or get them from Ford, they are very cheap to buy. here is the wiring colors and what they do, u will also need a cheap 12 volt test light, about $6
1993 Ford Explorer Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Light Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: Light Blue/Red
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Blue
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Pink/Light Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Pink/Light Green
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Black/White
Jan 08, 2009 | 1993 Ford Explorer Limited
Drills Logo
65 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
