Question about Zhone Computers & Internet
"I know that its not a phone but it has 4 voice ports and hence I would like to use them to make calls which connects to the call manager, any suggestions how to configure the voice ports will be high
How do I configure the voice ports to make calls
  • Zhone Master
  • 3,320 Answers
Get the manuals and read them. Then you will find this equipment is not for home use.
Posted on Mar 31, 2014
3 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: configuring
When you say download speed, are you using a peer to peer programme, in which case you will need to open a port, or are the download speeds related to general file downloads and what speed broadband do you have?
Posted on Feb 14, 2007
  • 17 Answers
SOURCE: cisco 3640 with a VWIC-2MFT-E1 network
You most likely don't have the correct IOS on your 3640 router. Other possibilities include bad VIC card or non-compatible VIC card.
Posted on Jan 11, 2011
ZTE MF190 Dialing problem
I have a unlocked ZTE Mf190 USB-Modem. When I put the SIM card in it and connect it to the computer, I am able to connect to 3G Internet via beetel connection manager. Is it also possible to send and receive SMS. But when I try to make a voice call on beetel voice call panel, I receive this error message "Dialing failed! Please try again!" . And also when I use another phone to call the SIM card line number that I put in the USB-Modem, I receive busy tone
Mar 31, 2013 | ZTE Mf190 Unlocked 3g Gsm 7.2 Mbps...
No dial tone on phone connected to ext port on epson dx9400f
Buy a double adapter so both cords go to the LINE port. Set your answering machine to 6 or 7 rings so the fax picks up first. Your fax machine will know the difference between voice and fax calls,
Jun 22, 2010 | Pitney Bowes 9920 Plain Paper Fax
How do you take out voicemail from the phone so call forwarding can be processed?
I'm not sure that you are phrasing the question correctly. How can I bypass the voice mail box would be a better explanation.
If you take out the voice mail box it will go to the main greeting. Call forwarding to voice mail is call forwarding being processed. Is there somewhere else you would like it to forward to?
If you are just trying to delete your mailbox then you need to know your system manager info. If you do email me at IsaiahJ1980@gmail.com and I can help you further.
Call Forwarding Options:
From Port 1
Find port 01 or Tel 01 by pressing feature 4 from the lowest extension # in your system. Once you have found port 01 dial either of the following:
Call Forward Busy No Answer
Speaker 45, enter the extension you want to forward i.e 103, enter the destination, another extension perhaps 107 and speaker.
Call Forward Busy No Answer to an outside #
Speaker 45, enter the extension you want to forward i.e 103, press 9 and enter the destination phone # and speaker.
To Cancel Call Forward BNA
From port 1: Speaker 46 and the extension #
Call Forward All
Speaker 47, 103, enter the destination extension 107 and speaker.
(You will notice the Feature light flashing after this operation)
Call Forward All to an outside line
Speaker 47, 103, 9, enter the destination phone # and speaker.
To Cancel Call Forward All
From port 1: Speaker 48 and the extension #
Nov 13, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Want to turn off voicemail Don't know codes
To turn off voice mail please dial ##002#, this would do the trick.
Regards
Oct 13, 2009 | RCA 25450 4-Line Extended Range Multi...
I can't call pc to pc
It may have some causes:- First, check your internet connection. You should run the Call Setup Assistant before making voice calls for the first time. To run the Call Setup Assistant: Open the "Messenger" menu in the main Yahoo! Messenger window, and click "Preferences." Then, in the Preferences dialog box, click "Calling and Audio." In the Calling and Audio dialog box, click "Open the Call Setup Assistant." Follow the instructions to test your microphone and speakers and specify your Internet connection. Running the Call Setup Assistant will ensure that you have a high-quality voice experience within Yahoo! Messenger. You can run the Call Setup Assistant at any time to make sure your microphone and speakers are working properly or to change the type of Internet connection you are using. One important thing, your firewall must support outbound TCP (transmission control protocol) connections for the PC-to-PC voice feature to work. You might have a firewall blocking Yahoo! Messenger's PC-to-PC voice feature. If so, you need to open up some outgoing TCP connections. Note that it is the outgoing connections that matter, not incoming connections. In most firewalls, you have to specify a destination port or port range to open. Learn more about which ports Yahoo! Messenger uses. Even if you don't use a firewall, your Internet service provider (ISP) may use a firewall, a network address translator (NAT), or a proxy server that blocks voice traffic. Any of these could prevent you from using the PC-to-PC voice feature in Yahoo! Messenger. Please contact your ISP's network administrator for assistance getting around these issues. You must know that what ports are used by Yahoo! Voice services. Yahoo! Messenger with Voice will work if any one of these TCP ports are open: 5061, 443, 80. At least one of these ports must be open in order to make PC-to-PC or PC-to-phone (Phone Out) calls, or to receive calls (Phone In). If your connection to the web is through an http proxy, then you won't be able to make or receive calls with your PC. Hope it was helpful!
Jun 09, 2009 | Yahoo Messenger
What do I buy to use 2line phone and separate fax?
You can buy a 2 line phone, but to use the fax/dsl line for voice, you will also need a line sharing device.
"The stick" is a good brand....
All it does is recognize if an incoming call is a fax or a voice call. If fax it would go to a fax port on the stick. If voice, it comes out the voice port which you can call on.
The same rules apply to this line....if something is using it, the next call will get busy......But now you could have the phone company "Hunt" your line 1 to line 2 (fax/dsl) if line 1 is busy.......hence...2 incoming lines....
Apr 14, 2009 | RCA 25201RE1 Corded Phone
Greeting message
Since you asked this question in a 76xx forum, you have a TDA phone system. A TDA has timers that set where unanswered phone calls route to, one of the ports being voice mail/auto attendant.
There is no "simple" explanation for setting auto attendant. Each installation is different. You first of all, have to know which phone system and voice mail you have, then, know how the AA was set up.
For example, in a TVA voice mail, the setup is visual. you log in via the console and drag icons to the screen that maps the call routing. Since you start with custom menu 1, it sets your custom greetings 1,2,3, etc. In a TVS, you build custom service menus by hand.
While phone intercept is straightforward, trunk (line) is not. The voice mail knows whether the call is coming from a phone or a trunk and each has to be defined. In the case of an extension, you already know it goes to a voice mailbox and plays the greetings established for that person. In the case of a trunk, it may be a different greeting for each trunk for day, night, lunch, and break. Those parameters are all set in the TDA and TVx both.
I hope your head hasn't spun around several times, but the best idea is to sit with your voice mail administrator and phone system installer and get the picture of how the system was designed. You should get specific instructions of how the system handles calls and how you change greetings. You need to get the passwords and instructions for mailboxes 998 (message manager) and 999 (system manager) and a location of all greetings.
If you're into learning, a copy of the manuals for the voice mail and the windows software (if TVA) should have been delivered to your site with the system. In addition, the PT Programming manual (PTPM) can be requested from your dealer and it will allow you to make changes to your TDA.
Spending 5-10 hours with the manual some time will give you a better idea how the systems work.
Also, a spare PC with USB ports and a network card could get you remote maintenance from your dealer and maybe get you free or reduced cost maintenance and changes.
I know this is probably not the answer you're looking for, but I hope it helps.
Carl
Oct 02, 2008 | Panasonic KX-T7630 Corded Phone
How to connect headphones
i have a head phone with 3 speakers and wish to communicate on network computer to chat online and to call mobile numbers, but i don't know how Togo about
Sep 19, 2008 | Audio Players & Recorders
Call will not Transfer to Voice Mail
Typically you want your phone system to ring your phones (say extension 10, 11 and 15) and then if no one answers after so many rings the call is transfered to the port the voice mail is on (let's say it's port 16) The voice mail is set to answer right away but does not "ring" until the call is transfered to it. This way (at 4 rings) if a call comes in on line 1 and you answer after 3 rings but a call comes in on line 2 at the same time, the first ring on line 2 will not make the total = 4 and set off the voice mail. I would guess the port at your voice mail is not set to ring and nothing is set up to transfer calls to your voice mail. Did you set this up yourself? How did you program the phone system?
Aug 21, 2007 | Toshiba Stratagy 4 Lite Voicemail System...
Computers & Internet Logo
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
