Question about Orion Car Audio & Video
Orion MDC-201 disc player will not scip forward or back on the Mini disc so does not play, the multi jog just turns rather than part turn clockwise or anti-clockwise, can this component switch be rep
Mini disc will not select or play
  • 27 Answers
SOURCE: Sony MZ-N505 - says mini disc is blank
Hi- it sounds like the record head is bent or needs adjustment. I do repairs on Sony minidiscs, so you may contact me at: masondixon@netzero.com for help.
Jacques
Posted on Nov 21, 2008
  • 13 Answers
SOURCE: Yamaha S661 Player wont play multi region
This one is for S530, S540, S550, S557, S560, S600, S657. It's worth a try. Tell me if it works.
  1. Open the disc tray
  2. Press 9, 9, 9, 9, 0
  3. Press ENTER
  4. Close the disc tray
Posted on Apr 15, 2009
SOURCE: dvd "unknown disc" message coming up
When Your DVD shows "LOADING" for quite some time and then if shows "UNKNOWN DISC" or "NO DISC", Open the cover of your DVD Player, Remove the flap over the disc by opening the screws. Remember that you are not keeping your eyes perpendicular to the lens. Now take Colin liquid in an ear buds and rub over the lens. Now with dry end of the bud, rinse it and make it dry. Keep the disc in the space provided for. Put on the Flap over the disc. And try to run it. I hope this would work fine.
Posted on Jul 13, 2009
SOURCE: My JVC cd player, plus Mini disc, and radio. CD will not play
Thank you for your email. The problem must have been dust. I kept putting the cleaning disc in for quite a number of times. Thankfully the problem was simple and it is playing super.
Kind regards to all.
Tonytopaz
Posted on Oct 13, 2009
seanpwright
  • 2030 Answers
SOURCE: 3 phase air compressor wrong rotation
yes it will you need to make sure you have the proper wires connected to get either clockwise or counter-clockwise rotation.
try changing the hot wires around to correct your problem
Posted on Mar 31, 2010
Hi, I am seeking the region free code for a Samsung DVD-D530? Thanks!
I tried the above steps, but each time when restarting the DVD player, it said 'reset' and asked for the language to be selected again. Pressing the "Fast Forward Fast Rewind Fast Forward Up Down" sequence caused the player to lock up and require powering off at the wall.
I found on another web site that there are different initial sequences. Once I use the one for Region 2, it worked fine.
I found the instructions below on another web site, but it worked for me...
  • Make sure there is no disc in the player.
  • Turn on the player (you can use remote control or front panel, it doesn't matter)
  • Wait for "No Disc" message to appear on the TV screen.
  • Press the Repeat button on remote (plain, not A-B).
  • Press the correct sequence of buttons of remote according to the original region code of your player (it's on the sticker on the back panel of the player). FF = fast forward, FR = fast rewind.
    • Region 2 players: FF, FR, FF, UP, DOWN
    • Region 3 players: FF, PLAY, FR, UP, LEFT
    • Region 4 players: FR, PLAY, DOWN, DOWN, RIGHT
    • Region 5 players: FF, UP, DOWN, STOP, RIGHT
    • Region 6 players: LEFT, RIGHT, RIGHT, PLAY, LEFT
  • If you pressed the correct sequence, a small white number 0 will appear somewhere on the top right of the screen. The white number 0 of the same font and size as the "No Disc" message, so don't confuse with the red "not allowed" sign that would appear when you press a function that's not available.
  • Turn the player off and on again, then you can pop in a DVD of any region and watch immediately.
Apr 30, 2011 | Samsung Televison & Video
SETTING CLOCK ON JENSEN PHASE PCD120U
Display Selector (DSP)
This unit can display either the clock time or
radio frequency/CD player functions. Ordinarily,
the radio frequency or CD player track
indication is displayed, but the unit will display
the time when the DSP button (18) is pressed.
The time will display for approximately 5
seconds then return to the radio or CD player
function display. The correct time-of-day can be
set by pressing and holding the DSP button.
Setting the Clock
To set the clock, perform the following steps:
1. Turn the vehicle ignition and radio on.
2. Press and hold the DSP button (18) until
the time display flashes.
3. Within 5 seconds, turn the MULTI/JOG
control (3) clockwise to adjust the minutes
to the desired setting.
4. Turn the MULTI/JOG control counterclockwise
to adjust the hour and the “AM”/
Jan 28, 2010 | Vehicle Parts & Accessories
Same problem - carousel won't turn
Take the cover off of DVD player and get a Qtip and alcholol. Clean the head glass thing that reads the DVD and it will work fine. Just be gentle. This has happened a few times and works great. It is just dirty.
You might get away with just using the Qtip if you dont have cleaning alcholol.
IT WILL WORK.
Jul 28, 2009 | Sony DVP-CX995V Multi-disc DVD Player
What dvd players do the mini dvd-rw discs play on?
Hello sir/ma'am good day, all dvd players has this small circle on the center of the tray, where you play the mini dvd disk. eject your dvd tray to see. hope this helps. thanks
Jul 15, 2009 | GE 5803P Multi-disc DVD Player
Unlock Region Code for LG XB12 Mini Home Theater
Below is the only known process to unlock the region settings on that model of dvd player.
Make sure there is no disc in it
Turn on by pressing "Power"
(--------) apears an "No Disc"
Press "Pause" on remote and "314159"
"Code" apears
Press "0"
"Code 00" apears
press "enter"
Turn off and on
Hope this works for you, let me know. If it doesn't then there are no available region hacks for your dvd player.
Thank you for trying Fixya!
Mar 25, 2009 | Sylvania DVC-840E DVD Player/VCR
Failure to shut down when playing one cd.
Try checking the control and try pressing repeat. Maybe its in repeat mode. Oh...fast forward and you won't need to wait to Check it out. Let me know...
pita3obn
Jan 06, 2009 | Bose Wave music system Multi-CD Changer...
YAMAHA CDR HD 1500
Go to HDD Utility -and then HDD Format
To do that click on MENU, then turn the Multi-Jog up to HDD Utility
Press once on MultiJog to select HDD Utility, and then turn the Multi-Jog to HDD Format.
Press once on MultiJog to select HDD Format
Then Click on the small "Complete" Button
Nov 23, 2008 | Yamaha CDRHD1500 CD Player
Code for dvd player dvd252
Pioneer DVD player (DV-505, DV-525, DV-606, etc.) Note: Some codes work on LD/DVD combo players only, such as "Disc side A/B".
Note: The LD/DVD 0525 code will work too, but the arrow keys (among other things) won't work without being keymoved to the correct codes.
000 Chapter prev
002 Pause
003 Scan reverse
012 Disc side A/B
014 Random
028 Power on/off
029 Step/slow reverse
030 Audio
031 Exit?
033 Menu
034 +10
035 Power off
061 Power on
062 Power on
063 Demo (when player is off)
064 Power on
067 Reset (when player is off)
076 Program
077 Repeat A-B
078 Disc side B
080 Disc side A
082 Enter
084/086/088/090 Shuttle reverse
085/087/089/091 Shuttle forward
092 A/D/CX
093 8
097 9
140 Return
142 Last memory
143 Up arrow
147 Down arrow
150 Subtitle
156 Title
157 Mode (set-up)
158 Open/close
160 Angle
161 Condition
162 Step/slow forward
163 Chapter/time/frame search
191 Chapter next?
195 Chapter prev?
196 Right arrow
203 Left arrow
204 Repeat
205 Time search
208 Clear
209 Chapter search
211 Display
212/214/216/218 Jog reverse (w/still)
213/215/217/219 Jog forward (w/still)
220 4
221 0
222 6
223 2
224 5
225 1
226 7
227 3
252 Chapter next
253 Stop
254 Play (will turn on player and resume if player powered off)
255 Scan forward
Jul 11, 2008 | Televison & Video
CD player restarts cd from beginning each time
1) What year and model is it?
2) Probably not.
I have an Emerson from several years ago that I've taken all apart and put back together.  My guess is, unless it auto powers off when paused, or there's another button besides play/pause, stop, Back, forward, mode, prog, and antiskip, your problem is better-solved with an mp3 player. An ipod shuffle would do fine. The shuffle feature can be turned on or off, and one may jog without disturbing the electronics.
Nov 05, 2007 | Emerson (CKD2330) CD Player
Car Audio & Video Logo
50 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
