Question about Hoover Dryers
Hoover Nexia HNV375 Stops After 10-15 minutes
As stated, my Hoover Nexia Megaload HNV375 starts to heat up and dry but only for about 10 - 15 minutes then bleeps as if it's finished.The little red triangle on the display flashes. If I leave the machine for about 30 - 45 minutes it will do the same again. I did have the whole thing apart and cleaned and lubricated everything I could get to and also tried another heater/thermostat unit. All to no avail. Please help someone!!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 134 Answers
Sounds like a faulty board
Posted on Apr 09, 2014
jsrock516
  • 5911 Answers
SOURCE: kenmore 90 series electric dryer
Before you toss your dryer to the curb, here's some simple advice. I know you said you cleaned your dryer, but when was the last time you inspected the dryer vent and/or inside the dryer for lint? The symptom sounds like you could have a couple of possible issues. The dryer may have restricted air flow (Meaning, the vent hose is clogged from where it leaves the dryer to the vent outside. Or...the dryer may be clogged inside the air baffle inside the dryer where the lint screen goes.) You may also have a high limit thermostat that is malfunctioning or a blower fan not working properly. Here's some recommendations:
1. Remove the dryer vent hose from the dryer and turn the dryer on. Is the air leaving the dryer forceful and warm? (The air should measure about 140 degrees F) If so...you probably have a clog or kink in the ducting somewhere between the dryer and where it exits the house. If the air is weak and cool, you will need to inspect your dryer interior to find what is obstructing the air flow. Rodents are notorious for building nests inside the vent line or air baffle. Check the air blower fan to see if it is rotating. If enough lint is allowed to build up, it can obstruct the rotation of the blower fan. It some cases, the fan can shear off on the motor shaft and must be replaced.
2. Can you access the heating element so you can see it? Start the dryer with the casing removed so you can watch the heating element. The element should glow red, but not so bright that it glows like the sun, and it should cycle on and off. If it glows continuously, the high limit thermostat is a likely suspect and should be replaced. (NOTE: It is recommended that you replace the high limit thermostat and thermal cut-out at the same time. Some manufacturers will sell the two as a pair).
HINTS: If you have a lint screen in the door, you should be able to access the heating element by removing a panel under the door or by removing the entire front panel. If your lint screen is on top of the washer, you will have to remove the rear panel of the dryer to see the heating element.
If the dryer is left to run in an overheated or clogged condition, the thermal cut-out and/or heating element will eventually blow. It is recommended that you inspect the dryer to see what is causing your current problem. You should inspect the dryer ducting and exhaust about once per season and keep it cleaned. Clogged dryers are a hazard and can contribute to house fires.
CAUTION: Always unplug the dryer if you are servicing the inside of the unit. Dangerous voltages are present even with the unit turned off. Also, unplug the dryer if you have to remove the rear panel. The 220VAC terminal is directly behind the panel and can cause electric shock if touched.
I hope this information helps you. Post back if you need any further assistance.
PS I hope I'm not insulting your intelligence with this, but improper sorting of laundry can also attribute to longer dry times. Try not to dry dense or heavy items (i.e., towels and jeans) with lighter items like cottons and linens. More dense material holds moisture longer and can transfer this moisture to other articles you are attempting to dry.
Posted on Mar 25, 2008
Illeagle
  • 525 Answers
SOURCE: Maytag MDG7600AW Gas Dryer heat starts and then stops
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Here are some common solutions to help resolve the issue with your appliance. Clicking on the underlined links will take you directly to that page.
If your dryer doesn't heat properly, check this: Venting restriction: Disconnect the dryer temporarily from the vent. If the flame stays on for a longer period, you may have an air flow obstruction to the outside. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Also, in your case, the coils may work fine initially, but heat build up can cause the coil(s) to malfunction and when they cool down will work again.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3479&PPStack=1
This link will help you with disassembly and diagnostics diagrams.
http://www.repairclinic.com/0100_17.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
Illeagle
  • 525 Answers
SOURCE: I Have a Whirlpool LGR6620PQ0
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
http://www.repairclinic.com/0088_8_1.asp#Level1_16
You may have faulty gas valve solenoids, especially since you've already replaced the other ignition components. Below is an image, (I hope), of the solenoids which can be found and ordered from the link above. A more rare cause can be a lint filter obstruction, i.e. the screen can be coated with an invisible film from using fabric softener sheets. Try running water over the filter screen, horizontally, and if water does not strain through, then replace the filter and stop using fabric sheets.
Thank you,
Dave E. (Illeagle)
Posted on Jul 04, 2008
Maytag317
  • 1136 Answers
SOURCE: heat cycle stops/goes off
Hi Tony, The next thing I would checnge would be the coils on top the gas valve. The tend to not open after the get hot. This is a very common problem with the newer gas dryers. I hope this helps you. Let me know if I can help you further.
Thanks
Vic
Posted on May 15, 2009
lsteward68
  • 331 Answers
SOURCE: Stops heatinng
ithis sounds like the ignitor glow bar might going out. take the door off and remove the from plate. you need to get on your knees to see this. put a peice of tape on the door interlock. turn it on. the ignitor glow bar should be red hot. This ignites the gas. I suspect that it is not going on at all. and the tumbling in the unit airates the clothes making it seem like its on. Remember to take the door off first. this website has the ignitor you need
http://www.repairclinic.com/Maytag-Dryer-Parts?s=t-starter-%3d%3db4a8c249
If this helped please rank me
Posted on May 24, 2009
Hoover washer dryer Error Code E12 during dry programme. How can I fix?
E12 means a problem filling on dry cycle.
Unplug the appliance, take the top off and check that the plastic condenser below the fan is clear and clean.
If this is ok, the most likely fault is the triple valve isn't opening properly to feed water into the condenser.
Nov 03, 2012 | Washing Machines
No heat from hoover hnv375
If not heat at all check for open heating element.
Sep 06, 2017 | Dryers
HI TIMES TODAY I HAVE PUT ON MY HOOVER DISHWASHER , IT GOES THROUGH THE CYCLE RIGHT UP TILL THE DRYING THEN THE FLASHING LIGHT THAT SHOWS ITS WORKING JUST STOPS AND THEN NOTHING, PLEASE HELP
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 08, 2010 | Hoover Dishwashers
Just moved into a house in Singapore with a Hoover D6786 dryer. It starts up and spins but repeatedly stops spinning after only 5-7 minutes. Clothes will not dry. What's up? Thanks for any help.
This is normally the sign that the electric motor start/run capacitor has gone faulty: the special motor start/run capacitor, usually around 4 to 10 uF / 450v, helps the motor during the stop/start sequences which require higher torques.
Aug 05, 2010 | Hoover Dryers
Programme problems hoover nextra megaload
I had this problem soon after I purchased mine. The engineer came out and readjusted the dial. Hope this helps.
Feb 26, 2009 | Hoover Nextra HNF 3157 Front Load Washer
Dryers Logo
91 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
