Question about Makita Drills
Green light shows but tool does not work ? - Makita Drills
    Problem Solver:
  • 50 Answers
Could be the motor brushes
Posted on Jun 29, 2014
Just stoppd working
Tried the brushes?
Mar 31, 2014 | Makita Drills
Ryobi charger bcl1418
Usually this is indicative of a bad battery. First try a good battery in the tool to make sure it is OK. If the tool is OK, you need to try charging the good battery in the charger to see if the charger is working properly. If the charger is OK, replace the bad battery. Some batteries will show fully charged on the charger but will not supply the power to the tool.
Oct 08, 2012 | Ryobi Drills
Software to rest the canon pixma ip 4940 printer ink absorber full problem
i have able to reset ip 4940 but the problem is after switch off the printer it return to ink absorber full what can i do please
Sep 06, 2012 | Canon PIXMA iP4920
Rocstor icon disappears from desktop and light is half orange/green
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps you
Mar 05, 2012 | Rocstor Storage Rocstor Rocpro 225 500 GB...
Are all the Lithium batteries working like this. Mine work for a short time then stop dead. Wait a while then they will work again. Really a pain when you are working trying to do somthing and have to run...
I use the Ryobi Li-Ion tools the L-I batteries will cut off when they get to a low charge level this is to protect the batteries Li-Ion batteries life span is shortened when fullt discharged so when the tool suddenly stops put the battery on charge,also if the battery has a charge indicator light for a more accurite idea of the charge (green is charged,red discharged) hold the test button on then run the tool the light may go from green to red if it does that shows the the charge is about depleted if the light stays green you have a little run time left.
Oct 25, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
The red light is on the SMART Board 580 and we need to fix the connection so it shows green but don't know how to do this.
Find "SMART Board Tools" or "SMART Board Tools 2011" on your computer. Select Control Panel > About Software and Product Support > Tools > Diagnostics. From the menu select Service and then Start.
If the red light does not change to green, try the following steps located located here: http://preview.tinyurl.com/3qggntc
Ian Berg
Technical Support Specialist
SMART Technologies
http://www.smarttech.com/tcea
Aug 17, 2011 | Smart Technologies SMART Board 580 (SB580)
I have the Arrow CT50 stapler, it won't drive the staple, light works makes a sound like it wants to drive staple but don't. I have adjusted the power to all the way + and the battery shows 4 green lights....
It sounds like the battery is failing low battery voltage equals loss of power. The batteries used in this type of tool are the cheapest ones out there to keep the cost of the tool low, and have a very short lifespan, it is not the number of times used but how old they are that is the main factor
Feb 28, 2011 | Arrow Ct50k Professional Cordless Staple...
Tablet won't switch on.
The power on switch is faulty. replace it. The battery is fine as there is green light meaning that it is supplying the current. And since the power switch is not lighting up it is faulty. If replaced, the tablet will function correctly.
Nov 16, 2009 | Wacom (PTZ930AC) Graphic Tablet
Green lights on start up
You should have 3 green 2 yellow and 1 red.This is your maintenance indicator. When the 1 (last) green light goes out and a yellow light comes on its time for a service. The shop will reset the lights for you after the service is completed. If you do the service yourself and like to work on your own car you can buy a service light reset tool here. http://www.eurosportdesign.com/c-5-reset-tools.aspx?gclid=CPnumom1_pcCFRKLDQodkTwFDQ The R5B tool is the one you will need. It's on sale right now.
Jan 08, 2009 | 1999 BMW Z3
Drills Logo
59 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
